    [REQ] Export selected groups/comps to separate skp files
    14 Posts 6 Posters 2.8k Views 6 Watching
    • N Offline
      numerobis
      Is there a plugin that lets you select one or more groups or components and export them separately as skp to a specific directory? I have found export plugins for other formats, but no skp.
      I'm still searching for a good solution to "link" skp files to 3ds max. There is this import link manager for max that could work quite well for me...
      http://www.mirarkitektur.com/mirzasoftwares/?menu=presentationProduit&product=Mirza%20Link%20Manager
      I could import the whole model, but this can take some time for bigger files, so i think splitting up the model in several parts would be helpful. If i modify the model only the changed parts need to be updated.
      So my question is, if someone could set up an export routine where you can export (and overwrite on update) only selected parts to a folder.
      The best thing would be if it would be possible to specify an export folder that is defined in the project (is it possible to store such attributes?) and export/update the selected groups or components with their definition names with click on a button or an entry in the right click menu.
      (A more advanced option could be a link manager like "Cross Reference Organizer" (https://extensions.sketchup.com/en/content/cross-reference-organizer) where all parts would be listed and could be refreshed)
        rv1974
        Hide unwanted, save file and open it in Max. Max skips hidden geometry
          rv1974
          link aux max files (containing skp geometry) in centralized (host) max file.
          • N Offline
            numerobis
            Thanks for the suggestion, but i need separate files to link them in max. If i link the same file several times with different hidden parts the imported geo will be overwritten.
            And if i have to hide parts first and then save the file i can also select the modified groups one by one and export them via right click menu, as i do it now. I was searching for a more automated solution for bigger models, where i would split the model in more parts to make it faster to update in max.
            • srxS Offline
              srx
              You have the option from Component browser/In model Components - Save to local colection which saves all components from the model to SU components library
              www.saurus.rs
                rv1974
                It doesn't preserve location
                  The attached code should do something like you want...
                  Note the following:
                  You must have saved the model before running this.
                  You must have at least a group and/or a component-instance preselected before running this.
                  Individual groups are exported using their given-name, or if unnamed as 'Group#N' where N is the count.
                  Individual instances are exported using their definition-name, with a '#N' count suffix added if there's more than one instance of that definition.
                  These exported SKPs are put into the same folder as the model itself.
                  It reports the files it has exported as it goes.
                  The exported file's thumbnails should be accurate.
                  It removes any backup files made during the process, and on completion it reverts to the original model's contents.
                  All temporary deletions etc are 'aborted', so that although the exported files get made successfully, the original model should remain unchanged.
                  To use the code simply copy all of it and paste it into the Ruby Console and press <enter>.
                  Note the preselection requirement !
                  If it works as you hope, then I can make it into a RB file, with a menu item etc for you...
                  mo=Sketchup.active_model
                  pa=mo.path
                  if pa.empty?
                    UI.messagebox("Save 'Untitled' Model Before Exporting...")
                  else
                    d=File.dirname(pa).tr("\\", "/")
                    es=mo.active_entities.to_a
                    ss=mo.selection.to_a
                    mo.selection.clear
                    gs=ss.grep(Sketchup;;Group)
                    gis=gs.collect{|e| e.persistent_id }
                    is=ss.grep(Sketchup;;ComponentInstance)
                    iis=is.collect{|e| e.persistent_id }
                    unless gis[0] || iis[0]
                      UI.messagebox("Select Groups and/or Instances Before Exporting...")
                    else
                      gis.each_with_index{|ii, i|
                        e=nil
                        mo.active_entities.to_a.each{|ee|
                          if ee.persistent_id==ii
                            e=ee
                            break
                        next unless e
                        mo.start_operation("Export_group#{i}",true)
                        n=e.name
                        n="Group##{i+1}" if n.empty?
                        p f=File.join(d, n+".skp")
                        xs=es=mo.active_entities.to_a-[e]
                        xs.each{|x|
                          x.erase! if x.valid?
                        mo.save(f)
                        if File.exist?(File.join(d, n+".skb")) #PC
                          File.delete(File.join(d, n+".skb"))
                        if File.exist?(File.join(d, n+"~.skp")) #MAC
                          File.delete(File.join(d, n+"~.skp"))
                        mo.abort_operation #revert model
                      iis.each_with_index{|ii, i|
                        e=nil
                            e=ee
                            break
                        next unless e
                        mo.start_operation("Export_instance#{i}",true)
                        n=e.definition.name
                        n="#{n}##{i+1}" if e.definition.instances[1]
                        xs.each{|x|
                        mo.save(f)
                        mo.abort_operation # revert model
                      mo.save(pa) # revert back to orignal model
                  puts "Done."
                  M 1 Reply Last reply Reply Quote 0
                  • N Offline
                    numerobis
                    Thank you very much TIG! But i'm getting an error message...
                    Error; #<NoMethodError; undefined method `persistent_id' for #<Sketchup;;ComponentInstance;0x0000002558bb80>>
                    <main>;12;in `block in <main>'
                    <main>;12;in `collect'
                    <main>;12;in `<main>'
                    SketchUp;1;in `eval'
                    I tried with components and groups.
                    • N Offline
                      numerobis
                      @srx This saves ALL components of a model.
                        I just noticed that the SketchUp version you have is <2016.
                        Therefore "Persistent IDs" cannot be used - these are needed to circumvent the lost IDs during newer SketchUp processes...
                        Try this alternative [which will fail with >=2016 ! but should still work in older versions ?? ]
                        pa=mo.path
                        if pa.empty?
                        else
                          mo.selection.clear
                          gis=gs.collect{|e| e.guid }
                          iis=is.collect{|e| e.guid }
                          else
                              e=nil
                                if ee.guid==ii
                                  e=ee
                                  break
                              next unless e
                              n=e.name
                              xs.each{|x|
                              mo.save(f)
                              e=nil
                                if ee.guid==ii
                                  e=ee
                                  break
                              next unless e
                              n=e.definition.name
                              xs.each{|x|
                              mo.save(f)
                        puts "Done."
                        • N Offline
                          numerobis
                          Oh sorry, i wasn't aware of that.
                          Thanks for the update. It's working great now! Very cool. 😄
                          Could you put it into the right click menu to the other export options?
                          Btw. is it possible to configure the right click menu? The list is getting very long and there are some entries that i never use. I somehow remember that this wasn't possible and you had to change it in the plugin code. If this is the case, is there a single command that can be commented out to deactivate it without generating problems or is it more complex?
                            MartinGr @TIG
                            @TIG Error: #<SyntaxError: <main>:4: syntax error, unexpected else' <main>:15: syntax error, unexpected else'
                            else
                            <main>:23: syntax error, unexpected '}', expecting end-of-input
                            SketchUp:in `eval'
                            It keeps showing this error in su 2021
                            TIGT 1 Reply Last reply Reply Quote 0
                              TIG Moderator @MartinGr
                              @MartinGr
                              I can't see where that error is arising.
                              Unfortunately any old 'ruby' formatted text is FUBAR on the new forum - Gábor is working on a fix:
                              Here's a rewritten version that works for me...
                              pa=mo.path
                              if pa.empty?
                              else
                                mo.selection.clear
                                gs=ss.grep(Sketchup::Group)
                                is=ss.grep(Sketchup::ComponentInstance)
                                unless(gis[0] || iis[0])
                                else
                                    e=nil
                                        e=ee
                                        break
                                    next unless e
                                    n=e.name
                                    xs.each{|x|
                                    mo.save(f)
                                    e=nil
                                        e=ee
                                        break
                                    next unless e
                                    n=e.definition.name
                                    xs.each{|x|
                                    mo.save(f)
                                  mo.save(pa) # revert back to original model
                              puts "Done."
                              Didier BurD 1 Reply Last reply Reply Quote 0
                              • Didier BurD Offline
                                Didier Bur @TIG
                                @MartinGr :
                                This one will perhaps be useful to you:
                                [https://sketchucation.com/plugin/2667-componentsplus]
                                Regards,
                                DB
