    Exporting Layout to PDF - Style problem
    layout
    4 Posts 2 Posters 6.8k Views 2 Watching
      agrazdi
      I have different styles ( created within the SKETCHUP file ) in several Layout pages.
      Example, I have 1 page with a shaded textured color style, other one in Monochrome, and so on.
      When export them to PDF, all the pages have the shaded textured color style.
      Is there a way to export each page with their own style ?
        It is possible to have each page show a different style if you want. Why it's not happening for you is a guess at the moment. Can you share the LayOut file so I can see how you have it set up? That'll give me the info I need to give you the correct answer. Send it via a PM if you don't want to make it public.
          agrazdi
          I guess i found a way to achieve it
          I render the su drawing in each page either Vector / Hybrid, and apply the style again and it worked.
          Thank Dave
            That kind of sounds like a work around for the right method but if it works for you, that's fine.
