    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 646.5k Views 71 Watching
    • G
      Garry K
      Please email me directly and we can set up a time to Skype and solve your problem.
      • G
        Garry K
        Cabmaker 3.0.130 is now available for download. CutMaster 3.0.1.78 is also available.
        You can now extend an overlay top and adjust the top gap.
        CutMaster now has additional drilling and grooving operations to facilitate drawer systems.
        • G
          Garry K
          CabMaker 3.0.131 and CutMaster 3.0.1.79 now available from my website.
          CabMaker
          1. Added Mitered Corners for Standard Cabinets.
          2. Added switch in Report Configuration so CabMaker parts report will produce 1 line per part instead of combining all like parts.
          CutMaster
          1. Added Reference from Drawer Box for configuring Drawer Fronts Hole Sets and Pilot holes.
          2. Fixed bug where spaces in Purpose breaks the configuration.
          • G
            Garry K
            CabMaker 3.0.132 and CutMaster 3.0.1.80 are now available from my website.
            1. Added Hinge positions for Tall, Mid and Standard doors. You can now have up to 5 hinges on a door. Please note that this information is sent over to CutMaster CNC for machining of the side panels and 1 piece doors.
            These CabMaker GIF's (from context help) give examples of what can be accomplished with hinge positions. The GIF's have a 2 second delay between frames.
            Box 1
            Box 2
            Box 3
            Box 4
            Box 5
            • N
              NBG
              Hello,
              Am I blind, or there is no way to force handle height for the lower part of a tall cabinet? So not the mid section, not the top one, the "default one".
              thanks in advance,
              • G
                Garry K
                The mid door is the only door that allows you to adjust the vertical position of a handle.
                I am just finishing up on another feature and was planning to visit Doors next. I can add this as a FR (feature request)
                • N
                  NBG
                  HEllo GAry, I don't get how you selected the line about "make full door" as the problem. Why this one among the others?
                  • G
                    Garry K
                    create_door_part is actually the first clue but make_full_door is the high level method which is called from make_door_drawer. This tells us that the problem is with doors / drawers.
                    The add_face, do_create_part and do_create_vert part are lower level methods which are called many times from many places such as make_top_bottom and make_shelves etc.
                    In this case the duplicate points error was caused by the Door Stile Width set to 0
                    • N
                      NBG
                      I have a similar error but I cannot find the problem. HEre is the ruby consol c/p
                      I understand that there is a problem with the sides (?), but I don't see anything
                      start_operation
                      Duplicate points in array
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:8666:in add_face' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:8666:in create_part'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:1170:in make_sides' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:8929:in draw_cabinet'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:9519:in make_one_cabinet' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:9479:in prepare_cabinet'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:178:in block in show_cab_dialog' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:172:in call'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:172:in execute_script' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:172:in block in show_cab_dialog'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:172:in call' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:172:in execute_script'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:172:in block in show_cab_dialog' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:172:in call'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:185:in call' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:185:in show_modal'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3_gui.rbe:185:in show_cab_dialog' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:9112:in load_cabmaker'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:454:in do_run_app' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:404:in activate'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:9640:in select_tool' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:9640:in initialize'
                      c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:10893:in new' c:/users/marti/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/gkware_cabmaker3/cabmaker3.rbe:10893:in block (2 levels) in module:CabMaker3'
                      SketchUp:1:in `call'
                      abort_operation
                      • G
                        Garry K
                        Please email me direct to help resolve.
                        make_sides is where the problem is. Which version of CabMaker are you running? This is important so I can go to the exact line of code that triggered the error.
                        It could be in the profile of the side or it could be with some of the dado's.
                        There is more to go wrong (bad parameters) with base cabinets - so it is helpful to know what all your cabinet and rule settings are. One area where people have issues is with integrated kicks where they use parameters that create duplicate points.
                        So please do not clutter up this thread - so send me your responses by email.
                        • G
                          Garry K
                          I should mention that with a little help from me Martin was able to determine the problem. It had to do with setting the kick height to 0.
                          Since several people have had this error I have coded around it. In the future this one won't bite you.
                          • G
                            Garry K
                            CabMaker 3.0.133 and CutMaster 3.0.1.81 are now available on my website.
                            Added shelf support cluster size optional cabinet override.
                            Now working on additional pilot holes in CutMaster for various configurations of backs.
                            • G
                              Garry K
                              CabMaker 3.0.134 and CutMaster 3.0.1.82 are now available on my website.
                              Added support for pilot holes for cabinet backs.
                              • G
                                Garry K
                                I'm looking at providing more merge options to help out users who build closets (wardrobes).
                                I would like to get construction details from users and or explanations on how you guys build your closets.
                                I'm thinking something like this.
                                • G
                                  Garry K
                                  There are a number of closet styles that can be simply created without complicated merging. In this case I adjusted left and right gaps for ALL cabinets by 1/2 the case thickness. Sides go to floor. I omited left side for Cabinets 2 and 3.
                                    abdalmalki
                                    Now we need Cutmaster to support double sided machining.
                                    • G
                                      Garry K
                                      There are some situations where the back side of a part needs machining. Personally with CNC I would avoid it as much as possible. Having said that there are situations that could benefit from it.
                                      The nesting that cutmaster produces will always machine the left side of common panels. The right side will go into it's own folder and not be a nest. Additionally the outside shape of the part will be in layer that will have it's name appended with an underscore signifying that the polyline is for reference only.
                                      Second side machining means you will have to set aside parts that need second side machining after the nest is complete. Then you will have to load the correct second side DXF and position the part correctly on the CNC.
                                      So there is a lot that can go wrong and that is why I would try to avoid it.
                                      • N
                                        NBG
                                        Hello,
                                        would there be a way to add this kind of door profile?
                                        or
                                        I thougth about it, and I guess there are 2 difficulties:
                                        • the door profiles are all for framed door, so I suppose the magic behind your "add door profile" process won't work with this. But maybe is there something to do with "panel profiles" you mention in the manual? but I don't see any panel profile in "door profile.skp"
                                        • there should be some kind of specific process capable of adaptating the number of groove regarding the door size.
                                        Using a simple texture would be easier I guess, with the problem of having to create different texture for each case (wood type, color, orientation).
                                        br,
                                        • G
                                          Garry K
                                          I can't see adding a door like this. However I am starting to work on doors and will be adding an optional bead for Shaker style doors.
                                          • G
                                            Garry K
                                            I've added 4 default Panel Bead Profiles and an option for Bead Spacing and a check box for Dead Center. Beading will follow the grain and will work for 5 piece Shaker and Slab.
                                            From top to bottom these are called Standard, Smooth, V Groove and Half Round.
                                            Bead Spacing
                                            Dead Center
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 31
                                            • 32
                                            • 25 / 32
