    Draftsight fini de rêver !
    337 Posts 10 Posters 127.4k Views 10 Watching
    • PatrickP Offline
      Patrick
      Extrait Forum Dev.
      Updated by André Dagenais over 4 years ago
      Quote
      I didn't found where I can translate the menubar.
      Regards,
      André
      #19
      Updated by Ilya Slobodin (Nanosoft) over 4 years ago
      Quote
      The menu is inside NCad.cfg, just select it in the WldEdit and you will see the strings to translate.
      #20
      Quote
      I did that but when I start nanoCAD nothing change. Example, I would like to rename Draw menu to Dessin. I change it from WldEdit and I also check directly in nCad.cfg file. Do I have to reload the menu or recompile it? If yes, how can I do that.
      Regards,
      André
      #21
      Quote
      You need to reset the UI that is being read once from NCad.cfg and then is stored in the registry. You can use either of the following:
      Right click a toolbar, choose Customize and then reset. Then restart nanoCAD.
      Manually delete HKEY_CURRENT_USER\Software\Nanosoft\nanoCAD Plus Int\6.0\Profile\TOOLBARSETTINGS.
      Add
      [\Configuration]
      ClearRegistry=f1
      to the NCad.ini or create nApp.ini with this lines next to NCad.ini.
      #22
      Quote
      Thank you, it works!
      André
      #23
      Quote
      I have some problems translating the menu bar. When I try to translate using WldEdit, in \nCAD.cfg it seems that some menu are not available (ex, I didn't find Plot Preview or Zoom Extents). I can edit the nCAD.cfg file (using Notepad++) but it doesn't accept accentuated caracter like «é». From WldEdit, it's working well.
      #24
      Quote
      Please try to scan new strings in WldEdit with right click on NCad.cfg and then \Rescan...
      Couldn't Notepad++ change the file encoding into UTF-8? It should remain ANSI.
      #25
      Quote
      I've updated nCAD.wld in fr-FR folder. If you use Tortoise, you will see in the log file what have been translated.
      So it's started. I will update this regularly and I hope to complete this task by the end of the year.
      Regards
      André
      #26
      Quote
      Great! Thank you, André!
      #27
      Updated by Gabriel Laurent over 4 years ago
      File nCad.wld nCad.wld added
      File RegWizard.wld RegWizard.wld added
      % Done changed from 20 to 40
      Quote
      I send you the file with 40% transladed. but not finish. I have not finish. André are you finish?
      #28
      Updated by Anaël C. about 4 years ago
      Quote
      Hello,
      anyone working on the translation at the moment ?
      #29
      Updated by André Dagenais about 4 years ago
      Quote
      Hello,
      I'm not working on that actually. But some translations have been done in last months.
      André
      • chonC Offline
        chon
        Chez moi, le progamme d'install s'appelle NCE50(2007).exe.
        Selon ses propriétés, sa taille est de 394 095 584 octets et 394 096 640 octets sur disque.
        Patrick, tu as fait une install type démo comme Pilou ou tu as rentré les codes fournis par nanocad lors de l'inscription ?
          40% il était optimiste il y a 4 ans, moi j'en ai vu à peine 10 % 💚
          C'est un peu plus clair mais je vais quand même avoir du mal à faire leurs bidouille!
          et avec ces codes fournis tu restes en Free ?
          • PatrickP Offline
            Patrick
            Idem pour moi à 384 859 Ko
            J'ai rentré les codes fournis.
            La V10 (NCEP(x64)10.0(4520).exe) est à 542 775Ko en mode trial.
            • PatrickP Offline
              Patrick
              Si tu veux te connecter sur le forum Dev - Localisation je te passe mes identifiants en PM.
                tu peux leurs dire que la traduction est faite à 100 % mais néecessite un gros toilettage en cours! 😄
                Le fichier config lui-même necessitera 2 heures de plus donc négligeable, mais je ne le ferais que quand la bidouille aura réussi!
                Au fait tu as traduit le fichier "register" les 400 lignes ?
                • PatrickP Offline
                  Patrick
                  Ok je leur dis.
                  Non je suis à la bourre au boulot, je fais ces choses à cheval sur les pauses ou entre deux impressions.
                  • chonC Offline
                    chon
                    Donc tout pareil à la version de Windaube près... Ça m'énerve ! 😡 😡
                      ET demande-leurs si depuis 4 ans les conseils de modifications n'ont pas changé?
                      car je ne vois que des [\configman... ] et pas de [\configuration...]
                      • SERGIOS Offline
                        SERGIO
                        Salut tout le monde!
                        Pardonnez-ma question idiote mais le but de la manœuvre est bien de traduire Nanocad en Français?
                        mais Nanocad est payant non?
                        Sergio
                        • chonC Offline
                          chon
                          Sergio
                          Salut Sergio,
                          Il existe une version light genre AutoCrad LT, >>> ICI <<<.
                            Oui, c'est le but uniquement pour le fun car c'est pas le genre de programme que j'affectionne! 💚
                            De toutes manières c'est déjà fini il ne me reste que des formalités, du toilettage! 😄
                            (et une petite paires d'heures pour le "Config" de la broutille ça à côté du monstre! )
                            Enfin quand j'aurai réussi à l'installer dans le programme, pour vérifications, c'est pas gagné! 😄
                            je suis plutôt du genre Capow à la poursuite du Gnarl! 💚
                            Un super bouquin en ligne "illustré"! : The Lifebox, the SeaShell & the Soul
                            Je l'avais utilisé dans le temps (1999) ce Capow, le gars Rudy l'a remis au gout du jour mais il a l'air de dire que cela va moins vite, mais bon cela fait des images sympas! ☀
                            Un autre cadeau : Ready by the Gollygang 😄
                            • PatrickP Offline
                              Patrick
                              @sergio said:
                              Pardonnez-ma question idiote mais le but de la manœuvre est bien de traduire Nanocad en Français? mais Nanocad est payant non?
                              Sergio
                              Je leur ai posé la question (les grands esprits se rencontrent 💚 ) et comme pour PconPlanner leur modèle économique ne repose pas sur la vente de Nono mais des produits métiers reposant sur Nono.
                              Plus trivialement, c'est leur pot à miel. Bon ils donnent pas non plus la dernière mouture, contrairement à PconPlanner, mais elle fait dans le dwg 2013 quand même !
                              Donc avec Nono pour de la mise en plan, PconPlanner et SU (tant qu'il y a une version Free)on a une suite qui couvre les besoins de tout le monde, surtout si j'ajoute Blender pour les plus fous...
                              Patrick
                              • SERGIOS Offline
                                SERGIO
                                Chon, Pilour, Patrick,
                                Merci pour vos éclaircissements!
                                et bonne journée!
                                Sergio
                                  Pas d'idées pour débloquer la situaton ?
                                  il y a aussi un truc qui m'échappe un peu 😄
                                  Dans le fichier cfg il n'y a pas les "doubles lignes" Anglais / traduction
                                  c'est donc du direct ? Donc pas très commode pour vérification / modification! 😄
                                  @Patrick as-tu fait le fichier des 400 lignes
                                  je peux le faire en attendant un miracle! 😄
                                  Je vais faire aussi le CFG mais à l'aveuglette...on verra bien...
                                    Je te le laisse avec grand plaisir, que tu comprennes les affres et solitude d'un traducteur devant le penalty! 💚
                                    Ce qui ce passe sur le #69 ou le forum, c'est pas la peine de me le répercuter, j'y ai accès! 😉
                                    Bon je repars traduire dans le désert! 😄
                                    En laissant quand même les raccourcis du genre en attente,
                                    |Name=sCouper &t pour |Name=sCu&t pour être sûr qu'ils ne se chevauchent pas avec d'autres...
                                    j'aurais bien le temps de les remettre au propre à la fin si besoin, quand il n'y aura plus que ça! 😄
                                    Et encore je n'ai qu'un intervalle de confiance de 75% que cela soit la bonne partie à traduire avant confirmation! 💚
                                    https://www.avoir-alire.com/local/cache-vignettes/L240xH327/arton37579-0c445.jpg?1554803945
                                    • PatrickP Offline
                                      Patrick
                                      Ben j'ai pas de réponse sur le forum DEV
                                      Ben ils disent des trucs qui sont pas super évident, par exemeple :
                                      "You need to reset the UI that is being read once from NCad.cfg and then is stored in the registry. You can use either of the following:
                                      Add
                                      [\Configuration]
                                      ClearRegistry=f1
                                      to the NCad.ini or create nApp.ini with this lines next to NCad.ini."
                                      Ben vu que ce n'est "que le fichier d'installation" laisse le moi que je puisse me glorifier d'avoir participé 💚
                                      Là oui !
                                      Patrick
                                        Et c'est reparti dans le brouillard! 😄
                                        500 / 4 700
                                        Un essai conceptuel avec Magica Voxel : ça marche on peut envoyer une image Png elle ressort en .Vox manipulable voir my site par le logiciel! ☀
                                        La carte est fausse du point de vue des zones de verdures (c'est voulu) et le relief est amplifié (c'est voulu) mais ça marche! 💚
                                        D'ailleurs un petit site donne free les Height Maps du monde entier! 😎
                                        https://terrain.party/ un peu nuageux par endroits il est vrai! 😄
                                        https://i.postimg.cc/fb2dYQ4F/boli.png
                                        nCad_cfg01.zip
                                          J'écoute ceci pendant mes translations nanocadiennes! 💚
                                          ça va sûrement me tenir éveillé! ☀
                                          Bon en fois 2 ...histoire d'en entendre deux fois plus! 💚
                                            Bon encore un mystère : cette barre d'Outils est déjà traduite à l'écran en tant que barre d'outils "flottante" et dans le menu lui-même aussi...à part son titre bien sûr pusiqu'il semble que ce soit ce que je traduis plus Bas! 😄
                                            Vérifiez : assez jolies d'ailleurs les Barres d'Outils Flottantes! ☀
                                            Dans les précédentes sections des menus
                                            la structure était plutôt de ce style dont il semblait ne devoir traduire que le "name"
                                            l'"intername" semblant servir de "variable" (?) mnémoniques (?)... (à vérifier)
                                            [\menu\file\Open]     |name=s&Ouvrir...     |intername=sOpenDocument
                                            Bref je ne traduisais que le "name"
                                            mais là zou plus d'"intername" ??? Bizarre, je fais l'impasse sur les "Intername" jusqu'à plus ample informé! IL sera toujours temps d'y revenir!
                                            [\toolbars\Edit]                                |name=sBarre d'Outils Editer
                                            [\toolbars\Edit\Cut]                                  |intername=sCut
                                            [\toolbars\Edit\Copy]                                 |intername=sCopy
                                            [\toolbars\Edit\Paste]                                |intername=sPaste
                                            [\toolbars\Edit\CopyProp]                             |intername=sCopyObjectProps
                                            [\toolbars\Edit\Delete]                               |intername=sDelete
                                            • 11
                                            • 12
                                            • 16
                                            • 17
                                            • 10 / 17
