2d exportation
pls how to make a good resolution 2d export, mine is very low rez and full of aliasing(jpeg)as you can see on this picThanks
Try exporting at a higher resolution.
Adjust the settings found by clicking the Options button on the export dialog.
All was already at the maximum, but export still have low res...
Increase the export size. And export as PNG, not JPG.
Even as .jpg you can increase the size from what you are showing in your screenshot.
Untick the box that says, 'Utilser la taille de la vue'. -
Thanks!!
