    Vray sketchup materials to 3ds Max
    renderpluginsextensions
    2 Posts 2 Posters 3.3k Views 2 Watching
      jerem13579
      Hi everybody, i would like to know how to transfer all my vray sketchup materials, with the bump maps, reflections, etc. I have tried to import directly my sketchup model to 3ds max but the textures are just "flat", no glossines, nothing. I also tried doing a FBX file but the result was the same. Is there an exporter that i dont know about that can do all this? Im using Vray 3.6 and 3ds Max 2018.
      • omiKronO
        omiKron
        hello,
        I knew of a software which made a transfer between v-ray sketchup and v-ray max properties, just that I miss its name at this point. It was a script for 3ds max which imported material properties such as glossiness factors and bumpiness slots...
        Though it can't be FULLY compatible since 3ds max is a different modeling platform than sketchup and will never be completely compatible with, also v-ray for sketchup is totally different than 3ds max one.
        And if you know your parameters you can apply them in v-ray for max too . I know you don't like working twice on something, but that's the best way sometimes.
        LE - here it is :
        404 Not Found
        (sketchucation.com)
