    Corrupt file can no longer open with bugsplats.
    3 Posts 2 Posters 980 Views 2 Watching
      coasterinc
      So i was working in a file that iv been in for a few days, basically optimzing components for unreal import, then while moving something around, i get the "fix model" promt, i say yes and i get a bugsplat, now when i try to load the file it instantly bugsplats, i tried imported into a clean file, bugsplat, i tried opening on a newer version of sketchup and i get the "corrupt beyond repair" promt...
      i dont have backups or autosaves turned on as i sometimes work in a file thats over 1gb and is shared via sync software that doesnt transfer quick enough at times and its just easier not to have it on...
      does anyone have any idea on what i can do?? its a lot of work to lose
        From what you describe, it may be too late to fix it and since you haven't been making backups, I doubt there's much you can do. It's probably a long shot but some users have had crashes on startup that were caused by bad graphics drivers. What is your graphics card? Update the drivers to the most current version. At least you've nothing to use. Are you still using SketchUp 8 as indicated by your profile?
          coasterinc
          no 2018, pretty poor that sketchups own "fix model" is what broke the file to a point where its completely gone... plus a driver update is as good of an answer and switching it off and on again, its the file not the computer thats the problem.
          broken file
