    Construction Methods In France Questions
    26 Posts 4 Posters 5.7k Views 4 Watching
    • Joe WoodJ
      Joe Wood
      This is floor framing
      this is wall framing
      and these are the posts and beams ๐Ÿ™‚
      Joe Wood
      woodsshop.com/
      • Joe WoodJ
        Joe Wood
        My questions are
        What do you call posts and beams in France, Poteaux et poutres?
        and floor framing, charpente du plancher ?
        Joe Wood
        woodsshop.com/
          Ok! So what is the question(s) ? ๐Ÿ˜„
          If this exist also in France ?
          Put "ossature bois" inside google research image! ๐Ÿ˜‰
          "plancher ร  ossature bois"
          "charpente ร  ossature bois"
          "mur ร  ossature bois"
            Affirmative! ๐Ÿ˜„
            Post = Poteau (un poteau, le poteau)
            Beam = Poutre (une poutre, la poutre)
            floor framing = l'ossature du plancher, la structure du plancher...la charpente du plancher! ๐Ÿ˜„
            • Joe WoodJ
              Joe Wood
              Thank you Frenchy, say, is all that artwork on your site digital or do you do any traditional artwork?
              Joe Wood
              woodsshop.com/
                Only digital, but it's just hobbyist relaxing for explore crazzy progs! ๐Ÿ˜„
                • Joe WoodJ
                  Joe Wood
                  Frenchy, what is the French for timber frame? Like with this photo, with the structure joined with mortises and pegs?
                  [attachment=1:2jr1xk38]<!-- ia1 -->1 Capture dโ€™รฉcran 2017-03-03 ร  15.47.15.png<!-- ia1 -->[/attachment:2jr1xk38]
                  Versus stick framed like this
                  [attachment=0:2jr1xk38]<!-- ia0 -->1 stick framed.jpg<!-- ia0 -->[/attachment:2jr1xk38]
                  With the Deep l translator I said I don't do any timber frame designs, and the translator made it 'wooden frame' instead of timber frame.
                  Joe Wood
                  woodsshop.com/
                    I believe that is "Cadre Poteau / Poutre en Assemblage ร  mi-bois en partie haute"
                    (Post / beam frame in half-timbered assembly in upper part)
                    I suppose mortise tenon assembly in lower part = assemblage tenon mortaise en partie basse
                    if i can good see the side view (that is not evident! ๐Ÿ˜„
                    • Joe WoodJ
                      Joe Wood
                      Merci encore Frenchy!
                      Joe Wood
                      woodsshop.com/
                        Please read your PM system! ๐Ÿ˜‰
                        • 2 / 2
