    [Inquiry] Plugin for Moving Scenes / mass selection
    8 Posts 4 Posters 911 Views 4 Watching
    • onzkiO Offline
      onzki
      Hi Everyone,
      I'm using 2018 Pro, to my surprise, the scene manager haven't improved a lot since version 8 lol 😄- selection method is one by one. Anyway, I have 100 scenes.
      All I'm planning to do is to select scenes from 1-50 and drag it after 51.
      Is there a plugin to do this? Many thanks!
      [/hr]Dell Alienware Area-51. SKU 2021 Pro. AutoCAD 2023. Landscape design firm
        rv1974
        back up the file with scenes, than
        delete all-> paste new model
        no plugins needed lol
        • HornOxxH Offline
          HornOxx
          @rv1974 said:
          back up the file with scenes, than delete all-> paste new model, no plugins needed lol
          just an additional suggestion: between "delete all" and "paste in place" it often could make sense to clean everything up via > Window > Model info > Purge Unused. So your file does not become unnecessarily large and you avoid possible conflicts with material namings ...
          never trust a skinny cook
            rv1974
            bad idea. for example, scenes presevre layer configurations (purging deletes them)
            • HornOxxH Offline
              HornOxx
              Uhps! does "Purge Unused" also delete preseved scene-layer configurations? I haven´t noticed this yet so thank you for this hint ...
              • pbacotP Offline
                move "51" to before "1"?
                • pbacotP Offline
                  No Hornoxx, but purge all purges unused layers and if you are doing cut and paste, there won't be any used layers in between.
                  • HornOxxH Offline
                    HornOxx
                    Thanks Pbacot to make it so clear - I use this "rv1974 method" so often, but never with complex layer arrangements. The thought about this didn't even cross my mind - there is always something to learn 😉
