    Fillet inner and outer edge porportional
    9 Posts 4 Posters 1.7k Views 4 Watching
    • H Offline
      herrschnitzel
      Hi I'm looking for something like in picture 4.
      I tried round corners but it cannot detect outer an inner edge as far as i know. Is there a simple solution to round inner and outer edge porportionally?
      • BoxB Offline
        Just use offset.
        • H Offline
          herrschnitzel
          Thanks thats exactly how I did Nr.4 in my picture. Is there another solution? If I want to change the radius a have to manually draw everything again. Thats time consuming ๐Ÿ˜„
          Its such a simple thing but still so laborious in SketchUp.
            Depending on what you've done to the geometry, you may be able to select the arc and change its radius in Entity Info. You have to select each arc individually, though.
            Click on the picture.
            If you think the radius might need to change later, it would probably make sense to plan for that and model accordingly.
            • BoxB Offline
              I'd have to argue about the laborious part.
              • H Offline
                herrschnitzel
                Yes, but again... I want both arcs to be scaled proportionally. If I scale one arc I have to calculate the size of the smaller arc.
                But it does the job^^
                thanks
                  You should know the thickness or you can find out what it is. There's not much calculating to do. Simple addition will take care of it.
                  • H Offline
                    herrschnitzel
                    Yes you're right it's not that much of calculation I know. I justed hoped for a parametric solution with a plugin or something.
                    Thanks anyway.
                      rv1974
                      profile biulder could be good to you, but it depends on situation
