    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      Version 0.9.8f - 10.23.2018
      • Critical fixes in the following modules: Auto-Corner Config, Shutters, Sheathing and Cladding.
      • Loading wall presets changed to a two step process. Clicking the update button is no longer required to activate a loaded preset.
      • Wall edit menu updated to allow for sequential selection of wall panels for quick editing.
      There are even more minor fixes that are too numerous to list.
      The wall edit menu update should be a welcome fix. If you are right clicking on each wall to edit them then each time you right click and "Edit Assembly" the wall settings will appear in the edit menu for that wall. Previously a separate window would open up for each wall panel but only the last edit window actually worked. This resolves that issue and makes it more intuitive and robust.
      If you are using the edit icon to edit walls this is even a quicker method of selecting and editing walls. After you select a wall the tool remains active and you can continue to select and update walls by clicking on your target wall panels. To terminate the tool, close the edit menu and hit the space bar.
      Both methods of editing are now faster and much more intuitive and robust.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 0.9.8g - 10.24.2018
        • Corrected a bug in the Walls tab of the global settings involving the wall presets selection field.
        • Added a blocking thickness parameter in the Walls tab of the global settings.
        http://design.medeek.com/resources/images/wall_su247_800.jpg
        This particular bug in the Walls tab only became an issue when a previously selected default preset was deleted and then the user navigated to the Walls tab after the deletion.
        Now the javascript checks first for the existence of the default preset before trying to assign it in the drop down menu.
        Not a really big issue but in a certain state it will lock up the form and not allow the user to save their settings.
        The blocking thickness parameter was a quick item to add per a user request. Note that this is a global default and cannot currently be adjusted per wall panel. If we need more granularity I can do that but it means an additional parameter in the attribute library of the wall panel which means it will break backward compatibility with previous versions of the plugin.
        design.medeek.com
        • medeekM
          medeek
          Medeek Wall Plugin Tutorial 5: Multi-Story Construction
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • medeekM
            medeek
            Version 0.9.8h - 10.25.2018
            • Fixed a bug with the blocking parameter for metric templates.
            If your using metric templates you will want to upgrade to this version otherwise your blocking will appear too large as it will not be converted from millimetres to inches in the final drawing step.
            A critical fix for clients using metric.
            design.medeek.com
            • medeekM
              medeek
              As a follow up discussion to the multi-story tutorial I was asked a question by a designer regarding installation of a band board between the two stories as shown below:
              http://design.medeek.com/resources/images/wall_su248_800.jpg
              To be honest I hadn't tried this before but the band board is provided by the 1st level walls and then its height is actually set such that it is actually above the sheathing, cladding and wall height. It seems this is possible.
              On the same token one could use the 2nd story walls to specify the band board and input a negative number to set the band board below the actual wall itself.
              In this particular design case, there is more than one way to solve the problem.
              The frieze and skirt boards are a little more static, in that they will always be positioned at the top and bottom of cladding respectively.
              On a slightly different note you will notice that we are already at revision "h" of version 0.9.8:
              404 - File or directory not found.
              (design.medeek.com)
              Quite a few updates to this version. The reason I haven't rolled to 0.9.9 is because I am saving that version for the stair module roll out and then version 1.0.0 will be when I roll out the gable wall module.
              At that point I will be taking the plugin out of BETA which in all reality means that I am then paying attention to backward compatibility issues and actively trying to maintain it so that new upgrades do not cause problems.
              Version 1.0.0 also means that I will be further reviewing my pricing structure and my licensing system. There has been some pressure from various quarters to move to a subscription based licensing system even though I have resisted this move.
              If I do move to a subscription system the good news is that all currently licensed users will be grandfathered in so that they will not be required to renew a yearly subscription, their licenses will always remain permanent.
              As an incentive to encourage more early adopters I will be running a "Thanksgiving Promotion" on all of the plugins until Nov. 23 (Black Friday). For all plugins purchased between Oct. 15 thru Nov. 23 your typical two year license will be doubled to four years and your one year foundation plugin will be doubled to two years.
              For those who have recently purchased any of the plugins please send me an email and I will honor this promotion by extending your license exp. date.
              design.medeek.com
              • medeekM
                medeek
                ***** UPGRADE WARNING *****
                One thing that has come to my attention is that when upgrading to the latest version of the plugin (0.9.8h) and you are upgrading from a previous version that did not have the new dimension layers (dim2 and dim3) added, you may encounter this error:
                Error; #<TypeError; no implicit conversion from nil to integer>
                c;/users/dscott/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/medeek_wall_ext/medeek_wall_globals.rbs;1445;in `[]'
                The quick fix for this error is to reinitialize the layers by clicking on the global settings and then navigating to the Layers tab. This alone will reinitialize any missing or newly added layers.
                In the next version I will add some additional code that checks for this type of situation, so that it is no longer an potential issue in future releases.
                design.medeek.com
                • medeekM
                  medeek
                  The next release of the plugin will have an arrow as shown to the right of the tabs in the global settings which will take the user to the next set of tabs:
                  http://design.medeek.com/resources/images/wall_su249_800.jpg
                  Currently there are nine new tabs planned, most of which will have an under construction sign until I fully flesh them out:
                  http://design.medeek.com/resources/images/wall_su250_800.jpg
                  The Updates tab will display the current changlog which is paralleled on the website as well.
                  http://design.medeek.com/resources/images/wall_su251_800.jpg
                  Clicking the left arrow will return the user back to the first set of tabs.
                  If required an additional right arrow can be added to the second set of tabs taking the user to the third set of tabs.
                  In total there are 12 tabs in the first set and 9 tabs in the second set, for a total of 21 tabs in the global settings.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 0.9.8i - 10.28.2018
                    • The following tabs added to the global settings: Garage Doors, Beams, Columns, Stairs, SSW, Shearwalls, Estimating, Engineering and Updates.
                    • Enabled custom materials for gypsum in the HTML wall draw and edit menus.
                    • Felt + OSB material added to the pre-installed plugin materials.
                    http://design.medeek.com/resources/images/wall_su252_800.jpg
                    Felt + OSB is similar to Tyvek + OSB where the outer face of the OSB has the felt material applied.
                    The felt material application depicts a typical 36" roll with 2" of overlap.
                    The change to the way I'm handling the gypsum material is a significant upgrade and allows for usage of custom materials from the material library within the global settings.
                    design.medeek.com
                    • facerF
                      facer
                      OSB stands for oriented strand board.
                      The most common uses are as sheathing in walls, flooring, and roof decking
                      OSB is a material with favorable mechanical properties that make it particularly suitable for load-bearing applications in construction. It is now more popular than plywood, commanding 66% of the structural panel market. The most common uses are as sheathing in walls, flooring, and roof decking
                      Oriented strand board (OSB), also known as flakeboard, sterling board and aspenite in British English, is a type of engineered wood similar to particle board, formed by adding adhesives and then compressing layers of wood strands (flakes) in specific orientations.
                      • medeekM
                        medeek
                        In a high moisture climate (like on the beach here in Western Washington) I would recommend staying with plywood, but most new construction for walls is 7/16 OSB anymore.
                        design.medeek.com
                        • medeekM
                          medeek
                          The current Wall Plugin ToDo list as of 10/29/2018:
                          1.) Gable Walls (Standard and Shed) [in progress]
                          2.) Stair Module (straight run then landings and complex shapes) [in progress]
                          3.) Estimating [in progress]
                          4.) Adv. Gypsum (multi-layer gypsum both sides of int. walls)
                          5.) Custom width of king and trimmer studs for doors, windows and garage doors.
                          6.) Transom windows above doors (rectangle and arch)
                          7.) Additional door types (bifold, sliding glass, pocket doors)
                          8.) Join/Split Wall Tools
                          9.) Wall Stretch Tool
                          10.) Wall Grouping
                          11.) Wall Dropper
                          12.) Engineering
                          13.) Levels/Stories Manager
                          14.) Interior painting of gypsum
                          15.) Wall justification in draw wall tool.
                          16.) Gypsum backer studs at tee intersections
                          17.) Interior Trim (crown molding, baseboard, chair rails, wainscoting)
                          18.) Global Settings (8 new tabs) [in progress]
                          19.) Shear Wall Module
                          Some of these are extremely high priority and some of these are much lower on the list.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 0.9.8j - 10.30.2018
                            • Advanced layers (headers, kings and trimmers) enabled for door, window and garage door framing.
                            Somehow along the way I setup advanced layers for the framing however they did not get fully implemented until now.
                            design.medeek.com
                            • medeekM
                              medeek
                              With balloon framed gable walls one often sees a lot of trapezoidal picture windows used in these walls:
                              https://qhj9t4ethoqu9lfx4606zo12-wpengine.netdna-ssl.com/wp-content/uploads/2010/06/Trapezoid_window_solar_shades.jpg
                              I need a little more guidance on the most typical way these openings are framed out. If a header is installed it would have to be inclined and would follow the pitch of the roof.
                              Any framing details or suggestions would be greatly appreciated.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 0.9.9 - 10.30.2018
                                • Enabled custom window header and trimmer widths within draw and edit menus.
                                • Added king and trimmer width parameters to Windows tab of global settings.
                                • Fixed a bug with insulation positioned above windows where trimmer quantity is greater than one.
                                http://design.medeek.com/resources/images/wall_su255_800.jpg
                                This addition was per customer request. I will probably add the same two additional parameters for doors and garage doors in the very near future.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  On a somewhat related note to the last post I'm looking at various photos of typical residential framing and I've noticed that many framers will include a plate below or above the header or both:
                                  https://banksresidence.files.wordpress.com/2012/09/131.jpg
                                  Any thoughts on this?
                                  Do I need to add this in as another option?
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Sounds like I need to provide the option for a header top plate and header bottom plate, (not sure what the exact terminology for these plates should be).
                                    design.medeek.com
                                    • facerF
                                      facer
                                      Adding a top and bottom plate may be done when the beam is not available.
                                      Although redundant it would allow the framer to allow for beams that are not on site
                                      at the time the frame is being constructed.
                                      • medeekM
                                        medeek
                                        I can use either one parameter with four possible options or two parameters with two options each:
                                        Built-up Header: NO|TOP|BTM|BOTH
                                        or
                                        Header Top Plate: YES|NO
                                        Header Btm Plate: YES|NO
                                        Which would you prefer?
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 0.9.9b - 10.31.2018
                                          • Enabled built-up headers within the window draw and edit menus: None, Top, Bottom or Both.
                                          • Added the built-up header parameter to the Windows tab of the global settings.
                                          http://design.medeek.com/resources/images/wall_su257_800.jpg
                                          The window to the left is a good example for where the top plate is not needed, just the bottom plate. as the header butts up directly against the top plate of the wall.
                                          The window to the right is set lower in the wall and requires both top and bottom plate as shown.
                                          The built-up header parameter allows four options: None, Top, Bottom or both. The default behavior can also be set in the global settings.
                                          As with the custom widths on the trimmers and kings I am test bedding this with the windows first, once everyone has had a chance to work this through a bit I will roll it out for doors and garage doors.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I'm trying to simulate a G-rib metal wall panel here (clay and stone color):
                                            http://design.medeek.com/resources/images/wall_su256_800.jpg
                                            The problem of course is that the shadow will be cast a certain direction on the original texture/image but when you render it out the light source may be the opposing direction which will make things look a bit off.
                                            Modeling the actual texture/profile of the panel is not a good idea either since it would make the model very heavy.
                                            Thoughts?
                                            View model here:
                                            3D Warehouse
                                            http://design.medeek.com/resources/images/wall_su258_800.jpg
                                            design.medeek.com
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 80
                                            • 81
                                            • 28 / 81
