    Edit: Create 3d objects with a single rectangle drag
    5 Posts 3 Posters 1.2k Views 3 Watching
      anujsaini
      hey im looking for plugin tool to create a 3 dimensional object involving a single drag of a rectangle button..
      for example i would like to drag a rectangle to create any sized object with the third dimension predefined as 0.75"..so that i can create plywood pieces in a single command rather than using rectangle tool along with push pull tool to create the depth of 0.75"...
      anyone have any suggestions?
        You can put the Subtitles! πŸ˜‰
        All are free! β˜€
          ktkoh
          Been woxrking on that. Sent a pm
          Keith
            anujsaini
            thanks for your suggestions..any other suggestion would be welcomed
              ktkoh
              Search for wudworx the board maker is free and makes a board component after dragging a rectangle and entering thickness value. Download the zip file and change the file extension zip to rbz and the file will install with the install extension feature. works on 2016 which is as far I can test.
