    [Plugin] jsMoveTool [updated to v2014]
    25 Posts 10 Posters 7.0k Views 10 Watching
      TBoy
      Is it possible this tool to be activated WHILE a keyboard button is pressed (and deactivated after release of the button)?
      (or another similar tools like "Key Rotate" by Kyyu.)
        Jorgensen
        Does anyone know if this plugin should work with sketchup 2018?
        Jorgensen
        • PixeroP Offline
          Pixero
          Just installed and tested and it works fine for me with SU 2018.
            Jorgensen
            I think i get the same errors as before - not sure why - i have used before with no problems.
              Garyvn
              and i was about to write my first plugin to do this:)... well I guess I will just have to do a LAYOUT equivalent... this NUDGE capability has been a standard CORELDRAW interface capability for many years and is really handy ... should be built into the SU/LO interface as standard.. thanks for this plugin
                LayOut has had nudge capability since it was released.
                  Jorgensen
                  hi @pixero
                  I have used this plugin for years and it's have been a great tool.
                  Now I i've been updated to a new laptop and I can't get the plugin to work.
                  I can activte the plugin, add a distance, but nothing happens when i use the arrow keys.
                  The only difference i have from the old computer and this one, seems to be that i need to use . instead of using , when i enter numbers.
                  Can that course the issue?
                  I have inserted output from the ruby console.
                  Jorgensen
                  Error: #<TypeError: no implicit conversion to float from nil>
                  C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in initialize' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in new'
                  C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in block in onKeyDown' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in each'
                  C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in onKeyDown' Error: #<TypeError: no implicit conversion to float from nil> C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in initialize'
                  C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in new' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:167:in block in onKeyDown'
                  C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in each' C:/ProgramData/SketchUp/SketchUp 2018/SketchUp/Plugins/jsMoveTool.rb:85:in onKeyDown'
                  • PixeroP Offline
                    Pixero
                    Did you press enter before using the arrow keys?
                    I just tried installing on a fresh version of SU 2018 and it worked just fine here.
                    Could it perhaps be a conflict with some of your other plugins?
                      Jorgensen
                      hi pixero
                      I'm pressing enter after i set the distance.
                      The plugin as worked all the time on other computers, but not on this one.
                      Are you also using . instead of , ? i have never had an installation before where i need to use . as a decimal separator.
                      Jorgensen
                        Jorgensen
                        Hi Pixero
                        I searched the jsmovetool.rb, deleted two instances, and installed via extension store.
                        Now it works πŸ˜„
                        Jorgensen
                        • PixeroP Offline
                          Pixero
                          Great!
                            jamessf69
                            Thank you so much for this, what a boon! I don't know why this isn't built into Sketchup as a default.
                            Again, thank you so much, it really helps!
                            • 2 / 2
