Spinning discs animation
Hi, I have been asked to create a short animation displaying several spinning disc's (similar to gears) but the disc's are spinning at different rotation speeds & the whole image is slowly rotating itself. Is this possible with the animation feature in SKP (v2016 Pro)? or do I need a more sophisticated plugin to achieve this result. Do I nest all the components & then create the animation scenes for each disc independently? I have done a basic search for tutorials but have not found any yet that deals with multiple animated components that are rotating. Any suggestions? thanks
You should be able to accomplish this with Fredo6's Animator plugin.
Thanks for the input. Will search for some specific Fredo6 tutorials.
