    MagicaVoxel as render for SU!
    70 Posts 4 Posters 33.1k Views 4 Watching
      The free incredible famous generator of Voxels: MagicaVoxel
      can be used as funny NPR render for SU! πŸ€“
      Tremendous varieties of regulates! (time render 2 seconds with reasonnable parameters)
      Just export SU model as OBJ format with OBJ exporter by TIG
      https://ephtracy.github.io/image/mv_home.png
      https://ephtracy.github.io/image/snap2016-06-22-20-03-21.png
      β˜€
      • Rich O BrienR Online
        Already a fan...
          Version 0.99
            Concepts! β˜€
              By Sir Carma Modeling with MagicaVoxel animation ouside
              http://saymygame.com/wp-content/uploads/2016/12/SciFiCityAnimation.gif
              http://medias.3dvf.com/publish/sircarma/Day-scene.png
              http://medias.3dvf.com/publish/sircarma/Industrial-sceneV2.png
                Released!
                http://ephtracy.github.io/image/snap2018-09-26-13-21-50.png
                  Some doddlings β˜€
                  https://2img.net/h/s6.postimg.cc/axhl7gsn5/magica02.jpg
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/pseudo-frac_orig.jpg
                  https://i.postimg.cc/9Fqbf9hg/magica_992.jpg
                  Astonishing as cubic cubes can do! 😎
                  https://i.postimg.cc/nc4NRgP1/lamp01.jpg
                    Free MagicaVoxel + free p5.Js
                    FullScreen
                    Code πŸ˜„
                    Tell me if you go to my account or just on the code ?
                    https://i.postimg.cc/CxKWQjr1/magica0100.jpg
                      From any OBJ format object just make a Drag & Drop on the MagicaVoxel Screen ! πŸ€“
                      (take an empty or fully matrix (maxi 126 *126 *126 it will be remplaced by your object)
                      https://i.postimg.cc/4305Kkyc/magica102b.jpg
                      From the internal
                      https://i.postimg.cc/sXZJ76GN/magica112.png
                      Spheres as Cubes
                      https://i.postimg.cc/KjSDNPnv/magica112f.jpg
                      2 objects for test because Matrix maxi is 126126126
                      https://i.postimg.cc/PfY4q7jL/moi300.jpg
                      So you must splite your big object! Here some Copy/ Paste/ Move
                      https://i.postimg.cc/QMFgZ4md/mmgicmoi300.jpg
                      Result from somewhere whith the Stereographic Projection function (cool from 150Β° to 270Β°)
                      https://i.postimg.cc/fR27FnxP/mg4.png
                      Edges can have a thickness & Colors!
                      https://i.postimg.cc/NFcRTgcK/mg02.png
                      Grid and Ground can have a thickness & Colors!
                      https://i.postimg.cc/V6bctgkG/mg01.png
                      Vertex Function render can stretch on x,y,z axis
                      https://i.postimg.cc/gjVqBxDy/magica300.jpg
                      Russian Constructivists should use MagicaVoxel! πŸ˜„
                      https://i.postimg.cc/XYQ36XP8/magicaperlin.jpg
                      Again test of 2 objects
                      https://i.postimg.cc/4ypch2w5/8-cubes-magica04.jpg
                      Some repetitions
                      https://i.postimg.cc/3xNwsbpc/8-cubes-magica05.jpg
                      Internal view
                      https://i.postimg.cc/rFnVNCbC/magic01.jpg
                      Sun, color background...
                      https://i.postimg.cc/x1B9Wj9X/magic02.jpg
                      Spheres as Cubes
                      https://i.postimg.cc/LsfmRdsN/magic03.jpg
                      Transparency: the little cubes in the space are used as a trick when you import your object for automatically fix its position (so 8 little cubes) inside the Matrix! You can of course erase them before rendering!
                      [img:2vt28qfp]https://i.postimg.cc/9MhCQxRV/magic04.jpg[/img:2vt28qfp]
                      Exploration...
                      [img:2vt28qfp]https://i.postimg.cc/B6BsLxHF/magic05.jpg[/img:2vt28qfp]
                      Some point of view...
                      [img:2vt28qfp]https://i.postimg.cc/8P0G6kJZ/magic06.jpg[/img:2vt28qfp]
                      From a model by diTOTO from 3DWareHouse Drag & Droped so very reduced! πŸ˜„
                      [img:2vt28qfp]https://i.postimg.cc/sgxswZP5/garabit8.jpg[/img:2vt28qfp]
                      Inside the beast! πŸ˜„
                      [img:2vt28qfp]https://i.postimg.cc/JzFmg4Kv/garabit9.jpg[/img:2vt28qfp]
                      Amazing that can be done in 30 seconds modeling!
                      [img:2vt28qfp]https://i.postimg.cc/fRHHwV9W/BUILDING.jpg[/img:2vt28qfp]
                      So clean...of course this use is not the classic use of Voxels Art! πŸ˜„
                      As edges and grids can have colors & tchickness variations are infinite!
                      [img:2vt28qfp]https://i.postimg.cc/Hsknv1KM/magica2004.jpg[/img:2vt28qfp]
                      In the Swimming-pool! Render's tools are so easy! Choose a color diectly on the rendering screen (Alt + Click) and this color can become emmeter, glass, metal etc...
                      [img:2vt28qfp]https://i.postimg.cc/qvpvZdCd/piscine.jpg[/img:2vt28qfp]
                        The famous Zbrush Demo_Soldier πŸ˜„
                        https://i.postimg.cc/sXXFN7Sp/demo-soldier.jpg
                        Architecture in 30 seconds πŸ˜„
                        https://i.postimg.cc/652286z0/magica2005.jpg
                        https://i.postimg.cc/sDdTVJFf/nogrid.jpg
                        https://i.postimg.cc/85Czfvqj/curve270.jpg
                        https://i.postimg.cc/NjcfT3wZ/roule_tout_seul.jpg
                        https://i.postimg.cc/Hnr4wJbW/deuxobject.jpg
                        https://i.postimg.cc/cL3KQRj5/deuxobject1.jpg
                        https://i.postimg.cc/MZMtn1F4/block1.jpg
                          Citizen Kane! πŸ˜‰ (and cool musics! β˜€
                          else complete guide: importing-magicavoxel-sketchfab ! πŸ€“
                          MagicaVoxel to SketchFab
                            My Magica Gallery! πŸ˜„
                              Green Spaces! πŸ˜„
                              https://i.postimg.cc/ZKkjjYdc/green01.jpg
                                https://i.postimg.cc/wvS5qwqY/blue.jpg
                                Less one minute!
                                https://i.postimg.cc/QCkCzQxD/space10.jpg
                                https://i.postimg.cc/VLmdCVDk/space12.jpg
                                https://i.postimg.cc/jdcCQ4FQ/space14.jpg
                                https://i.postimg.cc/nLjzxbc0/space16.jpg
                                https://i.postimg.cc/q7CzkWxB/space18.jpg
                                https://i.postimg.cc/vZVgV0Nq/space20.jpg
                                https://i.postimg.cc/Prkr7d34/pilouloco.png
                                  https://i.postimg.cc/ZR9T8Zk3/GIF_verve.gif
                                  https://i.postimg.cc/tJgpqxyh/bravo-Zarbuz.jpg
                                  https://i.postimg.cc/3w1MwHND/semis.jpg
                                  https://i.postimg.cc/cLShD9MD/height-map-trick.jpg
                                  https://i.postimg.cc/XYk8tfsn/paille.jpg
                                  https://i.postimg.cc/g2NWmBsJ/GIF-256.gif
                                  https://i.postimg.cc/XvjYgCHZ/glass-flowers.jpg
                                  https://i.postimg.cc/90fm7jNS/niveau-interne.jpg
                                  https://i.postimg.cc/NGCfvWZC/GIF-walk.gif
                                  https://i.postimg.cc/d0dS3BZb/GIF-vervo.gif
                                  https://i.postimg.cc/d0FypLfK/carte-fond.jpg
                                  Infinite variations πŸ˜„
                                  https://i.postimg.cc/5y9PPWKJ/blockw.png
                                    https://i.postimg.cc/jSnt2xk1/cristal.jpg
                                    https://i.postimg.cc/FsLpLv9q/rondo.jpg
                                    Magica "one minute shot" of the day πŸ˜„
                                    https://i.postimg.cc/B6RBNV6v/soleil-levant.jpg
                                    altitude "height" from an image created with Particles 9
                                    https://2img.net/h/s6.postimg.cc/qozypkhgx/partic02.jpg
                                    https://2img.net/h/s6.postimg.cc/t0pl4c5pt/pandora_box.jpg
                                    https://2img.net/h/s6.postimg.cc/5012lthup/partic01.jpg
                                      Blue Morning πŸ˜„
                                      https://i.postimg.cc/QN2Q8b6Q/blue-morning.jpg
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2048_2048.jpg
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/a2048.jpg
                                      http://moiscript.weebly.com/uploads/3/9/3/8/3938813/aaa_2048.jpg
                                        Speedy MagicaVoxel Workflow:
                                        Draw any thing in few seconds...
                                        https://i.postimg.cc/PqzCkfYG/interior0.jpg
                                        Give a color and thickness (or not) to the edges, the grid, the ground, the background.....
                                        A material with certain colours, from Glass to the colour of the faces for transparency, from Metal tyo Floor if ou want a reflection.
                                        https://i.postimg.cc/Vv5vMjT1/interior1.jpg
                                        Explore the internal volume with a sterescopic Projection
                                        https://i.postimg.cc/J7dG82Dh/interior2.jpg
                                          About Speed Modeling in MagicaVoxel!
                                          Create a simple and complex Pattern at the same time, save it. And with each new object, use it in ATtach mode (with Shift when you want to "cut" into the mass). Coupled with the "internal" matrix displacement (CTRL), it is extremely effective! (and 3 keys to remember, T, Shift, CTRL) for "short memories" like me, it's perfect! (and 0, 9 to turn the module)
                                          And of course you can create a Pattern in a 2nd matrix and bring it back to the 1st one as you wish!
                                          Translated with http://www.DeepL.com/Translator
                                          https://i.postimg.cc/7hQSY9R7/GIF-sppedy.gif
                                          6 seconds modeling! πŸ˜‰
                                          https://i.postimg.cc/3xG2YgF4/speedy.jpg
                                          Some color effect if needing...
                                          https://i.postimg.cc/1zc6NsTy/speedy1.jpg
                                          https://i.postimg.cc/wjKPGqjX/chantier.jpg
                                          https://i.postimg.cc/Pqq5PQnr/chantier2.jpg
                                          https://i.postimg.cc/Hszh2fhz/chantier4.jpgg
                                            For test bigs images *4 of free Deep Image ... πŸ˜„
                                            https://i.postimg.cc/xjKQ9n0g/night.png
                                            https://i.postimg.cc/6pQxVZC1/night.jpg
                                            Big Colors
                                            Big N&B
                                            • 1 / 4
