    Construction Methods In France Questions
    26 Posts 4 Posters 5.4k Views 4 Watching
      Sure! πŸ˜„
      Poteaux / Poutres ?
      An image can better explain than a text! πŸ˜‰
      • Joe WoodJ Offline
        Joe Wood
        This is floor framing
        this is wall framing
        and these are the posts and beams πŸ™‚
        Joe Wood
        woodsshop.com/
        • Joe WoodJ Offline
          Joe Wood
          My questions are
          What do you call posts and beams in France, Poteaux et poutres?
          and floor framing, charpente du plancher ?
          Joe Wood
          woodsshop.com/
            Ok! So what is the question(s) ? πŸ˜„
            If this exist also in France ?
            Put "ossature bois" inside google research image! πŸ˜‰
            "plancher Γ  ossature bois"
            "charpente Γ  ossature bois"
            "mur Γ  ossature bois"
              Affirmative! πŸ˜„
              Post = Poteau (un poteau, le poteau)
              Beam = Poutre (une poutre, la poutre)
              floor framing = l'ossature du plancher, la structure du plancher...la charpente du plancher! πŸ˜„
              • Joe WoodJ Offline
                Joe Wood
                Thank you Frenchy, say, is all that artwork on your site digital or do you do any traditional artwork?
                Joe Wood
                woodsshop.com/
                  Only digital, but it's just hobbyist relaxing for explore crazzy progs! πŸ˜„
                  • Joe WoodJ Offline
                    Joe Wood
                    Frenchy, what is the French for timber frame? Like with this photo, with the structure joined with mortises and pegs?
                    [attachment=1:2jr1xk38]<!-- ia1 -->1 Capture d’écran 2017-03-03 Γ  15.47.15.png<!-- ia1 -->[/attachment:2jr1xk38]
                    Versus stick framed like this
                    [attachment=0:2jr1xk38]<!-- ia0 -->1 stick framed.jpg<!-- ia0 -->[/attachment:2jr1xk38]
                    With the Deep l translator I said I don't do any timber frame designs, and the translator made it 'wooden frame' instead of timber frame.
                    Joe Wood
                    woodsshop.com/
                      I believe that is "Cadre Poteau / Poutre en Assemblage Γ  mi-bois en partie haute"
                      (Post / beam frame in half-timbered assembly in upper part)
                      I suppose mortise tenon assembly in lower part = assemblage tenon mortaise en partie basse
                      if i can good see the side view (that is not evident! πŸ˜„
                      • Joe WoodJ Offline
                        Joe Wood
                        Merci encore Frenchy!
                        Joe Wood
                        woodsshop.com/
                          Please read your PM system! πŸ˜‰
                          • 2 / 2
