    Need help punching pattern into cylindrical object
    45 Posts 6 Posters 29.7k Views 6 Watching
    • macleeM
      maclee
      sorry I deleted this post and updated it below.
      Obstacles do not block the path, they are the path.
      • boofredlayB
        boofredlay
        @jql said:
        @boofredlay said:
        @jql said:
        Check the following gif.
        This is great JQL however when you have to trim the edges because of the overlap the original pattern is destroyed. I have been struggling with the right angle to make the shape "wedge" to a point so no trimming is necessary.
        Share your model at the same stage boofredlay, I'm sure there is a solution.
        Here you go but as you can see, the edges will never taper properly to a point. The repeating pattern is destroyed each time. I think the method I used originally works much better, slower but more accurate.
        Bowl Pattern.skp
        • JQLJ
          JQL
          @maclee said:
          Well I am making progress but still issues that seem a bit too complicated for me to figure out. Maybe I need a more simple pattern.
          I'd say you need a simpler section of that pattern. What you could do is probably make a section of half the pattern and then mirror it, create a section component and polar array it with the rotate tool.
          www.casca.pt
          Visit us on facebook!
          • JQLJ
            JQL
            I'm sure you're right, but I'll give it a shot anyway.
            www.casca.pt
            • macleeM
              maclee
              Still making progress, I got my geometry all figured out, just need to accept the fact that I have to change the pattern as I go down. Maybe just a few simple leaves going back and forth for design and then of course I have to punch the holes. I am happy I got the pattern even just 2 rows of it at the top. Also hoping that I can round it off after I am done so it doesn't look so jagged.
              Thanks again for your help and ideas, they have been very helpful! Still not done but getting there!
              • boofredlayB
                boofredlay
                Have you tried the method I used in the video I posted up. That way allows for you to have your pattern along the taper at the bottom.
                • macleeM
                  maclee
                  I started it but I couldn't get my pattern to match the top and bottom and have edges connect, I think I need to do the same pattern you did to make that work. I will try it!
                  • macleeM
                    maclee
                    [quote="boofredlay"]Here is the tutorial on Youtube: https://youtu.be/sQJoDYOCM0M
                    This is one way to do it. I am sure there are probably others.
                    Well it took me a while but I think this is the best I can do! I ended up using your method boofredlay, as the other way created a distorted pattern at the bottom which I couldn't fix, although I did find using the curve tool easier to get the shape. In the end I just couldn't fix it.
                    With your method, I couldn't smooth the edges at the end like you did, it just distorted all the cutouts... any suggestions? The file is 22M yikes! Here is the link if that helps: https://www.dropbox.com/s/u9kzyhuvujywxho/pattern_v11_final.skp?dl=0
                    A huge thanks to you for your help and sharing ideas! I would never have even gotten this close without it!
                    Lee
                    • JQLJ
                      JQL
                      You've simplified the hole's geometry to a plane. That simplifies everything but doesn't bend the shape as it should. So there's no actual aproximation to what it is in reality and in my opinion doesn't solve the true issue in discussion.
                      However if it fits your objectives it's a perfect solution and congratulations are in order.
                      Even so, you could try this plugin here:
                      404 Not Found
                      (sketchucation.com)
                      www.casca.pt
                      • macleeM
                        maclee
                        404 Not Found
                        (sketchucation.com)
                        yes exactly you are right... every time I would bend the geometry in the dome it would pull the edges and distort the thickness. Maybe this plugin would have worked, I will investigate it further and thanks for the suggestion!
                        • boofredlayB
                          boofredlay
                          @maclee said:
                          ...With your method, I couldn't smooth the edges at the end like you did, it just distorted all the cutouts... any suggestions? The file is 22M yikes! Here is the link if that helps: https://www.dropbox.com/s/u9kzyhuvujywxho/pattern_v11_final.skp?dl=0
                          Lee
                          Here is my model. Hopefully it will help your process.
                          pattern cut 4.skp
                          • boofredlayB
                            boofredlay
                            @jql said:
                            ...http://sketchucation.com/forums/viewtopic.php?f=323&t=61363
                            Ooo, forgot about Flowify.
                            This was much easier.
                            Model with step by step attached.
                            pattern cut FLOWIFY.skp
                            • macleeM
                              maclee
                              Awesome thanks! I did find a few issues with my model and started over and this time the alignment was perfect. Thanks for your help, I just sent it to the 3D printer and he said the file was good. PHEW! So excited to see the results. I realize this isn't something most people will need but it will be a huge thing for me. (long story what it is, not sure if people would be that interested!)
                              Thanks again, I really appreciate your help, that video was great and it was also super helpful seeing your file.
                              Lee ๐Ÿ˜„
                              • boofredlayB
                                boofredlay
                                Happy to help and I learned a bit too.
                                • 3 / 3
