    Medeek Electrical
    206 Posts 6 Posters 288.1k Views 5 Watching
    • medeekM
      medeek
      What do we want these electrical symbols to look like?
      Simple lines or filled in faces?
      Any input would be greatly appreciated.
      Size of symbols?
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Here is a first look at the switch symbols, I've shown them drawn at 4.5" in height but I've set it up so that the symbol height can be determined by the user in the global settings and everything (symbol spacing etc...) should scale appropriately.
        http://design.medeek.com/resources/images/electrical_su2_800.jpg
        Also note that the symbols are with the switch group so when you move the switch in the wall the symbols move with the switch.
        The symbols are also placed on the electrical_2d_layer by default (again user definable in the global settings) so they can easily be toggled on or off.
        design.medeek.com
        • medeekM
          medeek
          I'll probably need to add a few more icons in the toolbar. Off the top of my head I'm thinking about:
          1.) Service Panels: These are typically 14.5" in width and fit nicely between 16" on center studs
          2.) Exterior Service and Meter
          3.) Additional Faceplates/Media Outlets: CAT5/6, Coax, Telephone, etc...
          Another can of worms would be light fixtures. I'm not quite sure I'm ready to jump into that one just yet. There are so many variations on light fixtures that I would certainly need to make it so the user can create their own light fixture components that then can be used by the plugin.
          Hit me up with any suggestions while my focus is on this plugin. In about a week I'm back onto the Wall Plugin and its massive todo list.
          design.medeek.com
          • medeekM
            medeek
            As can be seen in the image below a gang of switches can all be different types:
            http://design.medeek.com/resources/images/electrical_su3_800.jpg
            In the image below I've turned on the "Labels" for the switch boxes. The Switch (box) name can be edited in the switch edit menu for each switch:
            http://design.medeek.com/resources/images/electrical_su4_800.jpg
            With weatherproof switches I will need to have a different faceplate but for now it will default to the generic toggle switch.
            Tomorrow I will spend a few minutes and model up a low poly version of the Leviton Decora switch and outlet series and then we will have at least two options for switch and outlet styles.
            Similar to the Wall Plugin the labels are assigned by default to the Dim3 layer and can be toggled separately from the symbols, or be turned off completely in the global settings.
            design.medeek.com
            • jujuJ
              juju
              Please tell me that you're scripting this so we can pre-assign layers to the 3D components (separately per type, if possible) and the 2D part thereof on another single layer.
              Crazy idea, I know...
              • medeekM
                medeek
                I'm basically using four layers right now:
                1.) electrical_rough (electric boxes)
                2.) electrical_finish (faceplates, outlets, switches)
                3.) electrical_2d (symbols and annotations)
                4.) electrical_dim3 (for the box labels)
                design.medeek.com
                • medeekM
                  medeek
                  I'm not an electrician so bear with me, I'll probably get a few things wrong initially.
                  When you gang together switches you typically see the symbols ganged together as well. However with outlets is the same symbology used or do you just put a subscript next to the outlet symbol indicating the number of outlets and just show one outlet symbol?
                  design.medeek.com
                  • medeekM
                    medeek
                    After reviewing a few more electrical plans online it looks like the convention is to show the ganged outlets similar to ganged switches.
                    I've added Decora switches (and outlets) as well as the option for a simple blank face plate, which I am labeling as a junction (box):
                    http://design.medeek.com/resources/images/electrical_su5_800.jpg
                    For junction boxes or blank face plates I am following the same convention as I am for outlets and switches and showing a symbol for each location.
                    I will eventually add another icon in the toolbar for Combo Outlets (ie. switch, blank, outlet combinations), however I probably won't get to this until later.
                    design.medeek.com
                    • medeekM
                      medeek
                      First look at some outlets with switches:
                      http://design.medeek.com/resources/images/electrical_su6_800.jpg
                      I now need to look at all of the various outlet types and add in those annotations.
                      design.medeek.com
                      • medeekM
                        medeek
                        Here are all of the various outlet/receptacle options currently available:
                        http://design.medeek.com/resources/images/electrical_su7_800.jpg
                        I still need to put some logic in for the single, weatherproof and GFCI receptacles so that they display the proper outlet and corresponding face plate.
                        design.medeek.com
                        • medeekM
                          medeek
                          I don't see single receptacles very often but I guess there is some call for them:
                          301 Moved Permanently
                          (www.leviton.com)
                          design.medeek.com
                          • pbacotP
                            We are required to use a weather proof outlet that covers the plugs while in use. Perhaps a duplex a simple (minus curves) transparent lid should be provided. There are also gang boxes, some non transparent lids, but the first is most common.
                            Maybe you wish to go over the whole GFI thing with an electrician. I have my knowledge, but I'm not an electrician so I'll keep it to myself.
                            • medeekM
                              medeek
                              I have a 1-gang GFCI as well as a two gang GFCI-Duplex and GFCI-Decora combo. What other combinations of GFCI/Outlets are common? (I will handle the GFCI/switch combo later)
                              The possible permutations are crazy so I am trying to limit things slightly for certain outlet types, I think this makes the most sense. Just trying to rein in the madness.
                              For instance I have never seen multiple GFCI outlets ganged up in a single box, only ever one with another switch or regular duplex/decora receptacles.
                              Also what type of weather proof outlet would you prefer I include as the default? I'm looking at Leviton's offerings and also at Taymac, too bad I can't seem to find readily made models for any of these. Oh well, I would probably have to remodel them anyways because the poly count would probably be obnoxious.
                              After digging through Leviton's website straight for the last 3-4 days I now know more about switches and receptacles than I care to really, but it certainly is an education. I'm still amazed at all of the possible combinations of switches and outlets that are possible and how the manufacturers do their best to provide as complete coverage as possible, there are literally hundreds of face plates (configurations).
                              design.medeek.com
                              • medeekM
                                medeek
                                Does anyone have a model of a weather proof outlet (with transparent lid) that I could use as a starting point.
                                The most up-to-date covers (NEC 2014) seems to be the Taymac MM420C and the MM2420C:
                                (www.hubbell.com)
                                (www.hubbell.com)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  It looks like I will need to add in one additional option, Weather Proof GFCI. It seems that this combination is fairly popular:
                                  http://design.medeek.com/resources/images/electrical_su8_800.jpg
                                  My weatherproof cover is based on the Taymac MM420C, probably a little more detail than it needs but I wanted it to look somewhat recognizable.
                                  I also have the Decora option and the standard duplex option.
                                  design.medeek.com
                                  • pbacotP
                                    Nice!
                                    • medeekM
                                      medeek
                                      Has anyone ever called out duplex receptacles with the integrated USB chargers?
                                      https://www.leviton.com/en/images/lc/T5632_W_5.jpg
                                      (www.leviton.com)
                                      I'm assuming the callout would just be a standard duplex symbol with the annotation "USB" added.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        These type of outlets have a small parasitic load (50 mW), but I think many people are willing to accept that loss for the convenience. My worry would be that the device fails down the road and then I need to replace it. Its one thing tossing an old adapter in the bin, its entirely different when I need to pull out the tool bag and start re-terminating receptacles, or worrying that one of these things is really going to go bad and possibly create a fire hazard.
                                        It’s not a big deal to provide a USB model of your standard USB Decora duplex receptacle, I’ll just base it on the T5632 (Leviton) and if people want something different they can replace the default model in the library that I provide.
                                        As I was eating outing this evening with the wife I noticed along the bar a line of outlets (and even a couple switches) that were mounted horizontally rather than vertical. I will need to add in the first of the advanced options which allows the user to toggle between a vertical or horizontal mount, obviously vertical will be the default.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Added the advanced option which will allow for a horizontal mount of any receptacle:
                                          http://design.medeek.com/resources/images/electrical_su9_800.jpg
                                          First look at the the following: GFCI, USB, Simplex, Horizontally mounted Duplex
                                          http://design.medeek.com/resources/images/electrical_su10_800.jpg
                                          I will also extend this same functionality to the switch module so that they can be mounted in any orientation.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Option for weatherproof GFCI added:
                                            http://design.medeek.com/resources/images/electrical_su11_800.jpg
                                            I haven't gotten every combination but I think I now have about 85% of the most commonly used configurations added in for outlets. I will now return to the switch module and work that over for a while until it is also about 85-90% coverage.
                                            I also still need to add in a completely new style: 240V
                                            This will comprise single gang outlets for clothes dryers, welders, and ranges.
                                            design.medeek.com
                                            • 11
                                            • 1 / 11
