    Automatic walls, doors & windows
    55 Posts 13 Posters 38.1k Views 13 Watching
    • facerF
      facer
      Garage doors as noted in the list of types shows feet.
      I was curious as to why, but you have explained the reason in your last post.
        db11
        @facer said:
        Why did your use imperial dimensions to identify windows and doors?
        Canada is metric I believe, is Quebec an exception? ๐Ÿ˜„
        Not sure whether it's due to our proximity / trading relationship with US, or simply industrial inertia, but the vast majority of building materials are still made / spec'd to Imperial units.
        So to work/live here in QC, we need to be bilingual in dimensions as well as language ๐Ÿ˜‰
        • K
          KrisM
          Canada is a great place - You better be bilingual so to speak -
          We build a house in mostly imperial
          We draw the site plan in metric.
          We do the foundation forming in imperial.
          We order the concrete in metric.
          We frame everything in imperial.
          We order the windows sometimes in imperial, sometimes in metric.
          We order doors in imperial.
          The surveyor locates the house in metric.
          We order the backfill in imperial.
          Of course, if you do anything for the government, you do it all in metric.
          Keeps you on your toes.
          • facerF
            facer
            Given the rise of China and India and the subsequent increase in competition, I expect more component manufacturing companies in America will adopt the Metric System in manufacturing their products.
            Building components are likely to increasingly be manufactured in metric dimensions for construction
            while giving imperial dimensions for an ever diminishing number of users in America.
            For Sketchup plugin components I would suggest providing metric dimensions in brackets for all door, window, and construction components. ๐Ÿ˜„
            International Measuring System of Units by Country
            This map shows the international measuring system of units and the chronology of the advance of metric usage around the world.
            [highlight=#ffff40:fvva54up]Only three countries - Burma, Liberia, and the United States[/highlight:fvva54up]- have yet to adopt the International System of Units as their official system of measurement (weights and measures).
            Although use of the metric system has been sanctioned by law in the US since 1866, it has been slow in displacing the American adaptation of the British Imperial System known as the US Customary System.
            The US is the only industrialized nation that does not mainly use the metric system in its commercial and standards activities. At the same time, the US Armed Forces and medical and scientific communities do use metric measurements exclusively (including for nutritional information of consumer goods and drugs), and there is increasing acceptance many other sectors of industry.
            • medeekM
              medeek
              In high school (British Columbia) we learned everything in metric (Physics), then when I went to BYU for college it was mostly imperial but we also did metric as well. It was a bit tough getting used to the imperial units from an engineering standpoint but I already had an intuitive feel pounds, tons and units of volume like quarts, gallons etc...
              To this day I still can't keep straight the conversions between pints, quarts, cups, TBSP, tsp, ounces etc... what a mumbly jumbly mess.
              The English are just as bad, they say they converted to metric but then they start talking about "Stones" when they weigh you.
              In the construction industry I don't think you are going to convert the US market over to metric anytime soon.
              Nathaniel P. Wilkerson PE
              Medeek Engineering Inc
              design.medeek.com
                mics_54
                In America we pretty much use both metric and imperial systems. You all should try and catch up ๐Ÿ˜ฎ
                • mariochaM
                  mariocha
                  UPDATE
                  V5 ! Now create windows on demand. Much, much more flexible. Automatic naming. Wood grain oriented. No need for dynamic components for windows anymore.
                  Doors will follow later.
                  English and French are updated. Others will follow.
                  Works in any units.
                  %(#008000)[Mario C.
                  • mariochaM
                    mariocha
                    McF3D v5 updated to 5.01
                    To correct a little 1/4" offset in glass panes.
                    %(#008000)[Mario C.
                    • mariochaM
                      mariocha
                      Updated to v5.02
                      To let the sun through the openings.
                      And to make signature stay.
                      %(#008000)[Mario C.
                      • jujuJ
                        juju
                        For interest sake: kindly construct a cavity wall, insert either door or window, place a section through horizontally and vertically. Show the results here. The reason I ask is because I have yet to find something that will cut this type of opening (and close the cavity) correctly. There is always hope...
                        • mariochaM
                          mariocha
                          Well Juju, my video shows a wall made of a simple box. That works fine, using the fill section feature of Styles, SU21018.
                          Do you mean with wall finish thickness on both side ?
                          %(#008000)[Mario C.
                          • mariochaM
                            mariocha
                            Update 5.1 !!
                            After Windows on demand,
                            introducing Doors on demand.
                            A first set of interior doors. Plain and multiple glass panes.
                            Each has opened and closed doors on respective layers.
                            Wood grain respectful !
                            Ask if you need a particular door. Maybe I can add it.
                            %(#008000)[Mario C.
                            • jujuJ
                              juju
                              As stated, more complex walls are of interest. Simple block ones are not a problem at all.
                              • mariochaM
                                mariocha
                                How more complex ?
                                What purpose ?
                                An example ?
                                %(#008000)[Mario C.
                                • jujuJ
                                  juju
                                  @mariocha said:
                                  How more complex ?
                                  Probably at least 2 - 5 entities deep (depending on specifications and the way one models), may or may not be different groups on different layers.
                                  @mariocha said:
                                  What purpose ?
                                  I would have thought that was self evident? So you can pick your door/window, insert it into the wall with it cutting the hole through all of the various entities automatically; not only healing the geometry, but also construct the reveal geometry. That way you don't have to generate the additional geometry manually (and change it manually should size / position change).
                                  Hopefully something could be worked out so one can include the lintels also being automatically generated and inserted.
                                  Would also love to be able to pre-determine the layers the groups for the various geometries will be assigned to (for when you're working on a layering template).
                                  @mariocha said:
                                  An example ?
                                  • mariochaM
                                    mariocha
                                    Ah I see. Purpose is construction docs.
                                    No I do not want to go there. I left that way of producing docs.
                                    Now I do simple walls (ease of design) and the complex things are shown later on details (ease of change)
                                    And if the details impact on the walls, being simple makes them easy to adjust.
                                    %(#008000)[Mario C.
                                    • mariochaM
                                      mariocha
                                      EXTERIOR DOORS: first set. Includes sidelights & transom.
                                      %(#008000)[Mario C.
                                      • mariochaM
                                        mariocha
                                        Better Doors on Rail (suspended) and Multiple Glass now even spaced.
                                        %(#008000)[Mario C.
                                        • Bob JamesB
                                          Bob James
                                          @__juju__
                                          I think the awesomely detailed construction extensions being created by Nathaniel Wilkerson (medeek) is what you're looking for.
                                          • jujuJ
                                            juju
                                            @bob james said:
                                            @__juju__
                                            Hi Bob, I agree that Nathaniel makes some really great extensions and he's extremely dedicated. I am keeping an eye on his new wall framing extension (in beta 0.74 now I believe), but we don't really use that method of construction where I'm at.
                                            I'll have to look and see what can be done with it, but I think I'm kinda stuck with what I want / need at the moment. I use Profile Builder 2 (by whaat, another of the many great coders) for walls and such which helps speed things up.
                                            I'm starting to think one of the solutions would be not to create walls as they're built, thus as a single volume, but this doesn't communicate correctly on the construction documentation. I also use Skalp 3 (by layer method) and am hoping that they will be able to develop their Pattern Designer so I can create a complex pattern to represent a complex / cavity wall when cutting through a single volume wall.
                                            • 1 / 3
