    Layout renders hidden layers (2018)
    layout
    4 Posts 2 Posters 7.6k Views 2 Watching
    • ArisA Offline
      Aris
      Hi all,
      I found out that SU 2018 rocks!
      a small problem with layout though (and it might be just me not understanding something):
      I created two layers, one with content and one 'beneath' it with guides (lines and rectangles)
      When I exported the pdf, I 'blinded' the guide layer but it still kept being exported to the pdf.
      It was only gone when I deleted the layer with its contents.
      Is this how it is supposed to work? because it is a problem if you want to update the model and export again at another date.
      Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
        Normally layers that are not set to be shown should not show in the PDF export. Could you share the LO file that exhibits this problem so I can try an export to compare? That would help us sort out where things are going pear-shaped.
        • ArisA Offline
          Aris
          Hi Dave,
          thanks for replying so soon but it was a false alarm.
          I opened the pdf in the browser and for some reason it had cached the original file. I reopened the new version of the file with the guides hidden and it kept showing me the initial pdf.
          It was a browser problem, not a layout problem. once I ctrl+F5'd it it showed the new version.
            Good enough.
