π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Low lenticular dome
I have mastered the follow me tool for creating a dome but cannot make it work when creating a very low dome. Does any one have experience of this.
Well, I just made a pretty flat one with Follow Me and it worked fine.
How about providing more information about what you're doing. Upload the SKP file while you're at it so we can see exactly what you're working with.
Check your model scale. If the triangles being generated are too small, it could cause errors. Try scaling up and see if you still run into problems.
