The difference between Sketchup APIs
Hello,
I am in my first days with Sketchup. I had an experience in Revit API but here in Sketchup I found APIs in Ruby, C, Visual Basic, C++ and C#
I searched a lot to detect the difference between them but no luck.
Can you please help.
Regards.
@modar said:
Hello,
Regards.
The SketchUp Ruby API is embedded in the app itself for live action on the model. It is the main technique for implementing extensions (aka plugins).
The SketchUp C SDK is a separate library for creating standalone applications that can manipulate a SketchUp file outside of SketchUp itself and also for creating importers/exporters for other file formats.
The SketchUp C++ SDK is similar to the C SDK but is now being deprecated.
None of the other language bindings you list are officially supported by SketchUp.
Thank you for your valuable reply
This is what I found about C#
https://forums.sketchup.com/t/access-sketchup-sdk-from-c-net-project/74666does this mean that i can develop a plugin for SketchUp using C#Ψ
Regards.
