    Update extensions alert
    13 Posts 5 Posters 4.2k Views 5 Watching
    • BoxB
      Click Manage at the top to go to the manage tab, then scroll down till you see a highlighted Update button.
      • bazB
        baz
        I get this every time I start SU. Says TT_Lib2 by ThomThom needs updating, then says unable to read file extension.
        I have the latest version anyway, annoying.
        Now I ignore it and it goes away after a few seconds.
        • BoxB
          Baz I would suggest you go to the Extension Warehouse in a browser and sign in again. Then your auto update should work again.
          Or you could try signing out and in again from within SU using the icon in the bottom left corner.
          • bazB
            baz
            That worked.
            Thanks Box.
            PS: How is the Glass sculpture going, haven't seen an update for a while.
            • BoxB
              It's in the final stages, in other words, sitting lonely in a warehouse waiting for engineers to understand what is needed and for them to produce the drawing (from my detailed SU Model) so we can fabricate some steel work. I would just go ahead and do it myself but as it's a 'Public Sculpture' it has to have proper documentation blah blah blah
              • bazB
                baz
                Yeah, been there...pita.
                  drafter
                  Every so often, about 2 weeks maybe, I'm alerted to update plugins that are not even available; Trimble Connect [pro only] & Advanced camera tools [pro only]. It's just a little annoying. The option to uninstall is given, but they are not installed.
                    You can ignore the message that pops up when SketchUp starts. It's a very small thing and only lasts a few seconds and it doesn't keep you from getting started on your model.
                    • T
                      TBoy
                      @dave r said:
                      You can ignore the message that pops up when SketchUp starts. It's a very small thing and only lasts a few seconds.
                      Unique solution!
                      Really helpful.
                      • BoxB
                        You could pay for the Pro version then it wouldn't bother you.
                          drafter
                          And I thought it might be something important....gee wiz...
                            Yeah. I understand. You might check the Extension Manager once in awhile to see if there are any extensions that are important to you to upgrade. Upgrade them. Do the same with the Sketchucation Extension Store tool. Fredo's updated a number of his extensions recently as well as his Lib_Fredo6 support files. If you have them and installed them with the SCF Extension Store tool, it'll show you that there are updates and you can let it update all of them automatically.
