    [Plugin] jsMoveTool [updated to v2014]
    25 Posts 10 Posters 7.3k Views 10 Watching
    • guanjinG Offline
      guanjin
      Convenient and practical tool πŸ‘
        Jorgensen
        Hi Pixero
        a nice small tool, and i use it often.
        but at work, it won't detect the arrowkeys πŸ˜•
        i can start the plugin by using alt+arrow down - it does activate and i can enter a distance, but then nothing happens πŸ˜•
        at home it works just fine.
        i use sketchup 2015, both at home and at work, and windows 7 at work, windows 10 at home.
        i have tried to reset shortcuts, but that did not help πŸ˜•
        does anyone know what the problem could be?
        thanks
        jorgensen
        • JQLJ Offline
          JQL
          I always thought this would be handy but never knew this tool existed until now. Thanks!
          www.casca.pt
          Visit us on facebook!
          • PixeroP Offline
            Pixero
            @ Jorgensen
            Select the object you want to move and choose the JS Move Tool.
            Then enter the distance and press enter/return. Then it should work.
              Jorgensen
              hi pixero
              i can use it at home - so i don't think it's a user-error 😐
              mayby it's a conflict with an other plugin?
              i get this message in the ruby console as soon as i press an arrow key.
              Error: #<TypeError: no implicit conversion to float from nil>
              C:/Users/brj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jsMoveTool.rb:167:in initialize' C:/Users/brj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jsMoveTool.rb:167:in new'
              C:/Users/brj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jsMoveTool.rb:167:in block in onKeyDown' C:/Users/brj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jsMoveTool.rb:85:in each'
              C:/Users/brj/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/jsMoveTool.rb:85:in `onKeyDown'
                Since it's the same user, same plugin and same version of SketchUp, I wonder if it could be an issue of operating system? SU2015 isn't fully compatible with Win 10.
                Try it with SU2016?
                  TBoy
                  Is it possible this tool to be activated WHILE a keyboard button is pressed (and deactivated after release of the button)?
                  (or another similar tools like "Key Rotate" by Kyyu.)
                    Jorgensen
                    Does anyone know if this plugin should work with sketchup 2018?
                    Jorgensen
                    • PixeroP Offline
                      Pixero
                      Just installed and tested and it works fine for me with SU 2018.
                        Jorgensen
                        I think i get the same errors as before - not sure why - i have used before with no problems.
                          Garyvn
                          and i was about to write my first plugin to do this:)... well I guess I will just have to do a LAYOUT equivalent... this NUDGE capability has been a standard CORELDRAW interface capability for many years and is really handy ... should be built into the SU/LO interface as standard.. thanks for this plugin
                            LayOut has had nudge capability since it was released.
                              Jorgensen
                              hi @pixero
                              I have used this plugin for years and it's have been a great tool.
                              Now I i've been updated to a new laptop and I can't get the plugin to work.
                              I can activte the plugin, add a distance, but nothing happens when i use the arrow keys.
                              The only difference i have from the old computer and this one, seems to be that i need to use . instead of using , when i enter numbers.
                              Can that course the issue?
                              I have inserted output from the ruby console.
                              Jorgensen
                              C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in initialize' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in new'
                              C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in block in onKeyDown' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in each'
                              C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in onKeyDown' Error: #<TypeError: no implicit conversion to float from nil> C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in initialize'
                              C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in new' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in block in onKeyDown'
                              C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in each' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in onKeyDown'
                              • PixeroP Offline
                                Pixero
                                Did you press enter before using the arrow keys?
                                I just tried installing on a fresh version of SU 2018 and it worked just fine here.
                                Could it perhaps be a conflict with some of your other plugins?
                                  Jorgensen
                                  hi pixero
                                  I'm pressing enter after i set the distance.
                                  The plugin as worked all the time on other computers, but not on this one.
                                  Are you also using . instead of , ? i have never had an installation before where i need to use . as a decimal separator.
                                  Jorgensen
                                    Jorgensen
                                    Hi Pixero
                                    I searched the jsmovetool.rb, deleted two instances, and installed via extension store.
                                    Now it works πŸ˜„
                                    Jorgensen
                                    • PixeroP Offline
                                      Pixero
                                      Great!
                                        jamessf69
                                        Thank you so much for this, what a boon! I don't know why this isn't built into Sketchup as a default.
                                        Again, thank you so much, it really helps!
