    [Plugin] Add comments to your file
    104 Posts 20 Posters 28.7k Views 20 Watching
    • inteloideI Offline
      inteloide
      Hello,
      New version 2.3.9 should correct this issue.
      Please download it from the store (with new version of BGSketchup Library)
      Inteloide
      Humanity will do a huge step when the IT professionals will understand that computers are tools...
      • greenskpG Offline
        greenskp
        Thank you!!!
        Could you to correct this issue for Component Manager too? Maybe for all BGSketchup family?
        • greenskpG Offline
          greenskp
          inteloid,
          sometimes i need to change the tab for make another annotation but the icon of options is very close and opens the window. It's possible to put a delay or increase the distance between the tab name and the icon of options?
          Take a look on my screen recorder.
          http://i.imgur.com/oJMp2th.gif
          • greenskpG Offline
            greenskp
            Good Evening inteloid,
            I did for me a translation pt-br for the file Translation.rb and also correct few things in the file pt-br.js.
            If you think this is good, please add for the next update πŸ˜„
            Translation pt-br
              inteloide
              Hello Greenskp,
              Please find here a new version that include requested improvements.
              Please, keep me informed if it's ok for you.
              Best regards
              Inteloide
              Version 2.3.10
              • greenskpG Offline
                greenskp
                Happened some behaviors that not exists in official version. This version 2.3.10 seems incompatible with the library 3.6.
                If i make 7 tabs:
                • the tab 2 froze
                • change the language unfreezes the tab 2 but freezes the tab 6
                • From right to left is good but from left to right one tab is skipped
                I think is better forget this and only include the translation. Or perhaps force the tab to shrink before of the mouse be released.
                custom version 2.3.10
                  inteloide
                  Hello Greenskp,
                  Everything is working fine on my computer.
                  According your screen recorder, you have an issue "$ not defined" : it looks like jquery is not working correctly. Also, the height of the area where to enter text is smaller than expected.
                  Please try to install again the plugin. Sometimes it works.
                  If you have the same error, replace the pt-br.js file you send me by the previous version.
                  Keep me informed.
                  Inteloide
                  • greenskpG Offline
                    greenskp
                    I replace with pt-br.js file that i sent to you and worked very well!
                    Do you think about include in the Plugin Store on next update? I am really happy and waiting to tell my colleagues about all features.
                    • greenskpG Offline
                      greenskp
                      Hello Inteloid, it's me again
                      i was working today and i found some bugs in 2.3.9 version.
                      1. Double click or Ctrl + mouse click doesn't open a hyperlink
                      2. After change a language, if i change again, the javascript side remains the same and just Localization.rb does the change.
                        I erased the Library and Comments_2.3.9 and reinstall both, also i cleaned the cookies on Internet Explorer but this behaviour remains.
                      3. The last tab and penultimate tab doesn't save if not contain an image annexed.
                        Seilo
                        @bmoffa said:
                        I would really like to use this plug-in, but it seems to not save or not load comments that I add. At first it lost comments from one of the two tabs I set up, then it lost everything.
                        I'm using version 2.3.5 in SketchUp 2015 Pro 64 bit (current build). I really hope you can fix this as I really like it.
                        Hi, I'm having the same problem as BMoffa. The data in Tab1 is always deleted after I close and reopen a file. Tab2 seems to be fine...
                        Using version 2.3.10 on a 64Bit Win7 machine
                        • 6 / 6
