    Sending To Layout
    layout
    28 Posts 4 Posters 10.1k Views 4 Watching
    • Joe WoodJ
      Joe Wood
      OK found the dimensions in the tray, but when I changed it to cm, all the dimensions are wrong? The SUp model was set to the same cm scale.
      here's the skp file!
      France 2b.skp
      Joe Wood
      woodsshop.com/
      • C
        Charlie__V
        [attachment=5:3e349nvu]<!-- ia5 -->9 Untitled.png<!-- ia5 -->[/attachment:3e349nvu]
        Joe,
        I get 301.93cm for the over all rafter length in both Sketchup Model and Layout file.
        please see attached. [attachment=1:3e349nvu]<!-- ia1 -->France 2b_LO_V15.layout<!-- ia1 -->[/attachment:3e349nvu]
        PS....in my above simple example the SU model units are in fractional inches and LO model viewport scale @ 1" = 1'-0" [1:12]........I used LO dimensions to illustrate you could leave your native model set to imperial, yet still document & dimension an imperial model to metric (cm/other) in LO. (Rt. click LO viewport..open w/Sketchup to view SU model)
        [attachment=0:3e349nvu]<!-- ia0 -->Scale_Test_SUImperial_to_LOMetric_V15.layout<!-- ia0 -->[/attachment:3e349nvu]
        Charlie
        • Joe WoodJ
          Joe Wood
          I'm not completely getting all of this but seems like I'm close πŸ™‚
          but why are these dimensions off?
          1 rafters.layout
          Joe Wood
          woodsshop.com/
          • C
            Charlie__V
            @joe wood said:
            I'm not completely getting all of this but seems like I'm close πŸ˜„
            Joe,
            Maybe I am not following still?
            In the attached model I have set the LO file to imperial and set all viewports to 1"=1'-0" (1:12)(regardless of SU model units)
            So, your original SU model in LO appears fist.
            I extracted one rafter and dimensioned it in SU after setting model units in SU to Metric.
            I then saved this same model and changed the SU model units to Imperial.
            Inserted both of these models below your original model in LO
            You can now see a representation of both Metric and Imperial (both dimensioned in SU) within the attached LO file. 1 rafters_Imp_Metric_LOFile_Units_Imp_V15.layout
            Note: always make sure "preserve scale on resize" box is ticked in the SU model palate.
            Hope this all makes sense.
            Charlie
            • Joe WoodJ
              Joe Wood
              I dimensioned this before sending to layout, it measures accurately with PCon but then another I did also measured correctly, but not to my client.
              how does this one look and measure?
              1 Untitled.dwg
              Joe Wood
              woodsshop.com/
              • Joe WoodJ
                Joe Wood
                The next Scene I'm trying is much larger and the 1" = 1' scale doesn't work at all.
                this is the scene
                how do I figure out which scale to use? None seem to fit the viewport.
                1/4 = 1" was the only one that fit it to inside the viewport but the scale was way off ..
                Joe Wood
                woodsshop.com/
                • C
                  Charlie__V
                  Joe,
                  Assuming this is all still in the context of the Metric (French client) I would set the LO page size to Metric, all the LO SU viewport scaling to Metric, and of course LO dimensions in Metric.
                  (you should not have to worry about the Sketchup model being metric, unless you will show dimensioning "in" the SU model in the LO viewport)
                  You will have to increase the paper size to accommodate lager parts of your model.(and larger viewports based on scale(s) selected)
                  In the attached file I have set the file units/page/dimensions/viewport scaling to metric.
                  (please see note in box bottom right corner of page)JoeWood_C3Paper_Metric_Cm_Scale_1_10_LO_V15.layout
                  Here is another page size "C2" with viewport scales of 1mm = 10mm(1:10) & 1mm = 20mm(1:20)
                  JoeWood_C2Paper_Metric_Cm_Scale_1_10_20_LO_V15.layout
                  Charlie
                  Note;
                  Most of my work is US/Architectural/Imperial and mostly ΒΌ" scale and almost always page size of Arch D 24"x36"
                  Maybe our friends in and around France can recommend "typical" sheet size and scaling for a project like your so you can potentially save yourself from having to resize/scale all of you pages.(if not "standard" in france)
                  • Joe WoodJ
                    Joe Wood
                    Thanks again Charlie, I'll try it again,
                    you know, I'm not trying to get a specific scale on paper, all I need is for my French client to be able to get accurate dimensions off of the dwg file.
                    so is this dwg I posted ealier, accurate now?
                    1 Untitled(1).dwg
                    Joe Wood
                    woodsshop.com/
                    • C
                      Charlie__V
                      In the cad software I am using it is, but you may want others to further verify.
                      • Joe WoodJ
                        Joe Wood
                        OK, let's hope that last one is correct! I used 1" = 1'.
                        My next Scene is covers more area then the last, with a page size of roughly 850 x 530 cm. I Temp drew in those dimensions here
                        how do I go about figuring the page size and scale for this one? Remember I just want an accurate dwg file to measure and not an accurate scale printed drawing.
                        Joe Wood
                        woodsshop.com/
                        • C
                          Charlie__V
                          [attachment=1:396j2cay]<!-- ia1 -->1 Next One.png<!-- ia1 -->[/attachment:396j2cay]
                          Joe,
                          I was trying to steer you into setting up a scaled set of documents for a number of reasons, but mainly as a way to for you to convey the information from your original drawings/model as you intended.
                          Having a dimensioned .pdf file for the client and you to refer to for example helps you from having to answer for any(client)mistakes unintended or otherwise while manipulating the .dwg you have provided.
                          That said, It appears you want to still try to export to 1:1 and there is a limitation as to sheet size in LO 508cm x 508cm I believe (200"x200" Imperial...LO Version 2018...maybe same in LO V2015?)[attachment=0:396j2cay]<!-- ia0 -->JoeWood_Page_508cmx508cm_LO_V15.layout<!-- ia0 -->[/attachment:396j2cay]
                          That limitation will not allow for 1:1 scale, so as I suggested earlier it would be best to pick a Metric scale and a sheet size you can live with....even though you are not interested in printing the pages.
                          Best regards,
                          Charlie
                          • Joe WoodJ
                            Joe Wood
                            I'm sorry Folks, especially Charlie, but I'm just not getting this. Al I want to do with about 6 diff scenes is export a dwg that's to correct scale for my client.
                            Been working all day on this and no closer.
                            I wish we could just figure out why I can't export correct scale dwgs right from SUp ..
                            http://sketchucation.com/forums/viewtopic.php?f=15&t=68904&p=629858#p629858
                            Joe Wood
                            woodsshop.com/
                            • 2 / 2
