    Forming 3D object
    2 Posts 2 Posters 1.0k Views 2 Watching
    • C
      CliffordZhang
      Hi, I am trying to form a triangular prism with the two triangular faces delineated in the screenshot and the space in between. Because the two triangles are noncoplanar, Sketchup won't form a face to fill in the space even when i connect the 6 points together. Does anyone know of any tricks to get SU to form me a 3D object between the two faces? SKP and Screenshots of problem provided.
      RoughDRaft2.skp
      • pbacotP
        With two triangles connect the vertices directly across (bottom to bottom etc.) from one triangle to the other with edges. Then connect a vertex of one to a different vertex of the other and so three times. This way you create triangles that should form faces. You form the shape with 6 triangles altogether. Use smooth/soften window to hide the edges you don't want to see.
