    3D Truss Models
    1.5k Posts 31 Posters 944.1k Views 30 Watching
    • medeekM Offline
      medeek
      I'm a little burned out right now with the addition of all these extra tools to the Medeek Tools toolbar, but I still feel like I need to add one final addition to the mix.
      This one will be called the split tool and similar to the trim tool the user will select a single face (or three points, toggle with the control key?) to define a plane which will then be used to cut a solid group or component in two.
      The slightly tricky part with this is to make sure that the copied group/component is nested in the same overall group(s) as the original and retains all of its properties.
      This tool would be useful where you've used the followme tool to create some geometry but want to break the resulting solid into separate segments (groups).
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
        Seems a very colol "knife"! 😎
        • medeekM Offline
          medeek
          Version 2.2.6b - 12.18.2018
          • Added the Split icon to the Medeek Tools toolbar.
          • Added the Split function for (solid) groups and components: split plane via one face or three points.
          http://design.medeek.com/resources/images/tools_su_menu_active.jpg
          When you first click on the tool it defaults to the user selecting a face for the cutting plane however if you hit the "CTRL" key in Windows it will toggle to the three point mode.
          Tutorial 13 - Split Tool:
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.2.6c - 12.18.2018
            • Addressed a bug in the Split function regarding nested groups and components.
            This is a critical fix for this tool. I strongly suggest that everyone upgrade from 2.2.6b to 2.2.6c.
            Let me know if there are any other tools that might come in handy with manipulating an architectural model. I think the six tools now available can cover most tasks but I'm sure I'm missing something.
            design.medeek.com
            • medeekM Offline
              medeek
              There has been some call for a tool that is similar to the split tool but rather than selecting just one face you would select two faces and a section could be removed from the solid object (imagine two infinite planes cutting a slice out of your solid object). I'm not exactly sure what to call this possible tool (section cut?).
              The other question is whether to have the tool break the solid into two separate groups or components like the split tool or just leave the resulting geometry as one group/component? I suppose I could always enable an option that would allow the user to toggle between these to behaviors offering some flexibility to the user.
              Similar to the split tool I could allow the user to define the cutting planes but either selecting two faces or selecting six points, or a combination of three points and a face or a face and three points. Lots of permutations here... just makes the code a little more fun.
              With regards to the cutting planes, they could be parallel or they might not be, it doesn't really matter. Just as I am doing in the split tool I will need to include logic that checks to see that the cutting planes actually do intersect the solids otherwise no action will be performed. The two cutting planes cannot be perpendicular to each otherwise a valid solution cannot be obtained, or at least that is what I initially thought. I will need to give that possible solution some more thought. If a solution can be obtained there is no reason to discard it. There may be some overlap with the Trim 2 function, but that tool does not have the ability to separate the solid into different groups.
              Any thoughts or suggestions with regard to this potential addition to the tools?
              Also just a reminder that even though I am including these tools within the Truss plugin they are designed to work with any solid geometry created in SketchUp, it doesn't need to be plugin related geometry.designed to work with any solid geometry created in SketchUp, it doesn't need to be plugin related geometry.
              design.medeek.com
              • medeekM Offline
                medeek
                I've been thinking about labels for truss and rafter roofs and I would like to add in some sort of labeling system like the Wall plugin.
                With a typical gable roof I will have a label on each side of the roof aligned with the roof plane but offset vertically so it does not Z fight with the sheathing or cladding (shingles). The label will be similar to the Wall plugin where the user can customize the prefix (eg Roof1, Truss1, Rafter1 etc...)
                Each side will be designated a letter, so Roof1-A and Roof1-B. Hip roofs will have four roof planes so A, B, C and D.
                If the framing callout is enabled then beneath the label will show the area for that roof plane (sheathing):
                http://design.medeek.com/resources/images/wall_su322_800.jpg
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.2.7 - 12.27.2018
                  • Roof and Floor labels option added to the General tab of the Global Settings.
                  • Roof and Floor label prefixes can be customized in the General tab of the Global Settings.
                  • Roof labels enabled for common trusses.
                  • When framing callouts are enabled the area of each roof plane will be shown below the roof label (currently only common truss assemblies have this feature available).
                  • Added a customizable color for roof and floor labels within the Material tab of the Global Settings.
                  • Added additional layers for dimensions, annotations, 2d geometry, building code and engineering.
                  http://design.medeek.com/resources/images/truss_su368_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.2.7b - 12.29.2018
                    • Enabled roof labels and framing callouts for monopitch truss assemblies.
                    • Added stats (roof sheathing) for common and monopitch truss roofs which can be analyzed within the Medeek Estimator (Wall Extension) module.
                    In order to use this new feature you must also have the Wall plugin installed and upgraded to Version 0.9.9v, See Wall plugin thread for further details.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 2.2.7c - 12.30.2018
                      • Enabled roof labels and framing callouts for all rafter roof assemblies: Gable, Hip, Dutch Gable, TJI, TJI w/ Glulam, Shed etc...
                      http://design.medeek.com/resources/images/truss_su369_800.jpg
                      http://design.medeek.com/resources/images/truss_su370_800.jpg
                      http://design.medeek.com/resources/images/truss_su371_800.jpg
                      http://design.medeek.com/resources/images/truss_su372_800.jpg
                      I've also been thinking about how to best handle holes or cutouts in the roof sheathing and cladding that are not only parametric but can be properly reported by the estimator (ie. net area vs. gross area). I think I have a system worked out, I just need to implement the prototype and test it out.
                      The cut out or hole tool will have a few options. One of the options will allow the user to specify whether to cut the cladding, sheathing or framing or all of them. If the framing is cut then another option for framing in the opening.
                      I may also provide another option to provide a skylight to cover an opening or other construction elements (eg. vents, whirlybirds etc...)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Another basic piece of information of any roof is the pitch or angle in degrees for the metric side of the house. I'm updating the framing callout for roofs to also include this information:
                        http://design.medeek.com/resources/images/truss_su373_800.jpg
                        http://design.medeek.com/resources/images/truss_su374_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 2.2.7d - 01.04.2019
                          • All roof framing callouts now include the roof pitch or angle in degrees (metric templates).
                          • Added additional stats: (ridge cap, drip edge) for common and (drip edge) for monopitch truss roofs which can be analyzed within the Medeek Estimator (Wall Extension) module.
                          http://design.medeek.com/resources/images/truss_su375_800.jpg
                          The new stats will become available with the next release of the Wall plugin.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.2.8 - 01.06.2019
                            • License expiration date now appears in the License tab of the Global Settings when plugin is registered.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.2.8b - 01.18.2019
                              • Fixed a bug in the license and registration module.
                              I've noticed an issue with some licenses created in 2016. If you purchased a license before Jan. 2017 and the plugin is still showing as "TRIAL" version, even when the serial number is input properly into the License tab of the global settings, please contact me and I will re-issue you a corrected serial number as well as upgrade your expiration date by six months for any inconvenience this may have caused you.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.2.9 - 02.25.2019
                                • Fixed a bug in the display of the toolbars (Mac and Windows).
                                • Enabled custom materials for wall sheathing, wall cladding, roof sheathing and roof cladding in the HTML advanced options draw menu for attic trusses. This update also resolved an associated bug in the global settings for attic trusses.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.3.0 - 03.01.2019
                                  • Fixed one bug and a number of minor issues with monopitch trusses.
                                  • Enabled sheathing and cladding at the heel of raised heel common and monopitch trusses.
                                  • Added metal plates for raised heel monopitch trusses: wedge, slider, vertical w/ strut.
                                  http://design.medeek.com/resources/images/truss_su377_800.jpg
                                  If you are using monopitch trusses at all then this is a critical upate. Previously my algorithm for the bottom chord of the monopitch truss was not properly assigning the material and layer when the raised heel option was enabled for this truss type.
                                  Strangely that issue has been in existence since 2016 and no one seems to have noticed or at least notified me of it. While working on the cladding of raised heel variants the issue jumped out at me and now it is finally resolved.
                                  The thing about this plugin is that there are so many design permutations possible that it is almost impossible for me to investigate every single one and check for these type of minor issues. That is why I rely heavily upon user feedback to help put out some of these fires.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Related links to the Truss Plugin:
                                    Main Web Page:
                                    Medeek Design Inc. - Medeek Truss
                                    (design.medeek.com)
                                    Changlog:
                                    http://design.medeek.com/resources/pluginchangelog.html
                                    Registered User Map:
                                    404 - File or directory not found.
                                    (design.medeek.com)
                                    Vendor Products:
                                    Medeek Design Inc. - Medeek Truss Plugin Vendors
                                    (design.medeek.com)
                                    Truss Calculator (Common Fink Truss Only):
                                    Medeek Truss Designer
                                    (design.medeek.com)
                                    Snow, Seismic and Winds Loads and other resources:
                                    Medeek Design Inc. - Resources
                                    (design.medeek.com)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.3.1 - 03.15.2019
                                      • Fixed a bug with the wall cladding material parameter in the global settings.
                                      • Updated toolbar icons to be compatible with 4k (UHD) resolution monitors.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.3.2 - 04.15.2019
                                        • Enabled the "Edit Truss Assembly" function for all scissor trusses (imperial and metric units).
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.3.3 - 04.17.2019
                                          • Enabled the "Edit Truss Assembly" function for attic trusses (imperial units only).
                                          • Improved formatting of all HTML edit menus: Common, Monopitch, Scissor, Attic.
                                          http://design.medeek.com/resources/images/truss_su378_800.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            When I originally enable hurricane (uplift) ties for the trusses I failed to check to see how things looked with a raised heel when the H2.5A (simpson) tie was used.
                                            In this particular case the tie needs to be flipped around so that it is facing towards the interior rather than the exterior. I've made the correction and added the logic into the code. I will release the fix with the next version:
                                            http://design.medeek.com/resources/images/truss_su379_800.jpg
                                            design.medeek.com
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 75
                                            • 76
                                            • 46 / 76
