    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 97.8k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      Hello πŸ˜„ I'm author of Physically-Based Rendering (PBR) open-source extension for SketchUp.
      Features
      • Thanks to integrated material editor, enrich SketchUp materials with advanced properties like: metalness, roughness, normal map, height map, etc. What to bring reflections and reliefs to your models!
      • Add artificial lights right from SketchUp.
      • Visualize enriched SketchUp model in an external window.
      • Control scene camera in real-time.
      • Save render as a PNG image in two clicks.
      • Export enriched SketchUp model to glTF 3D format (Sketchfab...).
      License
      Funding
      If you find this plugin useful, donate at least 1 dollar to support its development. Thank you all! πŸ˜‰
      Download
      You will find installation instructions and a download link on the official page of SketchUp PBR plugin.
      Demos
      See attachments.
      Enjoy! πŸŽ‰
      A SketchUp model rendered without PBR extension
      Same SketchUp model rendered with PBR extension
      A virtual reef rendered with SketchUp PBR extension. Made with two faces, two materials and three textures.
      • filibisF Offline
        filibis
        Hi Samuel, interesting plugin, nice to see PBR and Gltf related extensions πŸ™‚
        But i couldn't operate normal map. And didn't understand where you put those 2 'base color' textures you provided.
        Also that would be great if you let normal map strength to be adjusted and option to add metallic & roughness maps as well if possible.
        • filibisF Offline
          filibis
          Thanks for the details.
          @samuel_t said:
          Normal map must be set in PBR Material Editor. Does this info helps you enough?
          I know πŸ™‚ what i meant was even though i apply normal map, it doesn't show up in web browser, object looks plain. (When i launch material editor again right after i applied normal map, it shows blank, does this mean it didn't accept the normal map?) Also i made sure it's 1024px etc.
          • samuel_tS Offline
            samuel_t
            No. PBR Material Editor doesn't show Normal map again... even if it has been accepted! I planned to change this ergonomic detail because it is confusing.
            Update: Since PBR plugin v1.2.0, status of texture image is shown (as checkbox) in PBR Material Editor.
            @filibis said:
            [...] even though i apply normal map, it doesn't show up in web browser, object looks plain.
            1. Close PBR Viewport (Web browser window).
            2. Set then apply Normal map in PBR Material Editor.
            3. Reopen PBR Viewport from SketchUp menu.
            4. If you still don't see Normal map effect, please report issue here: https://github.com/SamuelTS/SketchUp-PBR-Plugin/issues.
            • N Offline
              nlipovac
              Hi, since this can be prepared for posting on FB, can you make export for *.glb?
                Seems I've heard about this new thing somewhere! β˜€
                Seems a new cool rendering maker! 😎
                • samuel_tS Offline
                  samuel_t
                  Hi nlipovac,
                  PBR plugin only exports to *.gltf. Export to *.glb is not planned.
                  You can convert *.gltf to *.glb with Make GLB by Saurabh Bhatia.
                  FB doc: https://developers.facebook.com/docs/sharing/3d-posts/glb-tutorials
                  • samuel_tS Offline
                    samuel_t
                    I must render πŸ˜‰ unto Caesar the things that are Caesar's. Majority of 3D code included in PBR plugin was written by these talented people: Yi Shen and Natty.
                    • JQLJ Offline
                      JQL
                      I also like this plugin's idea a lot. I'm curious to where it's headed...
                      www.casca.pt
                      Visit us on facebook!
                      • samuel_tS Offline
                        samuel_t
                        A nice feature's coming soon. About camera control... Stay tuned πŸ˜‰
                        • samuel_tS Offline
                          samuel_t
                          Version 1.2.4 just released πŸ˜„
                          It's now possible to apply a metallic-roughness map to a material. Demos:
                          https://i62.servimg.com/u/f62/19/89/56/34/metal-10.jpg
                          https://i62.servimg.com/u/f62/19/89/56/34/vase_l10.jpg
                          Textures : Free PBR
                          Renderer : SketchUp PBR plugin
                          • JQLJ Offline
                            JQL
                            I'd love this if I could eventually link a substance file to a sketchup material...
                            www.casca.pt
                            • samuel_tS Offline
                              samuel_t
                              You can edit a material with PBR plugin then save material as .SKM file.
                              See this tutorial: https://sketchucation.com/resources/tutorials/528-how-to-create-your-own-sketchup-material-libraries
                              Thus, it's technically possible to build a SketchUp PBR material library πŸ˜‰
                              In other words, .SKM (SketchUp Material) can contain Normal map, etc.
                              • JQLJ Offline
                                JQL
                                The problem is that a sketchup material hasn't got a direct link to textures residing on disk. So, if I change a texture like color, normal or metal-roughness map, it won't refresh. Or, will it?
                                www.casca.pt
                                • JQLJ Offline
                                  JQL
                                  I have tried the plugin and got the following errors:
                                  Windows can't find 'nginx'...
                                  I have installed the glTF export (and import) plugins:
                                  It's easier for most users to have a separated roughness and metallic maps as they are very common, instead of the metallic-roughness map required by the plugin. I can easily create the metallic-roughness maps as I use substance tools, but is there any chance the separated maps could be implemeted?
                                  Also, I found you removed support for emissive materials, which would be a shame, as I use them for all my lighting applications in Thea for Sketchup and would find them cool to test on this pbr plugin.
                                  www.casca.pt
                                  • samuel_tS Offline
                                    samuel_t
                                    Is it a first time install or an update?
                                    If it's an update: Open SketchUp Extension Manager. Disable PBR plugin before uninstall it. Reinstall it.
                                    Let me know if problem persists πŸ˜‰
                                    • JQLJ Offline
                                      JQL
                                      It's a first time. Pbr v1.2.4
                                      Sketchup 2018
                                      www.casca.pt
                                      • samuel_tS Offline
                                        samuel_t
                                        Sketchup 2018
                                        Operating system: Windows 10?
                                        1. Open Windows's File Explorer.
                                        2. Goto %APPDATA%\SketchUp\SketchUp 2018\SketchUp\Plugins\pbr\Web Server
                                        3. Do you see the file nginx.exe?
                                        • samuel_tS Offline
                                          samuel_t
                                          I opened an issue for this: Emissive materials don't glow. It would be great if a GLSL expert could help.
                                          • JQLJ Offline
                                            JQL
                                            I'm afk today (phone here) but I'm on win10 and I have checked before that the nginx.exe file was there, though I don't know if that was the exact path.
                                            www.casca.pt
                                            • 1 / 6
