    Texture Color Change On 3dsmax While Importing from sketchup
    2 Posts 2 Posters 755 Views 2 Watching
      denden_mn
      Hello Guys !
      I Have a problem with my model sketchup.
      I save my sketchup model as usual, ex: model.skp then i change my color material in sktehcup (trough match color object)
      and then i import my sketchup model from 3dsmax, but the problem is my texture color model in 3dsmax has change to the original version (before i change material color).
      so is there any solution to fix this.
      thank's for Replying
      and
      thank's before
      • GD3DesignG Offline
        GD3Design
        You may need to look at your 'gamma and LUT' settings. Specifically, the 'affect color picker' check box. You may be operating in 2 different color spaces. Could need to change the gamma. Look into 'linear workflow'...(and if it is new to you...get prepared to be very confused!)
