    Looking for a plugin to make studs
    14 Posts 7 Posters 1.0k Views 7 Watching
    • PixeroP Offline
      Pixero
      Are there any plugins that can turn a face to a series of evenly spaced studs?
      (Not shure of the correct english name.)
      It should keep the contours of the face like in the example image below.
      I have tried TIGs Slicer but it does a lot of things I dont need/want so I'm just wondering if there are any other plugins to do this?
        rodman100
        http://www.1001bit.com/ - the Joist option in the 1001 bit tools plugin. Not exactly what you are looking for but may be useful... see video attached
        1001 bit tools.avi
          Slice by SU4You ?
          Objects can be Groups, "grouped", "Components" (will be separed) or "nothing" ! ๐Ÿ‘
          In fact it takes anything! ๐Ÿ˜„
          Trick : for erase the "Bottom" Just start from the left! ๐Ÿ‘
          Video start from the right so "Top" is erased! ๐Ÿค“
          Many possibilities of parameters! A true gem! ๐Ÿ˜Ž
          • PixeroP Offline
            Pixero
            @rodman100: The 1001 tools works pretty well but dont take holes (windows) into the calculation.
            @Pilou: Meedek truss is not quite what I'm after and the S4U slice is a great cutter but it's the part of creating the "studs" that I'm interested in.
            Keep them coming...surely there must already exist a plugin for this?
              I believe The Medeek Truss plugin makes that!
              But you must cut yourself with one click + line!
              Minute 4.40
              • BoxB Offline
                Have a look at Face to frame.
                https://sketchucation.com/pluginstore?pln=Face_to_Frame
                  Edge tools by Thomthom ?
                    Not sure that Face to Frame makes the "trapezoรฏd" ?
                    A possible workflow can be
                    Edges Tools by Thomthom
                    Keep the vertical lines
                    S4u to Components (maybe a resize vertical + rotation ๐Ÿ˜„
                    (here the right module is a Goup ! )
                    Then s4u slice because each stud is not "troncated" ๐Ÿ˜„ (see video above)
                      Maybe better!
                      It's truncated from a rectangular box ! ๐Ÿ˜„
                      Just now find a trick for resize! ๐Ÿ˜„
                        rv1974
                        s4u has the gift to answer the real (3D monkeys) needs in most effectiveway.
                        Love almost all hiss stuff
                          Make a Component of 2 Components red & white (name the white one "bub")
                          Select All
                          S4u to components "Face to component Arrange"
                          Explode one time
                          Select by Name bub on the Onliner
                          Erase them
                          et voilร  ๐Ÿ˜„
                          All studs are troncated (here Up and down) as wanted if start surface with hole(s) is very trapezoรฏdal! ๐Ÿ˜„
                          Click image for animation! ๐Ÿ˜„
                          • jolranJ Offline
                            jolran
                            You could maybe try 2dBoolean for this. To me it looks exactly what you want.
                            A Picture might explain better.
                            Note that the Component instances are flat (2d).
                              You could use the Solid Tools to do this, too.
                              • PixeroP Offline
                                Pixero
                                Thats quite a lot of suggestions.
                                Will have to try them out but at a glance the 2d boolean looks promising.
