๐Ÿค‘ 30% Off | Artisan 2 on sale until April 30th Buy Now
Looking for a plugin to make studs
14 Posts 7 Posters 857 Views
    Pixero
    Are there any plugins that can turn a face to a series of evenly spaced studs?
    (Not shure of the correct english name.)
    It should keep the contours of the face like in the example image below.
    I have tried TIGs Slicer but it does a lot of things I dont need/want so I'm just wondering if there are any other plugins to do this?
      rodman100
      http://www.1001bit.com/ - the Joist option in the 1001 bit tools plugin. Not exactly what you are looking for but may be useful... see video attached
      1001 bit tools.avi
        Slice by SU4You ?
        Objects can be Groups, "grouped", "Components" (will be separed) or "nothing" ! ๐Ÿ‘
        In fact it takes anything! ๐Ÿ˜„
        Trick : for erase the "Bottom" Just start from the left! ๐Ÿ‘
        Video start from the right so "Top" is erased! ๐Ÿค“
        Many possibilities of parameters! A true gem! ๐Ÿ˜Ž
          Pixero
          @rodman100: The 1001 tools works pretty well but dont take holes (windows) into the calculation.
          @Pilou: Meedek truss is not quite what I'm after and the S4U slice is a great cutter but it's the part of creating the "studs" that I'm interested in.
          Keep them coming...surely there must already exist a plugin for this?
            I believe The Medeek Truss plugin makes that!
            But you must cut yourself with one click + line!
            Minute 4.40
              Have a look at Face to frame.
              https://sketchucation.com/pluginstore?pln=Face_to_Frame
                Edge tools by Thomthom ?
                  Not sure that Face to Frame makes the "trapezoรฏd" ?
                  A possible workflow can be
                  Edges Tools by Thomthom
                  Keep the vertical lines
                  S4u to Components (maybe a resize vertical + rotation ๐Ÿ˜„
                  (here the right module is a Goup ! )
                  Then s4u slice because each stud is not "troncated" ๐Ÿ˜„ (see video above)
                    Maybe better!
                    It's truncated from a rectangular box ! ๐Ÿ˜„
                    Just now find a trick for resize! ๐Ÿ˜„
                      rv1974
                      s4u has the gift to answer the real (3D monkeys) needs in most effectiveway.
                      Love almost all hiss stuff
                        Make a Component of 2 Components red & white (name the white one "bub")
                        Select All
                        S4u to components "Face to component Arrange"
                        Explode one time
                        Select by Name bub on the Onliner
                        Erase them
                        et voilร  ๐Ÿ˜„
                        All studs are troncated (here Up and down) as wanted if start surface with hole(s) is very trapezoรฏdal! ๐Ÿ˜„
                        Click image for animation! ๐Ÿ˜„
                          jolran
                          You could maybe try 2dBoolean for this. To me it looks exactly what you want.
                          A Picture might explain better.
                          Note that the Component instances are flat (2d).
                            You could use the Solid Tools to do this, too.
                              Pixero
                              Thats quite a lot of suggestions.
                              Will have to try them out but at a glance the 2d boolean looks promising.
