    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 668.7k Views 161 Watching
      Anton_S
      @efrey1991 said:
      hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
      tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favor
      Equilateral and quadrilateral grids work without licensing. The adjustable grid only works with licensing. If you desire to use equilateral grid, you do not need to license the plugin.
      • jo-keJ Offline
        jo-ke
        @anton_s said:
        @jo-ke Did you use the extension manager to install ClothWorks? If not, install ClothWorks RBZ via the Extension Manager (and also SketchUcationTools if desired for licensing):
        1. Open SketchUp 2019
        1. Select (Menu) Window -> Extension Manager
        2. Click Install Extension button
        3. Select the downloaded RBZ file
        4. Restart SketchUp
        Let me know if this works.
        Still not able to reinstall.
        Installing via Scetchucationtool I am getting the error: "UnZIP error: Could not unzip archive"
        Strange...
        http://www.zz7.de
        • jo-keJ Offline
          jo-ke
          Now I used a different library to save the extension.
          I relicensed the product and it worked well.
          After restarting SU everything disappered. 😞
          What did I wrong?
          http://www.zz7.de
            This sounds like a problem typical of incorrect installation of SketchUp. When you installed SketchUp 2018 (I assume that's the version you are using as indicated in your profile), did you right click on the downloaded installer file and select Run as administrator from the context menu?
            • jo-keJ Offline
              jo-ke
              Oh since a few months I am using SU2019.
              I just started the exe file and installed SU and followed the instructions.
              http://www.zz7.de
                So does that mean that you did not install SketchUp 2019 by right clicking and selecting Run as administrator? If you didn't, close SketchUp and repair the installation. Find the downloaded installer file, right click on it. Choose Run as administrator and when presented with the options, select Repair.
                • jo-keJ Offline
                  jo-ke
                  OK Thank you. I will try it and report....
                  http://www.zz7.de
                  • jo-keJ Offline
                    jo-ke
                    I hate it... Where can I find the current download of SU2019pro.
                    Can't find it at the homepage of SU....
                    http://www.zz7.de
                    • jujuJ Offline
                      juju
                      https://www.sketchup.com/download/all
                      • jo-keJ Offline
                        jo-ke
                        Thank you juju. OK, found the installation file, downloaded it, ran as admin, repaired su and restarted my pc. Started su and: clothworks dissappeared again. 😞
                        http://www.zz7.de
                          Anton_S
                          Does this occur to all your plugins or just ClothWorks?
                          • jo-keJ Offline
                            jo-ke
                            It affects only clothworks
                            http://www.zz7.de
                            • jo-keJ Offline
                              jo-ke
                              somebody any idea?
                              http://www.zz7.de
                                What exactly does "dissappeared" mean? Is it only that the toolbar doesn't show? Does it show in the Extensions menu? Does it show in Extension Manager? If it does, does it show as Enabled?
                                • jo-keJ Offline
                                  jo-ke
                                  first session:
                                  starting SU installing clothworks. everything OK.
                                  clothing SU
                                  second session:
                                  starting SU, clothworks dissappeared completely.
                                  http://www.zz7.de
                                    Anton_S
                                    @jo-ke In your second screenshot, you have ams_ClothWorks at line 2. I am totally not sure where that is coming from.
                                    Paste the following into your file explorer address bar and send a screenshot of the plugins: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
                                    Then navigate into the ams_ClothWorks folder (if any) and send a screenshot.
                                    Then, paste the following into your file explorer, and send a screenshot, if the Plugins folder exists:
                                    C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
                                    • jo-keJ Offline
                                      jo-ke
                                      OK, theses are the two screenshots:
                                      http://www.zz7.de
                                        Anton_S
                                        As you can see, you have the same plugin installed in both locations. Delete the plugin from one of the installed locations. To delete the plugin, delete ams_ClothWorks folder and ams_ClothWorks.rb file from either program data or roaming. I see that the one located in roaming is newer.
                                        • jo-keJ Offline
                                          jo-ke
                                          Thats it!
                                          I deleted all folders in both directories and the rb files and reinstalled the plugin.
                                          restarted su and: it was still there!
                                          Thank you
                                          http://www.zz7.de
                                            This begs the question, how did you install Clothworks in the first place? With the normal installation methods, you shouldn't have been able to get it installed in the two directories. It should have only been installed in User/App Data/Roaming...
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 34
                                            • 35
                                            • 19 / 35
