    Export to DWG 2018 - Student version
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    7 Posts 3 Posters 12.2k Views 3 Watching
      JGA
      When I export from layout 2019 to the DWG 2018 file format, AutoCAD reports it as a student version.
      A student version of DWG will print a watermark onto all AutoCAD drawings.
      Export settings
      Message within AutoCAD when trying to open exported DWG file
      This issue doesn't appear when exporting to DWG r14 version
      Regards,
      JGA
        Not a LayOut bug. It was explained here
          JGA
          Thanks for replying on this & the SketchUP forums.
          I reckon it is a bug, as the Student Version watermark isn't created from Layout with other versions of DWG.
          The watermark is like a virus, and "infects" any drawing that the student version DWG is inserted into.
          We had a problem a number of years ago with a new start using presentation DWG blocks in production drawings that he created, while a student.
          All looked fine till we started printing - when it looks like our business was using student copies of AutoCAD for business use.
          Regards,
          JGA
            From what Trent has said in that post and elsewhere, if this is a bug, it is affecting more than just LayOut. Many other applications apparently have the same "bug".
            • pbacotP Offline
              Interesting. So SketchUp changed and now ACAD tags files to embarrass the SU user. So why can't SketchUp change back?
                JGA
                @pbacot said:
                So SketchUp changed and now ACAD tags files...
                It's not aimed at SketchUP users in particular, it's people using the "free" student version of AutoCAD in a business environment.
                There was a spell that Autodesk didn't use the watermark, but they are back with the 2019 version of AutoCAD.
                Regards,
                JGA
                • pbacotP Offline
                  Well it seems to be targeting anyone making dwg files in some non-AutoDesk software.
                  OH I thought it was caused by later SU versions. In the explanation someone said "save it as 2013".
                  They mean save it as ACAD 2013 dwg, I guess, which is a good precaution. Otherwise your consultants will believe you are using a student version of AutoCAD.
