    Fredo6 Plugins and Sketchup 2018
    5 Posts 4 Posters 3.6k Views 4 Watching
    • fredo6F Offline
      To all users,
      In principle, all my plugins should work in SU2018 if you upgrade to their latest versions.
        grabuge
        Merci pour ton boulot Fredo !
          laudhi
          Seems your plugins works fine in sketchup 2018, thanks fredo for your hard work... 👍
            gttc88
            **[size=100:cjok4imk]**Hello
            please help me out here
            after adding Fredo6 plugins (from Fredo6 v8.0c Library) to Sketchup 2018 in windows 7 64 bits
            Fredo6 plugins diden't show up and i got this message after i restarted Sketchup**[/size]**
            " Error: SketchUp:1:in eval' Error: #<NameError: uninitialized constant Traductor::Chrono6> c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:203:in module:F6_FredoScale'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredoscale/bootstrap_fredoscale.rbe:22:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in require' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in require_ruby'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1078:in block (2 levels) in load_bootstrap_rubies' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1075:in each'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1075:in block in load_bootstrap_rubies' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1073:in each'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1073:in load_bootstrap_rubies' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1029:in effective_load_part2'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:988:in effective_load' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredoscale/__loader__fredoscale.rbe:1:in <main>'
            E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in eval' E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require'
            E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:37:in register_extension'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:37:in <module:Fredo6>' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:27:in <top (required)>'
            Error: #<NameError: uninitialized constant Traductor::Plugin::T6>
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1057:in effective_load_part2' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:988:in effective_load'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredoscale/loader__fredoscale.rbe:1:in <main>' E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in eval'
            E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require' E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:37:in register_extension' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:37:in module:Fredo6'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoScale.rb:27:in <top (required)>' Error: #<NoMethodError: undefined method add_credits' for #Traductor::Plugin:0x00000014b4ca30>
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__angleinspector.rbe:38:in module:AngleInspector'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__angleinspector.rbe:31:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__angleinspector.rbe:23:in <main>'
            !libfredo6/top_libfredo6.rbe:263:in eval' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in require'
            !libfredo6/top_libfredo6.rbe:263:in require_ruby' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1107:in block (2 levels) in load_full_rubies'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1104:in each' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1104:in block in load_full_rubies'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1102:in each' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1102:in load_full_rubies'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1029:in effective_load_part2' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:988:in effective_load'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/loader__fredotools.rbe:1:in <main>' E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in eval'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:57:in register_extension' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:57:in module:Fredo6'
            Error: #<NoMethodError: undefined method add_credits' for #<Traductor::Plugin:0x00000014b4ca30>> c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__autoreversefaces.rbe:37:in <module:AutoReverseFaces>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__autoreversefaces.rbe:30:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__autoreversefaces.rbe:22:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            !libfredo6/lib6core.rbe:1107:in block (2 levels) in load_full_rubies' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1104:in each'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1104:in block in load_full_rubies' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1102:in each'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1102:in load_full_rubies' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1029:in effective_load_part2'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:988:in effective_load' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/__loader__fredotools.rbe:1:in <main>'
            E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:57:in register_extension'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:57:in <module:Fredo6>' ... Error: #<NoMethodError: undefined method add_credits' for #Traductor::Plugin:0x00000014b4ca30>
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__constructfacenormal.rbe:38:in module:ConstructFaceNormal'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__constructfacenormal.rbe:31:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__constructfacenormal.rbe:23:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in require'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in require_ruby' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1107:in block (2 levels) in load_full_rubies'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__convexify.rbe:37:in <module:Convexify>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__convexify.rbe:30:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__convexify.rbe:22:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__countfacesbysides.rbe:37:in module:CountFacesBySides'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__countfacesbysides.rbe:30:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__countfacesbysides.rbe:22:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__curvishear.rbe:37:in <module:CurviShear>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__curvishear.rbe:30:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__curvishear.rbe:22:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__divideedges.rbe:38:in module:DivideEdges'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__divideedges.rbe:31:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__divideedges.rbe:23:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__drawalong.rbe:38:in <module:DrawAlong>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__drawalong.rbe:31:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__drawalong.rbe:23:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__edgeinspector.rbe:38:in module:EdgeInspector'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__edgeinspector.rbe:31:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__edgeinspector.rbe:23:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__elementstats.rbe:38:in <module:ElementStats>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__elementstats.rbe:31:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__elementstats.rbe:23:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__markvertices.rbe:39:in module:MarkVertices'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__markvertices.rbe:26:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__markvertices.rbe:24:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__movealong.rbe:38:in <module:MoveAlong>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__movealong.rbe:31:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__movealong.rbe:23:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__removelonelyvertices.rbe:39:in module:RemoveLonelyVertices'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__removelonelyvertices.rbe:32:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__removelonelyvertices.rbe:24:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__reportlabelarea.rbe:37:in <module:ReportLabelArea>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__reportlabelarea.rbe:30:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__reportlabelarea.rbe:22:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__reverseorientfaces.rbe:37:in module:ReverseOrientFaces'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__reverseorientfaces.rbe:30:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__reverseorientfaces.rbe:22:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__revertcurve.rbe:37:in <module:RevertCurve>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__revertcurve.rbe:24:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__revertcurve.rbe:22:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools.rbe:99:in register_info' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__solidvolume.rbe:38:in module:SolidVolume'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__solidvolume.rbe:31:in <module:F6_FredoTools>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__solidvolume.rbe:23:in <main>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__thrupaint.rbe:37:in <module:ThruPaint>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__thrupaint.rbe:30:in module:F6_FredoTools'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_fredotools/fredotools__thrupaint.rbe:22:in <main>' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:263:in eval'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:57:in <module:Fredo6>' ... Error: #<NameError: uninitialized constant Traductor::Plugin::T6> c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1057:in effective_load_part2'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:57:in <module:Fredo6>' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in <top (required)>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_jointpushpull/loader__jointpushpull.rbe:1:in <main>' E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in eval'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:57:in register_extension' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:57:in module:Fredo6'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_JointPushPull.rb:26:in <top (required)>' Error: #<NameError: uninitialized constant Traductor::Plugin::T6> c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_!libfredo6/lib6core.rbe:1057:in effective_load_part2'
            !libfredo6/lib6core.rbe:988:in effective_load' c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_roundcorner/__loader__roundcorner.rbe:1:in <main>'
            E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:57:in register_extension'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:57:in <module:Fredo6>' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_RoundCorner.rb:26:in <top (required)>'
            c:/users/gttc/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/fredo6_toolsonsurface/__loader__toolsonsurface.rbe:1:in <main>' E:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in eval'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:57:in register_extension' C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:57:in module:Fredo6'
            C:/Users/gttc/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/Fredo6_ToolsOnSurface.rb:26:in `<top (required)>' "
            error message
            • fredo6F Offline
              I suggest you redo a clean installation of LibFredo6.
              Obviously, your update did go wrong somewhere. If you post a capture of your Sketchup Plugins directory, I think I could tell you what's wrong.
