    [Plugin][$] Curvizard - v2.5a - 01 Apr 24
    198 Posts 58 Posters 378.8k Views 57 Watching
    • fredo6F
      NEW RELEASE: Curvizard v2.1c - 03 Jul 18
      Curvizard 2.1c is a maintenance release fixing a small bug signaled by Box.
      Requirement: LibFredo6 8.1 or above
      See main post of this thread for Download of Curvizard.
      • fredo6F
        NEW RELEASE: Curvizard v2.2a - 23 Nov 18
        Requirement: LibFredo6 8.6m or above
        Curvizard 2.2a introduces new toolbar icons designed by JClements. They are provided in Vector mode (SVG, PDF) and Raster mode (PNG), and thus should scale for hi-res screens on SketchUp versions >= SU2016 (and all versions on Mac)
        See Plugin Page of Curvizard for Download.
        See main post of this thread for discussion on Curvizard.
          rv1974
          Since there's a little hope to see this as core function, I wish we had a commercialFredoSplines with following interactivefeatures:
          1. handles for shape editing
          2. 3 types of control points: smooth\corner\bezier
          3. interactive refinement (=segmentation) control
          4. Important for arch modelling: total slope (in %%) AND (optionaly) total height input
          • pbacotP
            That can be very useful at times. Thanks!
            • fredo6F
              NEW RELEASE: Curvizard v2.4a - 24 Feb 19
              Curvizard 2.4a offers 2 new tools[/b][/color] in order to reconstruct Polygons, Arc or Circle from a sequence of edges, when this is possible.
              Requirement: LibFredo6 8.8a or above
              See Home Page of Curvizard for information and Download.
              See Main post of this Curvizard thread for discussion, bug reports and suggestions.
              • designerbursaD
                designerbursa
                "Convert Guides to Edges" Are you considering adding ?
                • designerbursaD
                  designerbursa
                  "Convert to Arc / Circle"
                  thank you fredo6
                  • fredo6F
                    This would be different!
                    Anyway, there are already several plugins doing that, like TIG xLine2Line.
                    • uwesketchU
                      uwesketch
                      New feature "Convert to Arc/Circle":
                      Great, thanks a lot Fredo.
                      • Is it correct, that when using "Make curves", that now the curve is converted automatically to an arc as well?
                      • Now I can finally convert the corner edges generated by FredoCorner (using circle rounding) back to arcs, if desired. This then allows adding radius measurements in Sketchup and Layout! 😄
                      • Any chance that this feature is added as an option to FredoCorner for the generation of the corner edges when rounding using circles?
                      • fredo6F
                        Correct. I may introduce an option to disable this behavior however.
                        I understand that you ask for creating curves, possibly arcs when applicable.
                        I assume that only the rounding edges on rounded borders are to be converted to curves.
                        • B
                          bharralure
                          Merci beaucoup Fredo
                          Un outil qui va remplacer avantageusement (parce que beaucoup plus complet) "niline2arc" de Nobnob qui, malgré tout et sans mise à jour depuis 6 ans, fonctionne toujours.
                          Les améliorations que j'apprécie:
                          • sélection multiple, y compris avec les faces
                          • ne pas être obligé d'entrer à l'intérieur des groupes et composants
                          • l'outil reconnait les cercle ou arc même si l'option "convertir en courbe" à été choisie
                          peut être est t'il possible de découvrir d'autres astuces ...
                          • uwesketchU
                            uwesketch
                            Since an arc or n-gon (polygon) is as well a curve, it is not wrong to always convert to an arc or polygon, if it is an arc or polygon. I do not see any disadvantage for this.
                            Yes, only the corner edges, not as well the inner edges or borders.
                            To clarify I marked in below picture the edges.
                            blue marked corner edges to convert to arc
                            • fredo6F
                              [attachment=0:1u9dg31q]<!-- ia0 -->CornerEdges_to_Curves.png<!-- ia0 -->[/attachment:1u9dg31q]
                              Conversion to curve is probably possible.
                              But be aware that in most cases, this won't be an arc of circle, even if you chose a Circular profile, except in the special cases where the corner is purely made of orthogonal faces.
                              • uwesketchU
                                uwesketch
                                Looking already forward to it.
                                Agree, it will not be in all cases an arc. But it is enough, if the edge to be rounded is perpendicular to the face at the end of the edge.
                                  Trivial question but...when something is Converted to guides lines with Curvizard
                                  How to make the inverse ? 😮
                                  TIG xLine2line makes that but you must edit the Group generated above and the little black crosses are always living ! 😲
                                  So Curvizard don't make this trivial thing ? (i miss maybe something too 😄
                                  • fredo6F
                                    Curvizard could do it, but it is supposed to work on true edges.
                                    So that's why the function 'convert Construction Lines to Edges' should live in another plugin. I did not do it because there was some existing, but it is not too complex.
                                      Will be fine and more speedy than research the good plugin, enter the Group, click the lines, kill the cross points, explode the group etc... 😄
                                      • BoxB
                                        Hi Fredo,
                                        I think this has happened since the latest update to libfredo.
                                        If I remember correctly Smooth, Simplify etc previously left the edges welded but now explode the curve. Unless I'm missing an autoweld setting.
                                        • fredo6F
                                          I can reproduce it. Strange. I am looking into the issue and will come back.
                                          • fredo6F
                                            Problem of Sketchup curves not constructed fixed with LibFredo6 v9.5d.
                                            • 9 / 10
