    3D Truss Models
    1.5k Posts 31 Posters 978.1k Views 30 Watching
      glro
      @medeek said:
      I am trying to understand how the Mac .plist file works. Is it similar to the registry? I have a client that is having some trouble with registering (inputting their serial into the global settings) and having their system save the serial number.
      Unfortunately, I don't own a Mac so I am not much help. Does anyone use the plugin on a Mac and have had similar problems with saving the serial number? Where does one go to manually edit the .plist file and enter in the serial number manually.
      not only that
      i had the same questions
      so i bought a mac: https://en.wikipedia.org/wiki/Mac_Mini
      sheap, you can use windows mouse, keyboard and screen
      there are a few things to modify in the ruby code por windows, to make it work on a mac
      • medeekM Offline
        medeek
        I am working on adding the heel blocking since it is an option listed in the advanced options.
        http://design.medeek.com/resources/images/truss_su324_800.jpg
        So far there has not been much call for this feature but a few people have inquired so I figured we might as well add it in for completeness. The red coloration is for clarity in the image above.
        I will probably add the option to allow for venting holes since this is fairly typical in my neck of the woods.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • pbacotP Offline
          Very important. Sometimes the heel blocking, when taller, is a truss manufactured square that might have sheathing.
          • medeekM Offline
            medeek
            I agree, I was investigating this a while back but I'm not sure yet what is standard practice, there could be a number of ways of handling this.
            http://res.cloudinary.com/engineering-com/image/upload/v1484676854/tips/SHEAR_PANELS_ego3xz.jpg
            http://res.cloudinary.com/engineering-com/image/upload/v1484694321/tips/SHEAR_PANELS2_vis1pr.jpg
            design.medeek.com
            • pbacotP Offline
              Those look nice. I think sometimes the truss blocking has a diagonal which would make it effective (but the engineer will want plywood on it anyway it seems). You can have the truss all the way to the top or the method you show allows (1) continuous plywood gets nailed to the top of the truss block and the solid block provides the shear nailing (2) sometimes decorative rafter tails are added which need to pass through the space above the truss block.
              • medeekM Offline
                medeek
                Featured on the SketchUp Extension Inspection:
                design.medeek.com
                  Very enlighting video! 😎
                  else (Always : https://trussfr.weebly.com 😉
                  Truss Type = Type de Fermes
                  (not sure to translate all names of this little list of part of trusses)
                  King Post
                  Queen Post
                  Fink
                  Howe
                  Fan
                  Mod Queen
                  Double Fink
                  Double Howe
                  Mod Fan
                  Triple Fink
                  Quad Fink
                  Out-to-Out Span = Portée Hors tout
                  Top Chord Angle = Angle de Corde Supérieure (?)
                  Overhang Left = Porte-à-faux Gauche
                  Overhang Right   (Same as Left) = Porte-à-faux Droit (Identique au Gauche)
                  TC Size = Taille TC (? à définir)
                  BC Size = Taille BC (? à définir)
                  Web Size = Taille (?)
                  Ply Thickness = Epaisseur du Pli
                  Raised Heel (No, Yes) =Talon surélevé (?) ( (Non, Oui)
                  Heel Heigh = Hauteur du Talon (?)
                  Bldg.lenght = Longueur Bâtiment
                  Truss Spacing = Espacement de Ferme
                  Gable End Trusses (Yes, No, Front) = Poutrelles d'extrémité (Oui, Non, Face Avant)
                  Gable Stud Spacing = Espacement Goujons de Pignon (?)
                  Adv. Roof Options (Yes, No) = Options Avancées de Toit (Oui, Non)
                  PS
                  Does the Messages' window data is self-adapting to the length of words ?
                  • medeekM Offline
                    medeek
                    Thank-you Pilou, I will add these phrases into the language file.
                    Yes, the SU menu automatically adjust for the length of the words so even though French is often more verbose than English it does not matter. I've noticed though that Russian has some problems rendering in the SU menus.
                    I would have liked to see the video dive into the advanced menus more but I realize there is far too much material to cover in such a short video.
                    design.medeek.com
                      Excellent! 👍
                      What is BC and TC size ? 😳
                      Minor Roof Family = Famille de Toit Secondaire
                      Gable Dormer = Lucarne de Pignon
                      Hit Dormer = Lucarne de Toit
                      Shed Dormer = Lucarne de Hangar
                      Gable Roof Minor = Pignon de Toit Secondaire (?)
                      Hip Roof Minor = Lucarne de Toit Secondaire (?)
                      Dutch Gable Roof Minor = Pignon de Toit Hollandais Secondaire (?)
                      The (?) does not signify that is forcefully false but can maybe be enhanced! 😉
                      Else works fine! 😄
                      • medeekM Offline
                        medeek
                        BC = Bottom Chord
                        TC = Top Chord
                        Web = Internal (web) members of truss
                        design.medeek.com
                          Thx for the Infos! ☀
                          • medeekM Offline
                            medeek
                            The license registration module was causing some problems in isolated cases so I've released a sub-rev. 2.1.1b to address that issue.
                            If you are trying to enter in your serial number and it does not appear to take, first verify that you are not entering in any leading or trailing white spaces if that does not solve the problem you may be encountering the issue at top, in that case download the latest version which should address the issue fully.
                            design.medeek.com
                              Valley set chest => Panel de Noue
                              Stepdown Hip Set => Panel de Panne de Rive Inclinée
                              Terminal Hip Set => Panel de Sablière
                              Northeast Hip Set => Panel de Linçoir
                              Metal plate connectors = Connecteur Métallique Plat
                              Gusset = Gousset
                              Web = Membrure
                              Web = Fiche & Contre-Fiche
                              in this following Schema "Chantignole" is false : must be "Arbalétrier" ! 🤓
                              https://media.ooreka.fr/public/image/plan-charpente-29-big-9926265.jpg
                              • medeekM Offline
                                medeek
                                This week has been a bit tough for me to get any meaningful work done on any of the plugins, too many Christmas concerts, parties etc... but I guess its for the better. This weekend I will try to get out the update for the heel blocking and an update on the translations.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.1.2 - 12.18.2017
                                  • Enabled vertical and angled heel blocking within the advanced options for truss roofs.
                                  http://design.medeek.com/resources/images/truss_su325_800.jpg
                                  If you choose to enable vent holes the heelblock menu will prompt for the hole diameter. The vent hole algorithm will place vent holes in the heel blocking per the truss spacing:
                                  < 12 in. = 1 vent hole
                                  < 16 in. = 2 vent holes
                                  16 in. or greater = 3 vent holes
                                  Let me know if this makes sense, I can always modify it to meet any criteria. If this sort of thing varies a lot per locale I can also make it more user definable.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    This type of heel blocking is very typical in my locale (Western Washington State):
                                    http://design.medeek.com/resources/images/truss_su326_800.jpg
                                    View model here:
                                    3D Warehouse
                                    (3dwarehouse.sketchup.com)
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      To end off the year with a bang and to thank our truss plugin clientele I have decided to reduce the license renewal fee for the Medeek Truss Plugin to $10.00 USD. This promotion will run until the end of this year (Dec. 31, 2017) and then the renewal price will return to its usual price of $20.00 USD.
                                      This year has been very busy with further developments of the truss and foundation plugins. I am looking forward to the new year and another full year of new features and even new plugins and tools.
                                      I've really appreciated all those who have actively contributed to the recent developments of the plugin, especially the translations.
                                      A Merry Christmas to all and a Happy New Year.
                                      design.medeek.com
                                        Sorry but a more complete French translation will be at the beginning of the next year : no more free times for the moment! 😞
                                        Have happy new year! 😎
                                        • medeekM Offline
                                          medeek
                                          Just some minor bug fixes for 2.1.2b, I will probably address some other minor issues brought to my attention in the next couple of days.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I've been thinking about adding in the option to show H1 ties for rafters and trusses:
                                            https://embed.widencdn.net/img/ssttoolbox/ztwjogo5os/500px@1x/H1 (inst).jpeg?quality=80&u=cjmyin&crop=0
                                            I've seen them mounted both on the exterior and the interior with the flanges facing both inward and outward, four possible configurations. Any preference on how these are typically installed. I'm sure there is probably not much call for these but it isn't a big deal to add in the option for those that would like to use it.
                                            I am currently featuring Simpson Strong-Tie hardware in the Truss Plugin, not because I am specifically endorsing their products or the brand but because that is what I am most familiar with and their products are readily available in the US and Canada. Mitek also makes comparable hardware and probably has better availability outside of the US and Canada.
                                            I'm also thinking about allowing the user to choose between and H1 or H2.5A:
                                            https://images-na.ssl-images-amazon.com/images/I/41Q4wRZDHEL._SX385_.jpg
                                            design.medeek.com
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 75
                                            • 76
                                            • 39 / 76
