    Missing Imported Component
    4 Posts 4 Posters 2.2k Views 4 Watching
    • V Offline
      vedant88
      I'm importing dxf/dwg file which is converted through imgtocad converter but after importing it's not visible. PLease tell how to see it.
        pcmoor
        zoom all?
        did you apply options?
          slbaumgartner
          Did you try zoom-extents? Very often dwg contents are placed very far from the model origin and as @pcmoor observed unless you set options to not preserve origin they will be way off screen after the import. Also, there are some kinds of contents that the importer does not capture. Text and items that depend on CAD extensions are two examples.
          • gillesG Offline
            gilles
            Open a new file, import the component then open the Outliner it should be there as far as it is not raw geometry.
