    Big scene - Sketchup crashing all the time
    9 Posts 4 Posters 3.7k Views 4 Watching
      ark
      Lately I've begun using Sketchup for rendering (using Thea plugin for Sketchup), and as the scene gets bigger sketchup is struggling to handle it.
      Where is the bottleneck...? My PC is brand new with a strong GPU, CPU and a 32Gb ram!
      David
        Specifics? What kind of graphics card? What operating system? Windows 10?
        Are you using SU8 as your profile indicates? In SketchUp's Preferences>OpenGL, do you have Hardware Acceleration enabled or disabled? How big is the SketchUp file? Have you tried purging unused?
          ark
          Yes... of course πŸ€“
          CPU: Core i7-8700K 3.7GHz
          Primary GPU: Geforce GTX 1080 Ti 11Gb (For the screens)
          Secondary GPU: Geforce GTX TITAN Black 6Gb (Dedicated to Thea - no screens connected)
          System ram: 32Gb
          OS: Windows 10 Pro
          Sketchup: 2018 Pro
          • PixeroP Offline
            Pixero
            How heavy (MB) is your scene?
            I have successfully worked with SketchUp files that was about 650 MB.
            Grouping lose geometry and using layers to show/hide stuff while working is a good practise.
            If the SketchUp file is somehow acting weird it could work to start a new SketchUp file and copy every thing over to it.
              ark
              Well the scene is only 244 MB, so it shouldn't be to bad...
              I've attached some sunset renders (no post processing yet!) so you can see the scene.
              • soloS Offline
                Can you screen capture the SU model? me thinks the vegetation may be the issue.
                • PixeroP Offline
                  Pixero
                  Are you using Skatter for the grass and trees? If so, have you checked "Render only" to keep the SU file lighter.
                    ark
                    For the vegetation I used Skatter and Thea instances. Only a couple of plants on the terrace are full models.
                    • PixeroP Offline
                      Pixero
                      If you are using very large textures these might help:
                      http://sketchucation.com/forums/viewtopic.php?p=281153#p281153
                      https://sketchucation.com/forums/viewtopic.php?f=323&t=40720
