    3D Truss Models
    1.5k Posts 31 Posters 924.3k Views 30 Watching
    • medeekM Offline
      medeek
      Continuing on with regards to multi pitch hip roofs we need to be very clear about what point on the roof lines up when we talk about lining up the fascia. Do we mean the sub-fascia, rafter tail or the fascia?
      Since I currently don’t have the fascia and soffit added yet I can probably ignore these for now and state that the top of the fascia board must line up with other fascia boards on other roof planes.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • pbacotP Offline
        That make sense but in cutting rafters or fabricating trusses, isn't the only thing they can really do is line up the top of the rafter tails? Actually if there are tails, the truss manufacturer will leave it to the carpenter.
        • medeekM Offline
          medeek
          In the field I think its typical to provide rafter tails that are too long so that they can be trimmed all at once (chalk line) to ensure that they all line up.
          design.medeek.com
          • medeekM Offline
            medeek
            I've got the asymmetric options added to the edit menu and the common rafters and fascia are calculating correctly:
            http://design.medeek.com/resources/images/truss_su382_800.jpg
            Note that all four pitches are different values, however the fascia lines up all the way around the roof as it should (in this case I have the overhangs auto calculating).
            Next I will work on the hip rafters and jack rafters. As we can see in this example, all symmetry is broken, each hip rafter will be unique (x4) as well as each set of jack rafters (x8). Luckily we can program this sort of thing, drawing this type of roof manually would be a real headache.
            design.medeek.com
            • medeekM Offline
              medeek
              First look at the sheathing and labels for an asymmetric hip roof:
              http://design.medeek.com/resources/images/truss_su383_800.jpg
              http://design.medeek.com/resources/images/truss_su384_800.jpg
              design.medeek.com
              • medeekM Offline
                medeek
                Pitch and SQFT callouts/labels are now working:
                http://design.medeek.com/resources/images/truss_su385_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Hip and Ridge Cap is now working:
                  http://design.medeek.com/resources/images/truss_su386_800.jpg
                  This chunk of code is just for the ridge cap geometry:
                  @Phi1_3 = atan(sin(@Phiplane13) * tan(@Phi) * cos(@Phihip13))
                  @Phi3_1 = atan(cos(@Phiplane13) * tan(@Phi3) * cos(@Phihip13))
                  @Phialpha1_3 = acos(cos(@Phihip13) * sin(@Phiplane13))
                  @Phialpha3_1 = acos(cos(@Phihip13) * cos(@Phiplane13))
                  @Psi1_3 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi)*cos(@Phi3)))
                  @Phi2_3 = atan(sin(@Phiplane23) * tan(@Phi2) * cos(@Phihip23))
                  @Phi3_2 = atan(cos(@Phiplane23) * tan(@Phi3) * cos(@Phihip23))
                  @Phialpha2_3 = acos(cos(@Phihip23) * sin(@Phiplane23))
                  @Phialpha3_2 = acos(cos(@Phihip23) * cos(@Phiplane23))
                  @Psi2_3 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi2)*cos(@Phi3)))
                  @Phi1_4 = atan(sin(@Phiplane14) * tan(@Phi) * cos(@Phihip14))
                  @Phi4_1 = atan(cos(@Phiplane14) * tan(@Phi4) * cos(@Phihip14))
                  @Phialpha1_4 = acos(cos(@Phihip14) * sin(@Phiplane14))
                  @Phialpha4_1 = acos(cos(@Phihip14) * cos(@Phiplane14))
                  @Psi1_4 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi)*cos(@Phi4)))
                  @Phi2_4 = atan(sin(@Phiplane24) * tan(@Phi2) * cos(@Phihip24))
                  @Phi4_2 = atan(cos(@Phiplane24) * tan(@Phi4) * cos(@Phihip24))
                  @Phialpha2_4 = acos(cos(@Phihip24) * sin(@Phiplane24))
                  @Phialpha4_2 = acos(cos(@Phihip24) * cos(@Phiplane24))
                  @Psi2_4 = asin(0.70710678118 * sqrt(1.0 - cos(@Phi2)*cos(@Phi4)))
                  @Ridgex = (cos(@Phi)*@HRthk*tan((@Phi + @Phi2)*0.5)) - sin(@Phi) * @HRthk
                  @Ridgey = (sin(@Phi)*@HRthk*tan((@Phi + @Phi2)*0.5)) + cos(@Phi) * @HRthk
                  if @Sheathing_option == "YES"
                  if @Roofbatten == "YES"
                  if @Cboption == "YES"
                  thtot = @Cbheight + @Battenheight + @Sheathing_thickness + @Roofcladding_thickness
                  else
                  thtot = @Battenheight + @Sheathing_thickness + @Roofcladding_thickness
                  else
                  thtot = @Sheathing_thickness + @Roofcladding_thickness
                  else
                  thtot = @Cbheight + @Battenheight + @Roofcladding_thickness
                  else
                  thtot = @Battenheight + @Roofcladding_thickness
                  else
                  thtot =  @Roofcladding_thickness
                  # Extension at Peak
                  @Wa3 = PI - (@Phialpha3_1 + @Phialpha3_2)
                  @Beta23 = atan(sin(@Wa3)/(tan(@Psi1_3)/(tan(@Psi2_3)) + cos(@Wa3)))
                  @Beta13 = @Wa3 - @Beta23
                  ext13 = (thtot * tan(@Psi1_3))/(tan(@Beta13))
                  ext23 = (thtot * tan(@Psi2_3))/(tan(@Beta23))
                  @Wa4 = PI - (@Phialpha4_1 + @Phialpha4_2)
                  @Beta24 = atan(sin(@Wa4)/(tan(@Psi1_4)/(tan(@Psi2_4)) + cos(@Wa4)))
                  @Beta14 = @Wa4 - @Beta24
                  ext14 = (thtot * tan(@Psi1_4))/(tan(@Beta14))
                  ext24 = (thtot * tan(@Psi2_4))/(tan(@Beta24))
                  # Ridge Length and Extensions
                  ridgedx = (cos(@Phi)*thtot*tan((@Phi + @Phi2)*0.5))
                  ridgedy = (sin(@Phi)*thtot*tan((@Phi + @Phi2)*0.5))
                  length_sq = thtot**2 + ridgedx**2 + ridgedy**2
                  rext3 = sqrt(ext13**2 + (thtot/(cos(@Psi1_3)))**2 - length_sq)
                  rext4 = sqrt(ext14**2 + (thtot/(cos(@Psi1_4)))**2 - length_sq)
                  phicheck3 = atan(ext13*cos(@Psi1_3)/thtot) + PI - @Phihip13
                  phicheck4 = atan(ext14*cos(@Psi1_4)/thtot) + PI - @Phihip14
                  if phicheck3 > PI
                  	rext3 = -1.0 * rext3
                  if phicheck4 > PI
                  	rext4 = -1.0 * rext4
                  @Ridgecaplength = @Arraylength - @Hipf - @Hipb + rext3 + rext4
                  design.medeek.com
                  • pbacotP Offline
                    WOW.
                    I hope you never see a roof like this, but kudos for handling the situations where we may have a couple different pitches anyway.
                    • medeekM Offline
                      medeek
                      Gutters and Downspouts are now functional for the Asymmetric Hip Rafter Roof:
                      http://design.medeek.com/resources/images/truss_su387_800.jpg
                      Even with the different overhangs and top plate heights the gutter height (fascia) is the same height all the way around. However the downspouts on opposite sides of the roof are customized per the overhang on each respective side.
                      Tomorrow I will jump back into the hip and jack rafters and see if we can wrap this one up.
                      The good news is that the required code for the asymmetric hip and jacks already exists. I will be borrowing from the roof return module where I handled dissimilar pitches. The bad news is that after a cursory review of this block of code I have absolutely no idea how it actually works anymore (I haven't looked at it in about 2 years). It's just a matter of reverse engineering my own code for about an hour and it will all come back to me.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I'm actually still working on the hip rafters. The complexity of a multi-pitch roof took another unexpected turn with the realization that when roof planes A and B are different pitches it causes an offset in the rafters at the peak which requires some additional logic to account for this fact with the placement of the hip rafters and their geometry.
                        I'm also still a bit conflicted on how to best handle the birdsmouth cut of the hip rafters when they walls have different top plate heights. In some cases the hip rafter misses the corner entirely and is askew on one of the walls, this is the simple case. In other cases the hip rafter technically rests at the "corner" but since there are two different wall heights possible it is not clear how the birdsmouth cut should be constructed exactly. I'm assuming that the higher plate height will govern.
                        Does anyone have any photos or details of actual construction where a hip rafter bisects a corner where the top plate heights vary?
                        design.medeek.com
                        • pbacotP Offline
                          Got me looking for examples. I've created (or passed on) far more problems like this for others, than I ever had to deal with in the field. You might look at this guys webpage. https://deskgram.net/explore/tags/bastardhip
                          • medeekM Offline
                            medeek
                            Note how this hip rafter sits askew, only on one wall:
                            https://scontent-atl3-1.cdninstagram.com/vp/0c3557437b831311132380364886be2f/5D60F286/t51.2885-15/e35/35575469_1787088774714743_1874779179191369728_n.jpg?_nc_ht=scontent-atl3-1.cdninstagram.com
                            design.medeek.com
                            • pbacotP Offline
                              Yes. I once did a little roof framing, using old school framing square methods from a book. Sometimes I just had to work it out in the field.
                              • medeekM Offline
                                medeek
                                When the hip roof is asymmetric across the ridge you end up with a situation like what is shown below:
                                http://design.medeek.com/resources/images/truss_su388_800.jpg
                                The common rafter in the upper right is a 7:12 pitch and the common rafter in the lower left is a 10:12 pitch. Normally with a symmetric hip or gable roof the common rafters would be flush with the top of the ridge board.
                                However in the asymmetric case the steeper pitched side is flush and the lesser pitched side overshoots the ridge board just slightly as shown. This additional asymmetry causes further complications in the calculations of the hip rafter that is adjacent to the overshooting common.
                                Also note that the seams in the sheathing (edges of the roof planes) do not center up on the ridge board or hip rafters. This is not a flaw or an error it is just the way the asymmetric roof goes together.
                                It appears that I have the hips correctly calculating now (after nearly two days of intense debugging and about 10 sheets of engineering pad) however tomorrow I will continue with further testing, to see if I can break anything, and then begin attacking the jack rafters.
                                A further look at the bird mouth cut question in shown in the example below:
                                http://design.medeek.com/resources/images/truss_su389_800.jpg
                                So in reality I am still missing the birds mouth cut for the hip rafters and the implementation of the soffit cut for trimming the tails of the hip rafters. Always too much to do and never enough time to get it all done.
                                I'm really hoping that the jack rafter piece is a lot less trouble than the hip rafters, I would really like to get this roof type wrapped up by the end of the weekend.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Since each hip rafter is potentially unique each one requires the following calculations (for those that are interested):
                                  @Returnext = @HipendX + @Overhang3_num
                                  @Returnext2 = (@Pitch3/@Pitch) * @Returnext
                                  @Returnexthip = sqrt(@Returnext * @Returnext + @Returnext2 * @Returnext2)
                                  @Zeta = acos(@Returnext/@Returnexthip)
                                  @Tcy4mod = 0 - @Fascia_width * (tan(@Phi) - tan(@Phi3))
                                  @Returnext2mod = @Tcy4mod/(tan(@Phi))
                                  @Zeta_a = atan((tan(@Zeta))/(cos(@Phihip13)))
                                  @Zeta_b = atan(tan(@Zeta)*cos(@Phihip13))
                                  @Iota = atan(sin(@Zeta)*tan(@Phihip13))
                                  @Kappa = atan(cos(@Zeta)*tan(@Phihip13))
                                  @Term1 = (cos(@Zeta_a))/(cos(@Iota)) + ((sin(@Zeta_b))/(cos(@Kappa))) * ((tan(@Phi) - tan(@Iota))/(tan(@Phi3) - tan(@Kappa)))
                                  @Abar = @Ply/@Term1
                                  @Hipoffsetx = (@Returnexthip - @Ply) * sin(@Zeta)
                                  @Bbar = @Abar * ((tan(@Phi) - tan(@Iota))/(tan(@Phi3) - tan(@Kappa)))
                                  @Ebar = @Returnext - ((@Returnext2 + @Returnext2mod - @Abar)/(tan(@Zeta)))
                                  @Fbar = @Returnext2 + @Returnext2mod - (tan(@Zeta))*(@Returnext - @Bbar)
                                  if @Phi2 > @Phi
                                  	@Zbar = @Ry4 - @Ry4r
                                  	@Xbar = @Zbar/(tan(@Phi))
                                  	@Bbarmod = ((@Abar+@Xbar) * (tan(@Phi) - tan(@Iota)) - @Zbar) / (tan(@Phi3) - tan(@Kappa))
                                  else
                                  	@Zbar = 0
                                  	@Xbar = 0
                                  	@Bbarmod = @Bbar
                                  @Exthip13 = ((@Xbar+@Abar)*cos(@Phihip13)/tan(@Zeta))/(cos(@Phialpha1_3)) - @Zbar/(tan(@Phihip13))
                                  Term1 of the Abar equation is really interesting. If I took the time I could probably condense down some of the variables and reduce the amount of algebra but then in the future it would be harder for me to follow, so it is best left as verbose as possible for myself and future generations.
                                  The terms Abar, Bbar, EBar and Fbar specify the compound bevel cuts at the peak and eave of the hip rafter.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Actually I stand corrected. The sheathing does center up on the ridge board provided that you do vertically offset the opposing common rafters as shown in the previous images. A top down view shows the result:
                                    http://design.medeek.com/resources/images/truss_su390_800.jpg
                                    If you don't vertically offset the commons and the pitch on plane A and B differ then the ridge board will not center up on the sheathing. For now I have it centering and a vertical offset, for future work I may provide an option to toggle between these two possible configurations.
                                    Here is a view of the other side of the roof, note the different top plate heights and where the hip rafters land on them and the corners:
                                    http://design.medeek.com/resources/images/truss_su391_800.jpg
                                    Better yet, go ahead and download my test model that was most recently generated by the new asymmetric module:
                                    3D Warehouse
                                    (3dwarehouse.sketchup.com)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      First look at the jack rafters:
                                      http://design.medeek.com/resources/images/truss_su392_800.jpg
                                      Next I will look at the birds mouth cut of the hip rafters and the soffit cut for both hip and jack rafters, then a bit more testing to see if anything can be broken when the degenerate case (symmetric roof) is calculated.
                                      These is also the case where you might end up with a negative overhang (which doesn't make sense). I should probably include some logic to try and detect this condition and alert the user that the roof configuration is not physically possible.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        The birds mouth cut algorithm (and code) is now functional however I can't say I'm completely satisfied with it yet.
                                        For example take a look at this scenario:
                                        http://design.medeek.com/resources/images/truss_su393_800.jpg
                                        You have a 8:12 and 7:12 meeting almost at the corner of the building (skew is minimal) however the plate height is 2" higher on the 7:12 side and my algorithm cuts the birds mouth per the highest plate height at the corner.
                                        In this particular case it would seem to make more sense to cut the birds mouth at the lower plate height otherwise not enough meat is left in the hip rafter. This algorithm may need further refinement to really make it meaningful and useful to the designer.
                                        The other option of course is to simply not cut the birds mouth in the hips rafters and leave it to the user to determine what or how they want to handle the intersection at this critical junction.
                                        The soffit cut in the case of a hip roof is actually quite simple (surprisingly). Since the fascia lines up all the way around the roof the soffit cut will also be the same height for all jacks, commons and hip rafters.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          The soffit cut function is now active for hips, jacks and commons:
                                          http://design.medeek.com/resources/images/truss_su394_800.jpg
                                          Now I will see if I can break the module, I'm sure there is some state or configuration that I haven't considered that may throw some errors.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.3.7 - 05.13.2019
                                            • Enabled asymmetric hip rafter roofs (imperial and metric units).
                                            http://design.medeek.com/resources/images/truss_su395_800.jpg
                                            The most degenerate version of the asymmetric hip roof would be a pyramid roof. The roof shown below is a pyramid roof that is actually an asymmetric roof, as you can see the algorithms degenerate gracefully as they should:
                                            http://design.medeek.com/resources/images/truss_su396_800.jpg
                                            Items for future work include the ability to toggle the configuration where the sheathing centers up on the ridge board or not.
                                            Another outstanding item is ceiling joists. I'm not even sure what do with ceiling joists yet for an asymmetric hip as there could possibly be four different ceiling joist heights.
                                            I would also like to switch everything to HTML menus. The initial draw menu is still using the default SU GUI. Due to its limitations you can only initially create symmetric hip roofs but then you can edit them to switch them to an asymmetric configuration. I will explain this further in an upcoming tutorial video. Once I switch to an HTML draw menu this limitation will be resolved.
                                            design.medeek.com
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 74
                                            • 75
                                            • 60 / 75
