Where are shortcuts stored in sketchup2018
In su 2017 or before , shortcuts are stored in registry.
But where are they stored in su2018?
wikii
C:/Users/USERNAME/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/SharedPreferences.json
You need to split/parse the file to find [for example]:"Settings"; { "Num_Shortcuts"; 37, "Shortcut_1"; "0 0 0 H selectDollyTool;", "Shortcut_10"; "0 0 0 P selectPushPullTool;", "Shortcut_11"; "0 0 0 R selectRectangleTool;", "Shortcut_12"; "0 0 0 Space selectSelectionTool;", "Shortcut_13"; "0 0 0 L selectLineTool;", "Shortcut_14"; "0 0 0 K View/Edge Style/Back Edges", "Shortcut_15"; "0 0 0 M selectMoveTool;", "Shortcut_16"; "0 0 0 G Edit/Make Component...", "Shortcut_17"; "0 0 0 T selectMeasureTool;", "Shortcut_18"; "0 0 0 F selectOffsetTool;", "Shortcut_19"; "0 0 0 Q selectRotateTool;", "Shortcut_2"; "0 0 0 I selectImageIglooTool;", "Shortcut_20"; "0 0 0 S selectScaleTool;", "Shortcut_21"; "0 1 0 X View/Face Style/X-ray", "Shortcut_22"; "0 0 1 A viewShowAxes;", "Shortcut_23"; "0 0 1 G viewShowHidden;", "Shortcut_24"; "0 0 1 I Edit/Intersect Faces/With Model", "Shortcut_25"; "1 0 1 I Edit/Intersect Faces/With Context", "Shortcut_26"; "0 1 1 I Edit/Intersect Faces/With Selection", "Shortcut_27"; "1 0 0 H View/Component Edit/Hide Rest Of Model", "Shortcut_28"; "1 0 1 H View/Component Edit/Hide Similar Components", "Shortcut_29"; "0 0 1 X Edit/Item/Explode", "Shortcut_3"; "0 0 0 O selectOrbitTool;", "Shortcut_30"; "1 0 1 V Edit/Paste In Place", "Shortcut_31"; "0 0 0 \\ Edit/Delete Guides", "Shortcut_32"; "0 1 0 G Edit/Make Group", "Shortcut_33"; "0 0 0 J Tools/TIG-weld", "Shortcut_34"; "0 1 0 Q Edit/Item/Reverse Faces", "Shortcut_35"; "0 0 1 Q Edit/Item/Orient Faces", "Shortcut_36"; "0 0 1 R Edit/Item/Mirror Selection", "Shortcut_37"; "0 0 0 D Edit/Item/Divide", "Shortcut_4"; "0 0 0 Z selectZoomTool;", "Shortcut_5"; "0 0 1 Z viewZoomExtents;", "Shortcut_6"; "0 0 0 A selectArcTool;", "Shortcut_7"; "0 0 0 C selectCircleTool;", "Shortcut_8"; "0 0 0 E selectEraseTool;", "Shortcut_9"; "0 0 0 B selectPaintTool;" },BUT I recommend that you use the longstanding method
Sketchup.get_shortcutsto return a similar list...***
It returns an array, with elements formatted thus:"Ctrl+Shift+E\tCamera/Zoom Extents", "Ctrl+Shift+W\tCamera/Zoom Window", ...where the modifier keys are spelled out more clearly than in the json file's 0/1.. format [clearly separated by+signs], and the\talways separates the keys and the command...
***This method will probably also return a longer list, as it includes ALL shortcuts, including those shipped with the installer, whereas the json version only includes those which have been added or modified by the user... -
You need to split/parse the file to find [for example]:"Settings"; { > "Num_Shortcuts"; 37, > "Shortcut_1"; "0 0 0 H selectDollyTool;", > "Shortcut_10"; "0 0 0 P selectPushPullTool;", > "Shortcut_11"; "0 0 0 R selectRectangleTool;", > "Shortcut_12"; "0 0 0 Space selectSelectionTool;", > "Shortcut_13"; "0 0 0 L selectLineTool;", > "Shortcut_14"; "0 0 0 K View/Edge Style/Back Edges", > "Shortcut_15"; "0 0 0 M selectMoveTool;", > "Shortcut_16"; "0 0 0 G Edit/Make Component...", > "Shortcut_17"; "0 0 0 T selectMeasureTool;", > "Shortcut_18"; "0 0 0 F selectOffsetTool;", > "Shortcut_19"; "0 0 0 Q selectRotateTool;", > "Shortcut_2"; "0 0 0 I selectImageIglooTool;", > "Shortcut_20"; "0 0 0 S selectScaleTool;", > "Shortcut_21"; "0 1 0 X View/Face Style/X-ray", > "Shortcut_22"; "0 0 1 A viewShowAxes;", > "Shortcut_23"; "0 0 1 G viewShowHidden;", > "Shortcut_24"; "0 0 1 I Edit/Intersect Faces/With Model", > "Shortcut_25"; "1 0 1 I Edit/Intersect Faces/With Context", > "Shortcut_26"; "0 1 1 I Edit/Intersect Faces/With Selection", > "Shortcut_27"; "1 0 0 H View/Component Edit/Hide Rest Of Model", > "Shortcut_28"; "1 0 1 H View/Component Edit/Hide Similar Components", > "Shortcut_29"; "0 0 1 X Edit/Item/Explode", > "Shortcut_3"; "0 0 0 O selectOrbitTool;", > "Shortcut_30"; "1 0 1 V Edit/Paste In Place", > "Shortcut_31"; "0 0 0 \\ Edit/Delete Guides", > "Shortcut_32"; "0 1 0 G Edit/Make Group", > "Shortcut_33"; "0 0 0 J Tools/TIG-weld", > "Shortcut_34"; "0 1 0 Q Edit/Item/Reverse Faces", > "Shortcut_35"; "0 0 1 Q Edit/Item/Orient Faces", > "Shortcut_36"; "0 0 1 R Edit/Item/Mirror Selection", > "Shortcut_37"; "0 0 0 D Edit/Item/Divide", > "Shortcut_4"; "0 0 0 Z selectZoomTool;", > "Shortcut_5"; "0 0 1 Z viewZoomExtents;", > "Shortcut_6"; "0 0 0 A selectArcTool;", > "Shortcut_7"; "0 0 0 C selectCircleTool;", > "Shortcut_8"; "0 0 0 E selectEraseTool;", > "Shortcut_9"; "0 0 0 B selectPaintTool;" > },BUT I recommend that you use the longstanding method
Sketchup.get_shortcutsto return a similar list...***It returns an array, with elements formatted thus:
***This method will probably also return a longer list, as it includes ALL shortcuts, including those shipped with the installer, whereas the json version only includes those which have been added or modified by the user...great!
If I modify the SharedPreferences.json file,such as add some shortcuts in it,will it take effect in sketchup immediately?
Try it and see...
But I suspect not.
Also SketchUp might overwrite changes on exit back as it is currently kept in memory from the start ? -
@tig said:
Try it and see...
But I suspect not.
Also SketchUp might overwrite changes on exit back as it is currently kept in memory from the start ?Yeah!
Modify this file will take effect when su restarted.
Thank you TIG!
wikii
@tig said:
Try it and see...
But I suspect not.
Also SketchUp might overwrite changes on exit back as it is currently kept in memory from the start ?bad news!
SketchUp DO overwrite changes on exit!
I expect that SketchUp reads these json files as it starts and writes out revised copies as it quits. So, if you edit the file while SketchUp is already running, SketchUp will not see the changes and will overwrite with its in-memory version when it quits. You need to quit SketchUp before editing any preferences files.
