    Synchronization problems between sketchup and layout
    layout
    3 Posts 2 Posters 6.5k Views 2 Watching
    • B
      Buitremundo
      greetings, I have a problem in the synchronization between sketchup and layout, when I close the programs to continue the next day, they do not re-synchronize and changes in sketchup are not updated in layout.
        Share the LO file so we can see exactly what you have going on. That will make it easier to give you an exact answer instead of guessing at the reason.
        The typical reason for this is either not using scenes in SketchUp and connecting them to the viewports in LayOut, or modifying the scenes in LayOut after you've created the viewports. In both cases, any scene specific modifications you make in SketchUp will not be displayed in LayOut.
        • B
          Buitremundo
          thanks for the information, problem solved.
