    [Plugin] PomPi (Pompous Piping 2016 RC2018 )
    47 Posts 10 Posters 44.9k Views 10 Watching
      dezmo
      @frederik said:
      In particular I like the way users can make their own libraries...
      The company I worked with used a special DIN and I always had to adjust radius for bends and length of reducers etc...
      With the option your plugin has, it's much easier... ๐Ÿ‘
      Yes. Thanks for nice words. And you are right this was the main goal to use external file as a dimensions, so you can quickly choose what you want. Sure, you can override it manually you don't need some dimensions so often.
      As you can see you can "play" a lot with parameters but at the end you can resize the UI to smaller and you can use as a "toolbar" only...
      (BTW when I'm finishing my work in Denmark ๐Ÿ˜‰ I'll try to make some "final tune" on PomPi and the user manual... but I still can't give a deadline... )
      Man can do everything. Only a matter of time and money.
      • FrederikF
        Frederik
        @dezmo said:
        ...my work in Denmark... )
        Your work in Denmark...?!?
        Where do you work in Denmark...?
        I'm based in Denmark and I'm working in the center of Copenhagen... ๐Ÿ˜„
        Cheers
        Kim Frederik
          dezmo
          I'm in the middle of nowhere... in industrial area. (Videbรฆk close to Herning)
          • FrederikF
            Frederik
            Aahhh... In Jylland... Far away from Copenhagen...
            But you're not Danish - right...?!
            Could have been fun to meet you and have a cup of coffee or a beer...
            Aahhh welll... Perhaps another time...
            Cheers
            Kim Frederik
              dezmo
              I'm Hungarian, currently living in Germany and traveling a lot. Maybe one time we can have some coffee... ๐Ÿ˜Ž
                dezmo
                Update in the first post:
                Changes: (2016_0711_2005)
                • The HTML UI tuned (horizontal UI removed)
                • User input check is massively improved
                  Note the input fields check still not 100% complete, be careful what you type in. If you got crash please report here!
                • Undo stack is more clear now
                • User manual updated
                • Other small improvement
                • clean up, reduce file sizes, typos etc...
                • small bugs, and other things what I don't remember...
                  If you are interested in French UI and manual in French, don't hesitate! ๐Ÿ˜„
                  Seems remember i have made the 3SKeng and site in French in the past for the fun! ๐Ÿ’š
                  (seems they have updated that! There is only rest the menu on the left! ๐Ÿ˜ฎ
                  For the UI I need a list or a multi-Language system, because I don't want to swim in the code! ๐Ÿ˜„
                    dezmo
                    Thanks a lot pilou!I am very grateful! ๐Ÿ˜„
                    But unfortunately the code itself is not prepared for more than 1 language. (yet?) But at least the manual can be useful... ๐Ÿ˜‰
                      French Manual! ๐Ÿ˜„
                        dezmo
                        @pilou said:
                        French Manual! ๐Ÿ˜„
                        What a nice surprise! Thanks! ๐Ÿ˜Ž ๐Ÿ˜„
                        I'll put it to the first post!
                        • FrederikF
                          Frederik
                          One thing I'm really missing is the ability to make bends other than 90 degree...
                          With the 3skeng you have the option to select the bend degree when connecting it to a pipe...
                          If I select the pipe and bend, I can't get i.e. a 45 degree angle...
                          Cheers
                          Kim Frederik
                            dezmo
                            Oh, yes. Originally it is designed to make perpendicular piping between two existing point, when I did not think even of the Pipe Auto function.
                            But I get the idea of "pipe auto" and started to work on it, than pipe&bend remained as it is.
                            The drawn line endpoint is the 90ยฐbend "other end" "horizontal" projection to be able to align to the next component. Right now the pipe length is the distance between picked point minus the bend radius. I do not know what should be the length if the angle is different than 90ยฐ, because the "end" face of the bend looking somewhere other direction than the length of the pipe+bend "height" (bend "height" = the bend two end face middle point distance.)
                            If I allowing to put other than 90ยฐ I have to calculate backwards somehow and I would heve to know in advance the "height" of the bend + pipe length.
                            Did you get my explanation, because I'm already lost... ๐Ÿ˜„
                            So lot of questions raises regards your "simple" request.
                            I'll see if I can do something... Currently I don't have any idea and my boss extended my work for (in) Denmark & the holiday season is also here... ๐Ÿ˜Ž
                            • FrederikF
                              Frederik
                              @dezmo said:
                              ...and my boss extended my work for (in) Denmark & the holiday season is also here... ๐Ÿ˜Ž
                              Nice to hear...
                              Too bad the weather is so bad this year...
                              Summer time can be great in Denmark, but this year we seem to have UK/Irish conditions... ๐Ÿ˜›
                              Cheers
                              Kim Frederik
                              • Z
                                zxin0410
                                I am use mac os.It works fine.But i think it would be great if the font could be bigger.
                                In high resolution screen,the fonts of user interface will be too small to use.
                                  dezmo
                                  Thanks for feedback from MAC!! ๐Ÿ‘
                                  Probably I will make a "style" with bigger font or button to change font size... or something like this, but definitely only after holiday season... sometime! โ˜€
                                    dezmo
                                    New version is updated to 1st and 2nd post.
                                    I hope, you will like it!
                                      Seems I must update the Pompi French site (this summer) ๐Ÿ˜‰
                                        dezmo
                                        ๐Ÿ˜Ž
                                        Ye, There were some changes... not that much in docu ๐Ÿ˜‰
                                        • jujuJ
                                          juju
                                          why has this not been submitted to the pluginstore?
                                            dezmo
                                            There are two reason:
                                              1. It is still test phase...(but maybe good enough to submit ๐Ÿ˜‰ )
                                              1. I don't have any clue how to submit. ๐Ÿ˜• Do you have an idea and/or link about the procedure?
                                                (Actually I have a plugin in the store, but that one submitted by somebody else...)
                                            • 2 / 3
