    Need help punching pattern into cylindrical object
    45 Posts 6 Posters 30.5k Views 6 Watching
    • macleeM
      maclee
      Still making progress, I got my geometry all figured out, just need to accept the fact that I have to change the pattern as I go down. Maybe just a few simple leaves going back and forth for design and then of course I have to punch the holes. I am happy I got the pattern even just 2 rows of it at the top. Also hoping that I can round it off after I am done so it doesn't look so jagged.
      Thanks again for your help and ideas, they have been very helpful! Still not done but getting there!
      Obstacles do not block the path, they are the path.
      • boofredlayB
        boofredlay
        Have you tried the method I used in the video I posted up. That way allows for you to have your pattern along the taper at the bottom.
        • macleeM
          maclee
          I started it but I couldn't get my pattern to match the top and bottom and have edges connect, I think I need to do the same pattern you did to make that work. I will try it!
          • macleeM
            maclee
            [quote="boofredlay"]Here is the tutorial on Youtube: https://youtu.be/sQJoDYOCM0M
            This is one way to do it. I am sure there are probably others.
            Well it took me a while but I think this is the best I can do! I ended up using your method boofredlay, as the other way created a distorted pattern at the bottom which I couldn't fix, although I did find using the curve tool easier to get the shape. In the end I just couldn't fix it.
            With your method, I couldn't smooth the edges at the end like you did, it just distorted all the cutouts... any suggestions? The file is 22M yikes! Here is the link if that helps: https://www.dropbox.com/s/u9kzyhuvujywxho/pattern_v11_final.skp?dl=0
            A huge thanks to you for your help and sharing ideas! I would never have even gotten this close without it!
            Lee
            • JQLJ
              JQL
              You've simplified the hole's geometry to a plane. That simplifies everything but doesn't bend the shape as it should. So there's no actual aproximation to what it is in reality and in my opinion doesn't solve the true issue in discussion.
              However if it fits your objectives it's a perfect solution and congratulations are in order.
              Even so, you could try this plugin here:
              404 Not Found
              (sketchucation.com)
              www.casca.pt
              Visit us on facebook!
              • macleeM
                maclee
                404 Not Found
                (sketchucation.com)
                yes exactly you are right... every time I would bend the geometry in the dome it would pull the edges and distort the thickness. Maybe this plugin would have worked, I will investigate it further and thanks for the suggestion!
                • boofredlayB
                  boofredlay
                  @maclee said:
                  ...With your method, I couldn't smooth the edges at the end like you did, it just distorted all the cutouts... any suggestions? The file is 22M yikes! Here is the link if that helps: https://www.dropbox.com/s/u9kzyhuvujywxho/pattern_v11_final.skp?dl=0
                  Lee
                  Here is my model. Hopefully it will help your process.
                  pattern cut 4.skp
                  • boofredlayB
                    boofredlay
                    @jql said:
                    ...http://sketchucation.com/forums/viewtopic.php?f=323&t=61363
                    Ooo, forgot about Flowify.
                    This was much easier.
                    Model with step by step attached.
                    pattern cut FLOWIFY.skp
                    • macleeM
                      maclee
                      Awesome thanks! I did find a few issues with my model and started over and this time the alignment was perfect. Thanks for your help, I just sent it to the 3D printer and he said the file was good. PHEW! So excited to see the results. I realize this isn't something most people will need but it will be a huge thing for me. (long story what it is, not sure if people would be that interested!)
                      Thanks again, I really appreciate your help, that video was great and it was also super helpful seeing your file.
                      Lee πŸ˜„
                      • boofredlayB
                        boofredlay
                        Happy to help and I learned a bit too.
                        • 3 / 3
