    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • fredo6F Offline
      NEW RELEASE: LibFredo6 v8.6i - 21 Oct 18
      LibFredo6 8.6i is for bug fixing and FredoTools 3.3a.
        thj14
        I have problems with all fredo6 plugins
        Have Sketchup 18 pro, uses sketchup extension manager to install
        all plugins are updated and are in the same directory.
        When I press an icon, it does not respond. Do not get menu and no selections around the object.
        Someone who can help me.
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v8.6j - 30 Oct 18
          LibFredo6 8.6j is for bug fixing and small GUI adjustments (size of toolbar icons for high-DPI screens).
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v8.6k - 03 Nov 18
            LibFredo6 8.6k provides new instructions for downloading FFmeg on Mac-OS platforms.
            IMPORTANT: the previous documentations included a link that is no longer supported and, worse, may have been hacked. So if you use Animator, please use the new link,
            https://www.ffmpeg.org/download.html
            Attached are the new PDF instructions
            Instructions_ffmpeg_Mac.pdf
            • Seatales45S Offline
              Seatales45
              How does one update LibFredo6? Do I have to delete and reinstall?
              • fredo6F Offline
                NEW RELEASE: LibFredo6 v8.6m - 18 Nov 18
                LibFredo6 8.6m is for Animator 2.3c (transparent background) and for the size of icons on hi-res screens.
                • fredo6F Offline
                  NEW RELEASE: LibFredo6 v8.6n - 05 Dec 18
                  LibFredo6 8.6n fixes occasional problems in Orbiting, in FredoTools::ThruPaint and possibly in some others of my plugins.
                  • fredo6F Offline
                    NEW RELEASE: LibFredo6 v8.6p - 05 Dec 18
                    LibFredo6 8.6p fixes a random bug in Animator when using Movement Along Path.
                    • fredo6F Offline
                      NEW RELEASE: LibFredo6 v8.7a - 18 Dec 18
                      LibFredo6 8.7a is a maintenance release providing adjustments to several of my plugins.
                      • OxerO Offline
                        Oxer
                        Hi Fredo,
                        I installed the last version of LibFredo v8.7a, there is an issue, I can't access to your plugins through the icons, it appears the options window and it disappears immediately. When I access through plugins Menu or Contextual Menu they work.
                        When the tool (ex. JointPushPull) is running and I push the Tool Settings icon it happens the same, the settings window appears and it disappears immediately.
                        macOS 10.13.6 & SU2017
                        • fredo6F Offline
                          @oxer said:
                          Hi Fredo,
                          Can you open the Ruby Console.
                          • fredo6F Offline
                            Do you have the problem with the button palette of my plugins (like JointPushPull or FredoCorner) or is it just for the dialog boxes?
                            • OxerO Offline
                              Oxer
                              Nothing in Ruby Console. 😲
                              I open for example Window Menu> LibFredo Options> Check Updates for Plugins and the window appears but it closes immediately.
                              EDIT: After that I can use another Skechup Tools but if I press Cmd+Q (exit SU on Mac) SketchUp doesn't close, I have to force the exit.
                              • OxerO Offline
                                Oxer
                                It's with the dialogs (popup windows) only, the palletes works fine.
                                How I said you before to access to yours plugins I can do this through the Tool & Extensions Menu or Contextual Menu only.
                                • fredo6F Offline
                                  Is it for all popup dialog boxes ?
                                  • pbacotP Offline
                                    I have loaded this plugin but my Fredo tools don't work. I get several prompts on opening SketchUp. According to the Plugin Manager I have the latest plugin.
                                    • fredo6F Offline
                                      Seems to be something quite old, because there is no longer a reference to LibFredo6 6.3 in the latest version of my plugins. Can you check for TopoShaper.
                                      Also, ff you run LibFredo6 8.7a, could you send me the trace file (Windows > Library Settings > Trace Log File...
                                      Another user has signaled me an anomaly with popup messages.
                                      • pbacotP Offline
                                        I choose "View Trace Log Files..." and nothing happens. Let me try updating. I know most plugins are recent updates, but some like TopoShaper may not be.
                                        • pbacotP Offline
                                          hmm... check for updates doesn't work either.
                                          • fredo6F Offline
                                            Same problem as Oxer. You are on Mac, and there seems to be a problem with Web dialog boxes.
                                            Since you have FredoTools installed, could you check if
                                            • the Quick Launcher works
                                            • if Solid Volume displays a dialog box
                                            • 104
                                            • 105
                                            • 106
                                            • 107
                                            • 108
                                            • 109
                                            • 110
                                            • 106 / 110
