    LO: dimension units
    layout
    4 Posts 3 Posters 3.3k Views 3 Watching
    • jujuJ Offline
      juju
      How do you switch off the dimension units in LO?
      In my case, when I use millimeter I don't really want the mm behind every dimension.
        shawb
        In the Dimension style tab there is a 'Display units' box at the right hand side to do this. Select the dimension tool first and then go to the dim style tab and click the box. Dims will now not show the unit suffix until you re-click on the box.
        Hope this helps!
        • jujuJ Offline
          juju
          Wow, thanks, I completely misread what that box does. To me it looked like the toggle between different types of dimensioning (imperial vs. metric).
            There's a lot more to that window than just setting the units and whether or not the units are displayed. You should check out the other buttons.
