    [Plugin] Angular Dimension
    63 Posts 14 Posters 78.1k Views 14 Watching
      slbaumgartner
      @dave r said:
      The precision of the angle is driven by the precision you have set in Model Info>Units. For angular units you have up to 3 places right of the decimal.
      Dave, you are absolutely correct. I used SketchUp's built-in formatting for the angle, which obeys whatever the user has set in the model info.
      Steve
      • dereiD
        derei
        About angle precision... indeed, it uses SU precision, but sometimes even with three decimals, it still shows the ~ symbol. Maybe it should be suppressed if the angle precision goes beyond three decimals, because it is really confusing when you see ~30.000 degrees, for example. It would be somewhat understandable to see ~30.00 when the angle is 30.001 degrees, but as the precision cannot go beyond 3 decimals, there is no point to keep the "~" in that case.
        DESIGNER AND ARTIST DEREI.UK
          slbaumgartner
          You are mistaking the display format for a limit on calculation precision. The units settings in the model info affect how many decimal places SketchUp will display. But it is still perfectly possible to calculate or set a value to more places. For example, if the value is 30.0002 degrees, it will display as ~30.000, telling you that the actual value was rounded based on the display units. This is the same as occurs for all SketchUp units.
          • dereiD
            derei
            Actually I am not mistaking it. I know what you want to say. But I also know that programmatically the "~" can be removed by feeding in a "rounded" value to 3 decimals. So, if SU returns 30.0001 degrees and the plugin will round it to 30.000, then it will NOT display the "~". Of course, this will mean losing the fourth decimal precision... but wait: I can't use the fourth decimal, even if it's there. So, technically there is no lose at all, because SU won't even display the fourth decimal in degrees value.
            Is just for best displaying properties... to lead to less confusion.
            As an example, I just rotated a guide line with PRECISELY 30 degrees, but this tool shown me ~30 deg. Meaning that SU was not able to make the rotation to 30 degrees sharp (due its implicit precision limitation, which is fine). But again, the value that made for "~" to appear was somewhere far beyond the decimal point (maybe fourth/fifth decimal), which is completely not important. So, if the plugin just rounds-up the value to 3 decimals and dumps everything else, I believe we are in a common sense "territory".
              slbaumgartner
              You are asking me to make a decision for the user about whether the full precision of a value is important or not. I simply conform to the behavior of all the other units in SketchUp. I don't see why consistency should cause confusion.
              For example, if you have length units set to 0.0m and an actual length is 0.02m would you expect a linear dimension to display it as 0.0m rather than ~0.0m?
              By the way, my experience is different from yours. I just rotated a guide by 30 degrees and the angular dimension displays exactly 30.000 without any ~. Did you type 30 to get an exact value, or click after rotating in the view?
                driven
                unless you typed in '30degrees' there is a strong possibility SU rounded the radians up or down...
                • dereiD
                  derei
                  Or maybe it was too close to some other geometry and it snapped to it... whatever cause it was, it rounded it to some value that was askew from 30.000. And this is precisely why I got this detail into attention: because such approximations can happen. And unless the precise value can be displayed, there is no reason to provide the ~ symbol. Rounding all values to three decimal precision would be the most elegant way to solve this.
                    slbaumgartner
                    I request that you post this as a feature request for discussion at the general level of SketchUp, as it has far broader implications than here. In effect you are asking that I "mask" (i.e. not show) or perhaps even heal small modeling errors. I don't agree at all. Such errors are the source of numerous "why doesn't pushpull (or whatever tool) work right?" posts. I see the "~" as a feature, not a flaw. It tells you when you have been sloppy. But, more importantly, if such a change is to be made, it should be consistent across all units displays in SketchUp, not just provided by this extension.
                    • dereiD
                      derei
                      I understand your point... and it makes perfect sense.
                      What does NOT make sense is that on linear dimensions you can actually see where the flaw is (because user can choose a much greater precision), the issue here is that for angles you can't see it, if the error goes beyond 3 decimals, thus impossible to correct.
                      So, if I see ~30.000 I have no idea how I should correct it. Is it 29.9999, or is it 30.0001 ? Hence the confusion I was talking about.
                      Maybe to add it as option in a simple setting menu? Kind of keypress switch? Select the tool and in the information bar of sketchup to have a quick description "Press Ctrl to enable (or disable) round-up feature". As you say, in many instances this can be really useful, as it will tell the user there is a problem (even if the problem can't be seen with accuracy). But in other cases, if I see three zeroes after decimal point, I may be just happy to see it rounded.
                      Anyway, currently I just edit the text, but when I have to edit several angular dimensions, is a bit frustrating.
                      Just a suggestion.
                        Roggencrane
                        Can't seem to install download. Error message "This does not appear to be a Sketchup model!" Downloads just fine but that is as far as I can get. I wish I could send you a screen shot.
                          This indicates you're trying to open the extension as if it was a SketchUp model. To install it, you need to go to Window>Extension Manager and click on Install... Then navigate to where you saved it, select it, click Open and then Yes.
                          Better would be to install the Sketchucation Plugin Store extension, use it to access and automatically install extensions.
                            servile
                            nice work..
                            is there option to change decimal degree into degree, minutes, second
                            or, decimal degree with two digits behind comma
                            Thank you
                              The precision of the angle is based on the setting in Model Info>Units.
                                slbaumgartner
                                Although his image shows the newer Angular Dimension 2, DaveR is right that the formatting of the angle in both versions follows the settings in Model Info-> Units. At this time SketchUp provides only decimal degrees, but you can choose the number of places. It would in principle be possible to add a custom format for degrees, minutes, and seconds in the extension, though to date yours is the only request for this feature.
                                • P
                                  Pntch06
                                  Hi! I don`t know if someone else has issues when launching sketchup after installing the pluging. It is freezing the program πŸ˜•
                                  Please help
                                    Use Angular Dimension 2 instead.
                                      slbaumgartner
                                      Please help
                                      That's a new issue that hasn't been reported previously. I haven't been able to reproduce it.
                                      The code hasn't been modified since 2015, so this isn't due to any recent changes by me. Have you tried uninstalling the plugin to see if that makes the problem go away? It doesn't do anything during SketchUp startup that would explain freezing the program, so I unless some other plugin is interacting with it, I am at a loss as to what may be going on.
                                      As @DaveR mentioned, Angular Dimension 2 is the successor plugin to this one. It uses 3D text in the plane of the angle instead of leader text floating on the screen. That avoids issues where the leader text punches through or hides behind objects in the view. It also provides a lot of format customization options that the original Angular Dimension did not have.
                                      • 3 / 4
