    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] PomPi (Pompous Piping 2016 RC2018 )
    47 Posts 10 Posters 41.4k Views 10 Watching
      If you are interested in French UI and manual in French, don't hesitate! ๐Ÿ˜„
      Seems remember i have made the 3SKeng and site in French in the past for the fun! ๐Ÿ’š
      (seems they have updated that! There is only rest the menu on the left! ๐Ÿ˜ฎ
      For the UI I need a list or a multi-Language system, because I don't want to swim in the code! ๐Ÿ˜„
        dezmo
        Thanks a lot pilou!I am very grateful! ๐Ÿ˜„
        But unfortunately the code itself is not prepared for more than 1 language. (yet?) But at least the manual can be useful... ๐Ÿ˜‰
        Man can do everything. Only a matter of time and money.
          French Manual! ๐Ÿ˜„
            dezmo
            @pilou said:
            French Manual! ๐Ÿ˜„
            What a nice surprise! Thanks! ๐Ÿ˜Ž ๐Ÿ˜„
            I'll put it to the first post!
            • FrederikF Offline
              Frederik
              One thing I'm really missing is the ability to make bends other than 90 degree...
              With the 3skeng you have the option to select the bend degree when connecting it to a pipe...
              If I select the pipe and bend, I can't get i.e. a 45 degree angle...
              Cheers
              Kim Frederik
                dezmo
                Oh, yes. Originally it is designed to make perpendicular piping between two existing point, when I did not think even of the Pipe Auto function.
                But I get the idea of "pipe auto" and started to work on it, than pipe&bend remained as it is.
                The drawn line endpoint is the 90ยฐbend "other end" "horizontal" projection to be able to align to the next component. Right now the pipe length is the distance between picked point minus the bend radius. I do not know what should be the length if the angle is different than 90ยฐ, because the "end" face of the bend looking somewhere other direction than the length of the pipe+bend "height" (bend "height" = the bend two end face middle point distance.)
                If I allowing to put other than 90ยฐ I have to calculate backwards somehow and I would heve to know in advance the "height" of the bend + pipe length.
                Did you get my explanation, because I'm already lost... ๐Ÿ˜„
                So lot of questions raises regards your "simple" request.
                I'll see if I can do something... Currently I don't have any idea and my boss extended my work for (in) Denmark & the holiday season is also here... ๐Ÿ˜Ž
                • FrederikF Offline
                  Frederik
                  @dezmo said:
                  ...and my boss extended my work for (in) Denmark & the holiday season is also here... ๐Ÿ˜Ž
                  Nice to hear...
                  Too bad the weather is so bad this year...
                  Summer time can be great in Denmark, but this year we seem to have UK/Irish conditions... ๐Ÿ˜›
                  Cheers
                  Kim Frederik
                  • Z Offline
                    zxin0410
                    I am use mac os.It works fine.But i think it would be great if the font could be bigger.
                    In high resolution screen,the fonts of user interface will be too small to use.
                      dezmo
                      Thanks for feedback from MAC!! ๐Ÿ‘
                      Probably I will make a "style" with bigger font or button to change font size... or something like this, but definitely only after holiday season... sometime! โ˜€
                        dezmo
                        New version is updated to 1st and 2nd post.
                        I hope, you will like it!
                          Seems I must update the Pompi French site (this summer) ๐Ÿ˜‰
                            dezmo
                            ๐Ÿ˜Ž
                            Ye, There were some changes... not that much in docu ๐Ÿ˜‰
                            • jujuJ Offline
                              juju
                              why has this not been submitted to the pluginstore?
                                dezmo
                                There are two reason:
                                  1. It is still test phase...(but maybe good enough to submit ๐Ÿ˜‰ )
                                  1. I don't have any clue how to submit. ๐Ÿ˜• Do you have an idea and/or link about the procedure?
                                    (Actually I have a plugin in the store, but that one submitted by somebody else...)
                                  Gรกbor
                                  Rich O Brien or I can add you to the plugin author's group then you'll be able to upload your plugins to the SketchUcation pluginstore. For this to happen we need the following information:
                                  • The name you want to display as your author name in the pluginstore (it can be "dezmo" or any other name)
                                  • If you want to collect donations we need the email link of your PayPal "donate button"
                                  Please PM me these and I'll set you up.
                                    dezmo
                                    Note: The actual version can be a little different than shown below.
                                    Sorry about the quality... because the 2MB file limit
                                    You can find here the original:
                                    https://drive.google.com/file/d/1aATvf-oiEHjV9290RINv87tW6qybQTHa/view?usp=sharing
                                    Click to play!Click to play!
                                      dezmo
                                      First post updated. Some small changes in the UI, and naming of the components...
                                      and you can find it in PluginStore. ๐Ÿ˜„
                                      Download from PluginStore
                                        dezmo
                                        RC 2018_0521_1631
                                        • Bug: can't create BOM if there were T's, has been eliminated.
                                        • Small changes to rotate PomPi elements (and other group/component)
                                        • Indication of possible bend if the last point==first point in aided draw
                                        • More easy to put PomPi's into Pipe center line (xRay if hover on pipe, green color if on centerline)
                                          dezmo
                                          • SJS66S Offline
                                            SJS66
                                            Hi dezmo, awesome plugin. Just installed & took it for a test run & finally I can make pipes easily. I'd shout you a coffee & even some cookies but I need some paid work making pipes to afford it first ๐Ÿ˜‰ ๐Ÿ˜›
                                            • 3 / 3
