ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Problem with Displacement - Vray
renderpluginsextensions
7 Posts 2 Posters 5.0k Views
  • U Offline
    united_tb
    How to fix this problem with Vray for Skp? Please!!!
    https://i.ytimg.com/vi/2MixTivJxIE/hqdefault.jpg
      rv1974
      Keep continuity
      • U Offline
        united_tb
        Oh, sorry!
        This is the real problem I want to ask, with 2 different materials:
        • U Offline
          united_tb
          Help me. Please!!!
            rv1974
            I already told you. Check keep continuity option
            • U Offline
              united_tb
              But, this option only works with the same material.
              With 2 different materials ... like the image above.
              Sorry, if my English makes you confusing. I'm Vietnammese.
                rv1974
                Why do you need 2 materials? All sides on your picture look identical.
                Anyway if you still want 2 the easiest fix is PS. Select problematic areas, then Fill with content Aware option. Plus some Stamp tool.
                P.S. In 3ds Max displacement can work as modifier (not like a part of material) so multiple materials on one object is not a problem.
                Good luck.
                P.P.S. Try Vray Fur- it has no seams.
