    Animator: Parametric Animation plugin - Discussion
    249 Posts 56 Posters 144.9k Views 55 Watching
    • T
      TDahl
      I uploaded a more complete version of my work-in-progress model to DropBox.
      - Tom
      • T
        TDahl
        I've encountered an Animator problem (in v1.8a) that I encountered once or twice with v1.7d, where the editor and player become mostly unresponsive. In editor mode, clicking or dragging in the timeline has no effect other than to update the digital time text in the upper GUI area (the red timeline cursor does not move, no changes occur in the SketchUp viewport corresponding to camera or object movements); trying to render an animation causes the red frame rectangle to appear in the SketchUp viewport but the animation settings dialog box (for setting frame rate, selecting video formats, etc. plus the button to start the rendering) does not appear; clicking the green Play button seems to do nothing (no movement of blue cursor in timeline, nothing happening in the SketchUp viewport) other than toggle the button to become the Pause button (and clicking the Pause button reverts it back to the green Play button, but again has no effect on the timeline or viewport).
        Here is a file that is exhibiting this behavior for me.
        Through some experimentation, I found that if I disable the animation of object movements (but leave other actions enabled, in particular camera movements), then both the timeline behaves normally, and the render-animation mode displays the expected settings dialog box. If I disable camera movements but enable everything else, it still behaves badly (the timeline is mostly dead, the render-animation mode does not display the settings dialog box, the Play button does not do much).
        When I encountered this a couple of weeks ago with v1.7d I'm not sure what I eventually did to get past the behavior. I might have simply resorted to a previously saved copy of the SketchUp file and then re-created what I wanted (and somehow managed to avoid the behavior until today).
        If I open an older SketchUp file, Animator's GUI behaves normally - so it's not something that has somehow globally broken Animator. It seems to be something in the data of a particular SketchUp file. I have unintentionally triggered the behavior by opening an old version of the above linked file (which was behaving OK at the point I opened it), and then fiddling around in Animator - change some camera start/duration settings for example. BAM this opened file has begun exhibiting the broken behavior. Sigh.
        • T
          TDahl
          Aha! That makes sense. Thank you very much Fredo for diagnosing my model's problem! Before seeing your fast reply I was experimenting further and noticed that when hovering the mouse over three of the rotation animations in the timeline, the entire Animator GUI temporarily disappears. I could click in empty space (in the SketchUp viewport) and the chosen rotation would be selected and the GUI would reappear. I could then delete the rotation. After deleting the three rotations with this odd GUI behavior, the rest of Animator started working as expected. For all three of those rotations, I had used a temporary piece of geometry to be able to select the pivot point easily. Then I later deleted those "temp" objects. I did not correlate the beginning of the strange behavior with my having deleted those three rotation-pivot key objects.
          Lesson learned, thank you. I will simply hide those pivot objects in the future.
          • Tom
          • fredo6F
            @tdahl said:
            I still have some slight trouble creating a rotation motion within the sample model I linked in a prior reply, I cannot seem to use the mouse to establish the rotation sweep angle. But I can get it to work by clicking on the rotation point, and then using the properties dialog box to enter a numeric value for the rotation (which I could not get to work with v1.7d).
            I tried on my side and I did not observe particular problem of performance. Maybe I did not choose the right object? (note: I also added a few movements in a random manner, so that why the final playback looks disorganized)
            Animator Rotation Viking Lander.mov
            • fredo6F
              - Tom
              Wooh, big file, 136 Mb and superb model, really!!
              I tried to include a rotation in the model, and did not have major issue of performance.
              Note that I must have a much smaller screen than you have, which explains why the camera seems to be offset.
              Animator Viking Lander complex.mov
              • fredo6F
                There is a problem with one of the Rotation movement, called SSAA Azimuth, which apparently references a pivot component which has disappeared.
                This causes the error, blocking the whole animation of objects. If you open the Ruby console, you can see the errors.
                I would suggest you remove it from the animation, using the Maintenance dialog box (as it is uneasy to select the clip element in the timeline). Then you can recreate this rotation.
                I have fixed the errors in the code for a next release.
                One limitation in Animator is that groups and components referenced by the animation must not be deleted. Otherwise, you get this type of behavior.
                Animator already tracks this for the main objects to move (Clip element will appear in red), but here it is the reference pivot object, and I did not cover the case yet.
                EDIT: I made the changes to ensure that this type of error is detected. The faulty sequences will appear in Red (with a tooltip giving the error) and will be ignored
                This will go in the next release
                • T
                  TDahl
                  Fredo, thank you for conducting further experiments with my model files. The remaining performance issue I saw and reported with v1.8a seems to have been a transient condition, because creating animation steps has been OK for the past day or so. Sorry for the false-alarm report. By the way, I also learned how to hide the Animator GUI while playing an animation in Edit mode and have happily discovered that playback performance is great with that approach.
                  Thanks for the compliment on my work-in-progress model. It represents about 1,500 hours or so of time in SketchUp and Photoshop (to do photo scaling and interpolated measurement using a collection of some 3,500 detail photographs I've taken of actual Viking hardware during the past few years). In 2016 I created a making-of video that describes my process. I'm currently using Animator (and also hope to use MSPhysics) to create another video demonstration of the model.
                  https://youtu.be/1vyzoWudom8
                  • T
                    TDahl
                    What approaches do people suggest for configuring a camera path that orbits around and closes in on a subject, with the goal to have a smooth motion throughout the path (while keeping the camera pointed where desired)?
                    I have been using SketchUp scenes to define discrete camera positions, and creating Animator camera objects in the timeline for each scene. I have a hard time avoiding a bounce when the camera reaches each discrete scene key position. The three Animator camera path choices (circular, linear, bezier) all yield bounces unless the straight-line path between camera positions is naturally somewhat linear (which defeats the goal of orbiting around a subject, perhaps dipping above or below). The circular and bezier choices sometimes yield wildly crazy intermediate pointing and pathing (compared to SketchUp's native scene-to-scene camera motion), so I tend to use the linear choice in Animator.
                    Perhaps I could create a curve (welded out of line segments, curves, etc.) using SketchUp tools, and then constrain the camera to that geometric path? I seem to recall that is possible, but I don't know how camera pointing is defined with that approach.
                    • fredo6F
                      • Tom
                      Maybe you can use a construction point on the component / group that serve the pivot.
                      Also, when you select the rotation pivot, right click to show the contextual menu. Then you can choose the right object, or the absolute coordinates for pivot. I'll try to make this more user friendly in a next release, but this is today the way you can select the pivot reference.
                      • fredo6F
                        I have modified the algorithm for circular interpolation in Animator 1.8b (along with LibFredo6 8.0b).
                        Still not the native Sketchup scene transition algorithm, but I hope a smoother transition.
                        • T
                          TDahl
                          Fredo, thank you very much! I just upgraded to 1.8b and the circular camera paths are definitely better to my taste. I have been working on a sequence with multiple camera positions (see below) where the prior circular pathing was a bit too crazy for a number of the transitions. With this new version I was able to set them to circular and achieve a nicer result. Fantastic improvement, thank you again.
                          - Tom
                          • fredo6F
                            Tom,
                            Quite impressive, first the model itself and the animation for the mountng.
                            For the animation, did you proceed by unmounting from an assembled model (and then running the video backward), or the contrary?
                            • T
                              TDahl
                              Hi Fredo, as you suspected the animation was done by disassembling an intact model and then running the animation in reverse. A very handy feature of Animator to be able to do that!
                              • Tom
                              • ntxdaveN
                                ntxdave
                                Very impressive Tom.......
                                Press F1...thank me later
                                  ruudvanderham
                                  I am completely new to Sketchup, but it seems that Animator might be a good starting point for what I would like to realize.
                                  I have discrete event simultion of a container terminal written in Python (with my salabim tool). There I can do 2D animations. My idea is to interface either the code or a file with actions (crane moves, spreader, lowers, container is placed, ...) with Sketchup.
                                  Is there any possibility of interfacing Animator with 'the outside world', preferably with an API, but a file is also acceptable. Does that involve Ruby programming.
                                  Any advise is welcome.
                                  • fredo6F
                                    Animator is designed to generate videos of animation based on parameterization of object and camera movement.
                                    If the simulation aspect is more important for you, then I would suggest that you have a look at MSPhysics, which is more a Physical engine, which can also generate videos. I think it has some kind of script programming.
                                      ruudvanderham
                                      @Fredo
                                      Thanks for the response.
                                      Maybe just a little bit more explanation: All I want to do is animate the output of a simulation. This output might look like:
                                      t0=100 t1=110 object=crane1 x0=10 x1=300
                                      t0=100 t1=120 object=crane2 x0=20 x1=200
                                      t0=110 t1=200 object=spreader1 z0=100 z1=10
                                      t0=120 t1=130 object=container191 location=(10,20,40)
                                      Just to give an example.
                                      Would there be any way to interpret that kind of info (format totally discussable) and animate it with Animator/Sketchup?
                                      • fredo6F
                                        Animator does not have (yet) a specification scripting language. Again, it is not designed as a simulation tool, but as a video generation plugin.
                                        It all depends on what you have in mind. Maybe, if you already have the model built in Sketchup, and you post it, I can tell what you can do (or not do) with Animator, and in MSPhysics.
                                        • T
                                          TDahl
                                          Does the ability to Control-click a set of elements in the timeline to group them into a clip still exist? This was shown in one of Fredo's earlier YouTube Animator videos, #2 I think. When I try (using v1.8b on a Mac in SketchUp Pro 2017), attempting to Control-Click on a timeline element pops up a tiny gray menu thing with "Exit" as the only choice. I have not figured out any other way to collect a set of timeline elements into a group, which would be convenient for re-using a set of coordinated actions.
                                          • fredo6F
                                            Tom,
                                            I think on Mac, this is Command+Click.
                                            Tell me if it does not work.
                                            • 11
                                            • 12
                                            • 13
                                            • 9 / 13
